1985 300SD engine shock absorber - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 01-09-2011, 06:03 AM Thread Starter
BenzDslPwr's Avatar
Date registered: Feb 2009
Vehicle: 1985 300sd
Question 1985 300SD engine shock absorber
Hey,
I need help. I have been told I needed to replace both engine shock absorbers and the engine mount since the engine has been shaking pretty badly, rattling the whole body as a result. I live in Poland and it is rare to find new and quality parts for W126 diesels. I have found plenty of engine suspension parts for gasoline type engines. Now, will the SE (SEL) engine shock absorbers, engine mounts and other engine suspension components fit the SD type? I can get the parts from the well-known MB parts places in the US but the shipping costs will kill my budget, not to mention the time. TIA.
BenzDslPwr is offline
post #2 of 9 (permalink) Old 01-09-2011, 07:41 AM
Rmac58's Avatar
Date registered: Nov 2007
Vehicle: 2013 MINI Copper S Clubman, '84 300CD-weekend car
Quoted: 139 Post(s)
Does the engine shake all the time, or once warmed up? If the latter, a rack bolt/pin adjustment or replacement may be your problem.
The attachment shows which shocks will fit. Your SD is a 126.120 this link shows the chassis numbers: Mercedes Chassis & Engine Identification Chart
EDIT: The shock is used primarily for when the engine is shut off, you get a pretty violent shake and the shocks tame that.
Name:	engine shocks.jpg
'13 MINI Cooper Clubman S-daily driver
'84 CD-weekender!
Rmac58 is offline
post #3 of 9 (permalink) Old 01-09-2011, 08:07 AM
dranrebdy's Avatar
Date registered: Dec 2010
Vehicle: W108 250s '67, w123 280ce '77, w123 300d-t '85, w126 300sd '85', w140 s600 '94,w210 e230 '97, bug69
They will fit the sd, i have installed engine mounts from a v8 560se on my sd, and its worth it, costed more but lasted longer, i have had several sd engine mounts and they just lasted 1-2years, but with the more heavy duty v8 mounts its still is working fine now for almost 5years, the small engine shock well you can do away with this as i have several friends who did not install these shocks for their sd's and they are still ok, no body shakes
dranrebdy is offline
post #4 of 9 (permalink) Old 01-09-2011, 02:00 PM Thread Starter
BenzDslPwr's Avatar
Vehicle: 1985 300sd
Thumbs up
Hey Rmac58,
the engine tends to shake while warm and idling. I can have it at a complete stop and I could just feel entire body shaking. When the engine is cold and I start it, it also gives me a pretty good shake while starting. If I don't hold it at a 750-800 RPM's it will die and I have to start it again. I have played around with the rack bolt adjustment but to no avail.
My mechanic tells me that my engine mount is really bad, soaked with oil, the rubber does not hold up that well anymore. The engine shock absorbers looked like they have never been changed. It looks like I need a set of those shock absorbers along with the kit. If those are not the cause of the shakes, it sure will be a good thing to replace them anyway. I will research further the cause.
post #5 of 9 (permalink) Old 01-09-2011, 02:07 PM Thread Starter
BenzDslPwr's Avatar
Vehicle: 1985 300sd
I have been thinking about that too but was not too sure whether the bigger displacement engine mounts would fit my smaller SD. On the picture, they all look pretty much the same.
There are two reasons why I am so stock on those engine shock absorbers:
- I went to a shop that does W116, W123, W124, W126 (and latter W's of course) and told me what was wrong
- I saw mercedessource.com video about possible causes of the engine shock and surely the engine mount and the absorbers were the cause of it
For now, I can only rely on those sources, which seem to be pretty reliable. Now, it is my job to find the most reasonable-priced parts and have my mechanic perform his magic.
post #6 of 9 (permalink) Old 01-09-2011, 02:34 PM
Rmac58's Avatar
Quoted: 139 Post(s)
Okay, check your glow plugs too.
Mounts: Your Parts Search Returned 1 Part(s)
Good luck and let us know how things turn out.
'84 CD-weekender!
Rmac58 is offline
post #7 of 9 (permalink) Old 01-09-2011, 09:20 PM
dranrebdy's Avatar
At 1st i was using original engine mounts for the sd but replacing them every year was quite an expensive thing to do, they wont last for more than a year thats why i decided to use the v8 engine mounts and they really are very durable as i have mentioned 5years with no engine violent shaking, and i also decreased the idle down to 800 and the engine runs really smooth
post #8 of 9 (permalink) Old 01-10-2011, 06:35 AM Thread Starter
BenzDslPwr's Avatar
Vehicle: 1985 300sd
so, now I know a lot about engine mounts but what about the shock absorbers? Can I replace the SD engine shock absorbers with the SE engine ones?
post #9 of 9 (permalink) Old 01-10-2011, 08:14 AM
dranrebdy's Avatar
yes you can, the shock for the engine support will be an exact fit, i fail to mention that i too have installed the engine shock from a 560sel, and as well as my 2 front shock absorbers which are amg and front coil spring all from a 560sel which was parted out here, the ride has become more smoother than stock springs
    300SD Shock Absorber Replacement, Rear Seat Removal Pauls82300SD W126 S,SE,SEC,SEL,SD,SDL Class 15 02-04-2014 09:25 AM
    300SDL: Engine shock absorber mount upper is expensive SDLCrazier W126 S,SE,SEC,SEL,SD,SDL Class 25 07-14-2012 07:27 AM
    How many engine shock absorber should I have? 1972-350SL R/C107 SL/SLC Class 7 07-08-2009 07:55 AM
    My 300SE engine "shock absorber" Carolina28 W126 S,SE,SEC,SEL,SD,SDL Class 6 06-17-2008 10:09 AM
    Shock Absorber Rattles javelintrower W210 E-Class 4 01-31-2007 06:29 AM
