Transmission K1 Piston Spring Repair - Page 5 - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W126 S,SE,SEC,SEL,SD,SDL Class
Old 11-18-2010, 08:50 AM   #41 (permalink)
driftmeister's Avatar
Date registered: May 2008
Vehicle: MB W126 300SEL, MB W124 260E, MB W209 CLK200, Skyline R34 GTT Veilside,
Bowden Cable with ATF leak on 722.3 transmission
Hi guys
Just detected a dripping leak at the plug where the cable is attached to the transmission. It is a new part bought during the rebuilt 2 months ago. Indy tried to put sealant to stop the leak but after driving from work then home only i detected the leak started again. Check the ATF level and it seems overfilled.
Car going back in to the workshop first thing tomorrow morning. Wondering is there a seal or install method required when installing the bowden cable plug?
Transmission K1 Piston Spring Repair-20101118-_1210670.jpg   Transmission K1 Piston Spring Repair-20101118-_1210677.jpg   Transmission K1 Piston Spring Repair-20101118-_1210680.jpg
driftmeister is offline   Reply With Quote
Old 11-19-2010, 08:51 AM   #42 (permalink)
Javman's Avatar
Date registered: Oct 2010
Vehicle: 1983 300sd, 1979 300d
I believe you need this o-ring. I just ordered new bowden cable and o-ring and plan on doing this after I get my new, hopefully working, modulator installed. I have 722.303 tranny
Your Parts Search Returned 1 Part(s)
[SIGPIC]
Javman is offline   Reply With Quote
Old 11-20-2010, 04:48 AM   #43 (permalink)
Premium Member
foolio2's Avatar
Date registered: Oct 2009
Vehicle: 1986 420SEL - 2001 BMW 325xi Wagon
Premium Member
Originally Posted by driftmeister View Post
After putting the ATF 6 litres, which my parts guy told me to buy 6+1 (standby) so i didn't expect it to be slightly overfilled now. Have to re-check again and should i remove some of it? Will the transmission get damaged for overfill?
Detected a leak from the kickdown plug hole at the transmission, not sure why the seal gave way probably due to the new buildup pressure from the K1 spring kit.
Overfilling will most likely not cause immediate, catastrophic damage, but it can lead to the ATF foaming which in turn can cause slippage. I would try to get the level right; especially if you are tinkering with the adjustments to tune the shifting.
1986 Black on Grey 420 SEL (560 Interior Swap)
1986 Smoke on Burgundy 300 SDL - SOLD
foolio2 is offline   Reply With Quote
Old 11-20-2010, 11:45 AM   #44 (permalink)
Thanks guys...sorted out by removing the 1 quart of excess ATF. Probably it was my mistake because i read somewhere that we need 6 quarts for every change of ATF service. Anyway will check whether my O-Ring need to be change, since my rebuilt the bowden cable is new but hope my Indy change the O-ring at the same time.
Update on the K1, reduce flare with upshift of 3000rpm for 2-3. I am happy now since it will upshift when cold start in the morning. Previously it would be like free gear and upshift at 4500-5000rpm. My transmission is a 722.319, after adjusting my bowden cable without any slack...is there any way of reducing the 2-3 upshift at 2500rpm or less?
Old 12-09-2010, 05:33 AM   #45 (permalink)
Date registered: Sep 2006
Originally Posted by tjyak50 View Post
I bought a spare K1 kit from Mercedes of Avondale (Phoenix).
If anybody needs one it is surplus to my needs.
Tj
do you still have the kit
126 270 44 77
I need to do this service on my 95 e320. Flare at 2-3
1989 300CE 125k miles
1997 S320 102k
Sold: 1972 280SE 4.5 153k miles. The car that started my passion for simple, well made automobiles.
lee polowczuk is offline   Reply With Quote
Old 01-11-2011, 07:58 AM   #46 (permalink)
Premium Member
Date registered: Mar 2010
Vehicle: 560SEC
Premium Member
I've decided that I don't like the Mercedes supplied K1 spring.
My flare is long gone, but the 2-3 shift is very soft and lady-like.
Adjusted the modulator to no effect.
Subsequently I removed the K2 spring to amend the 3-4 shift but put it all back without replacing anything. After that the 3-4 shift became more firm.
So I am left with a soft 2-3 shift and a firm 3-4 shift that I cannot adjust away with Modulator adjustments.
Thinking about ordering those aftermarket springs and trying those. Maybe find some new pistons too and replace those.
Any input is appreciated.
TJ
Tom Johnson, Phoenix, Az
1988 560SEC (In family since 1990) / Frontier / 240Z / ZHP Coupe
Hellwig Swaybar / H&R / SLS Damper Mod / FGS / Shadowline
EU bumps pending, Tri-Y bought,
tjyak50 is offline   Reply With Quote
Old 01-12-2011, 09:32 PM   #47 (permalink)
Premium Member
Vehicle: 560SEC
Premium Member
On advice from my Indy Mechanic in Phoenix: David Terry,... I reduced the Modulator pressure a bit and put a teence more preload on the kickdown cable.
That helped delay and soften the harsh 3-4 shift and seemed to make the 2-3 shift more positive.
Will drive for a while and see how it goes.
Normally I only drive the SEC on weekends but its been my daily for the last week while my normal driver (Nissan Frontier) is being used as an aircraft tug...
Tj
Old 02-20-2011, 09:12 PM   #48 (permalink)
rudelover2's Avatar
Date registered: Feb 2007
Vehicle: 1995 S600 Coupe * SOLD
Shift correction package 722.3 / 722.4 Gas Makco Transmission Parts
Seems to have a shift correction kit with various springs.
Could this be a solution to the 1-2 and 3-4 bad shifts/flare
1995 S600 Coupe
rudelover2 is offline   Reply With Quote
Old 02-21-2011, 06:59 AM   #49 (permalink)
Looks like you have to keep recycling your ATF fluid each you the spring is changed....should be worth it if the flare is cured...
Old 02-21-2011, 07:18 AM   #50 (permalink)
scottx's Avatar
Date registered: Apr 2010
Vehicle: 85 190e/8v & 89 420 SEL
Send a message via AIM to scottx
This saved my transmission 7 months ago and it's still shifting good. I think anyone with shifting issues should do it first. (Along with a filter/fluid change)
$8 part saved me from a rebuild.
Professional Mobile Electronics Installer & Fabricator [R]
Champagne Dream - w201.024 - http://www.ChampagneDream.org/
scottx is offline   Reply With Quote
Bookmarks
'03 W211 Wagon Rear Hatch Piston Repair benzwagonfan W211 E-Class 4 10-05-2011 04:17 PM
The B2 piston and my Transmission 86 420 sel W126 S,SE,SEC,SEL,SD,SDL Class 3 11-17-2010 12:27 AM
DIY Mercedes 722.3 722.4 722.5 Transmission K1 Piston Spring Repair Kit Install HATTENATOR W201 190 Class 83 10-27-2010 11:19 AM
b2 piston repair... TOEUP W201 190 Class 5 10-03-2008 12:51 AM
Just replaced B2 piston, K1 spring ... now hard shifting pdxbiodiesel W123 E,CE,D,CD,TD,TE Class 3 05-30-2008 05:41 AM
