SO a few weeks ago I changed the coolant hose that goes into the side of the engine and through the firewall. The model that '84 300SDT that I have has a heated rear windshield so the part has three connecting lines (see photo below)
To make a long story short, I thought that the smaller line that that is through the firewall was leaking so I ordered a new one; however, I now think I might have damaged the line that is BEHIND the steal wall where the green-steal line runs in to. Ugggg...
The question is how do I access behind this wall?
Secondly, I was just adding antifreeze until the new hose that I purchased arrived and NOW I'm leaking coolant out of the water pump. Seriously, pouring out when I parked it at work only minutes ago. What is going on here?
How are these two related? I have an hour commute home, can I make it back with a few gallons of water and just keep adding it along the way? I had the defrost on at full blast; and although it was rising to around 100 degrees it did not pass that thresh hold.
Any and ALL help would be greatly appreciated. This is my daily driver and my wife and I are expecting our first child this weekend so I need to get a handle on this IMMEDIATELY!
Warmly,
Novice@Best
Warmly,
Novice@Best
