s.o.s. Strong vibrations at speed over 80 km/h - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W126 S,SE,SEC,SEL,SD,SDL Class
Old 08-13-2010, 01:45 PM   #1 (permalink)
dan500se's Avatar
Date registered: Jul 2008
Vehicle: `81 W123 280E, `83 W126 280SE, `85 W126 280SE, `91 W126 500SE, `96 W202 C180T
Send a message via Yahoo to dan500se Send a message via Skype™ to dan500se
Since almost two weeks I try to find the solution for a problem that had ruined my holiday.
I was in a new euro-road trip but I got a problem near Vienna and due to that reason I have made the way back home (total of 1300 kms) thinking that I will have a quick and easy repair of my car and I can still make my planned trips.
The problem is a vibration of the whole car ( W126 280SE ) that appears at exactly 80 km/h , aprox. 50 mph, and that vibration getting stronger at 90 km/h is such way that I do not have the nerve to accelerate further that speed.
Over 90 km/h the car seams to disintegrate...The feeling is similar to that of crossing over stairs from a long distance...This is the closest that I can explain to you!
So...What have I done in two weeks:
-change of the tire rod ends ant the central tire rod...the old ones where OK but I have changed them just in case...
-change of the lower ball joint...again, seams OK but changed that too...
-wheel alignment and geometry done
-changing of the front tire with those from the back checking if the front ones are not out of balance...same vibrations
-change of the right side dogbone...(because the bushings into the dogbone seams to have a "play")
-change of the gearbox
-remake of the exhaust system
-change of the tires...inspection of the rims without the tires...all OK
-balance of the wheels...checking the balance of the wheels at an other wheel shop...all OK
-checking of the flex disc from the gearbox/drive shaft...seams good but I will change that too when I will get it ( have to order...)
-checking of the flex disc from the differential/drive shaft...it is good
-checking of the central bearing for the drive shaft...seams good but maybe I will change that too
-checking the engine mounts...seams good but I will change them too
I have made two individual test at two separate locations for the inspection of the suspension of the car and in both places the result were goodand they did not find anything that can be associated with the vibrations that I have described.
After all the thinks that I have made to the car the proble is exactlly the same as before. No improvement at all!
If anyone of you can help me with some advice I will thank you very much!
http://www.youtube.com/watch?v=IUv-D4dgM3Q
1981 Mercedes Benz W123 280E Blue Green Metallic
1983 Mercedes Benz W126 280SE Smoke Silver Metallic
1985 Mercedes Benz W126 280SE Black Blue Metallic * Authority Sales
1991 Mercedes Benz W126 500SE Midnight Dark Blue * Last Edition / Reiserechner
1996 Mercedes Benz W202 C180T Tourmaline Green Metallic * Elegance
dan500se is offline   Reply With Quote
Old 08-13-2010, 03:57 PM   #2 (permalink)
Firewater's Avatar
Date registered: Jan 2009
Vehicle: 1985 500 SEC EURO AMG/LORINSER; 1988 560SEL
Send a message via AIM to Firewater
How is the condition of your tires? any broken bands?
Why not take it to a mechanic to have him diagnose it?
Sweeeeet car by the way.
LUBE YOUR THROTTLE LINKAGES!
ebaY: IrishConfetti
1985 Mercedes-Benz 500 SEC EURO AMG/LORINSER
1988 Mercedes-Benz 560 SEL
Firewater is offline   Reply With Quote
Old 08-13-2010, 04:24 PM   #3 (permalink)
Abdullah2009's Avatar
Date registered: Apr 2009
Vehicle: Mercedes-Benz 560SEL mod 91,MB 560SEL mod 90
There are alot of things that cause such vibration : rings, tires, axles, drive shaft, drive shaft central bearing, flex disc etc......
How did you get this problem, just all of a sudden? or is there some thing went wrong before that? You may not need all what is being done so far.
Most of the vibration comes from the rings and tires, check and/or do tires balancing, also take a look at the diff mounting bolts with its rubbers.
The open-minded see the truth in different things: the narrow-minded see only the differences.~ Author Unknown
Abdullah2009 is offline   Reply With Quote
Old 08-14-2010, 01:14 AM   #4 (permalink)
dan500se's Avatar
As I said in my first post the tires are new and even the rims were checked...and the balance of the wheel was double checked in two places.
...Why not take it to a mechanic to have him diagnose it?
I was with the car at a few mechanics...(I did not made the jobs that I described in my first posts...the mechanics did). I have speak with the representant from Mercedes Romania, the chief engineer of mechanics, but even him did not give me a good tip that resolve this annoying problem.
The car was put to tests in two "stands" and everything was just perfect. I have made the shock`s test and they were all good. At first test the difference between the shocks were 1% in the front and 2% in the back. Just the efficiency was a bit low :50-51% front and 37-39% rear.(I have attached a scan of the test results)
At the second test in a new location the efficiency of the shocks was an average of 75%.
Originally Posted by Abdullah2009 View Post
There are a lot of things that cause such vibration : rings, tires, axles, drive shaft, drive shaft central bearing, flex disc etc...
You are right! There can be numerous reasons and I (or the mechanic) have tried all of that: rings, tires, axles, drive shaft, drive shaft central bearing, flex disc...and even more: engine mounts, gearbox mount, shocks, undercarriage, etc.
Just that there is something that is slipping to us or the checks were not good enough to find a problem.
...How did you get this problem, just all of a sudden? or is there some thing went wrong before that?...
To be precise: I have hit a pretty big hole in the road in Hungary at 90-95 km/h the day before...but after that I have made a few hundred kms on the highway without problems. The vibration had started when I have arrived near Vienna and the highway started to get bad, made from concrete and with uneven joining of the surface. It was the place where the vibrations started!
The strange thing is that if I go in bad roads the vibrations are not present, or they are overwhelm by the moving of the car`s body.
In the way back home, in Hungary-where the particularly bad roads are present everywhere, I did have no problem going even with 100 km/h.
Only when the road is smooth the vibration is feeling so strong that the car shake violently.
...Most of the vibration comes from the rings and tires, check and/or do tires balancing, also take a look at the diff mounting bolts with its rubbers.
All of this were checked and declared OK!
Absolutely right! Nothing has changed since I have made those changes...
s.o.s. Strong vibrations at speed over 80 km/h-hwscan00111.jpg
Old 08-14-2010, 01:21 AM   #5 (permalink)
slightly creased
420 SE's Avatar
Date registered: Sep 2005
Vehicle: 1988 420 SE
is it possible there is a problem in the steering box? IDK, I'm just putting it out there because you seem to have tried just about everything else....
Ross
OzBenz
beware of fundamentalists
420 SE is offline   Reply With Quote
Old 08-14-2010, 01:40 AM   #6 (permalink)
dan500se's Avatar
Steering box was checked and it was find a minor play...but declared unsuficient to cause this kind of problems.
In my search on the Internet I have find a site where somebody had a similar problem and it was recommended to him to make the 9/12 hour test. Maybe you have heard of that...Must grad the steering wheel with left hand at 9 hour and right hand at 12 hour. With the right index finger raised you observe the moving...It the index finger is moving left/right is a problem with the direction system and if is is moving up/down is something unbalanced (wheel in particular...not my case do...) or transmission system...
In my car after that 9/12 test the finger is moving shorth up and down...
Old 08-14-2010, 01:47 AM   #7 (permalink)
slightly creased
420 SE's Avatar
can you get it onto a dyno and check out more closely where the vibration is coming from under traction conditions (dangerous I know).
Old 08-14-2010, 02:06 AM   #8 (permalink)
dan500se's Avatar
Yesterday evening we have made a test...a home made dyno...
We raised the back of the car, rear wheels on the air and accelerated and decelerated...0-60 km/h, 0-80 km/h, 0-90km/h and the last time even to 180 km/h (110 mph) at 6000 rpm. Everything was OK...No vibration whatsoever! The car was raise over a "channel", so we have access under and we can observe everything from there. Drive shaft moving even, flex disc are spinning round without jumps.
Seams like the vibration are present or on the front of the car or they appear only when the car is "in trust" ... or sitting on the road. In the air everything is good!
Old 08-14-2010, 02:23 AM   #9 (permalink)
slightly creased
420 SE's Avatar
is it possible, that when you hit the hole, you have broken a part of the chassis and are getting some body flex at speed?
Old 08-14-2010, 02:31 AM   #10 (permalink)
dan500se's Avatar
...you have broken a part of the chassis and are getting some body flex at speed?
We have checked and nothing seams to be deteriorated... I have received an advice that i should change the left side arm that is maybe bent when I have hit the hole. But I`m assuming that when I have made the geometry this should be coming out from the tests. If it is required I`ll will do that too...
Bookmarks
She just went from a strong 7 ogrenutz Off-Topic 8 04-03-2010 05:09 PM
Is this really that strong? tjobeid R129 SL Class 1 07-07-2007 09:40 PM
Be strong yoseyman Off-Topic 2 04-02-2007 04:32 PM
Too Strong Zé Bocaina G-Class 0 02-05-2007 07:53 AM
