Driver door-activated courtesy interior light not working... - Page 2 - Mercedes-Benz Forum
post #11 of 46 (permalink) Old 08-25-2010, 08:16 AM
liammarsh's Avatar
Date registered: Apr 2009
Vehicle: 1981 300SD Biodiesel
Originally Posted by 420 SE View Post
well if the problem only occurred following work a shop did to your car, I would be returning to them and having them sort their problem out...
+1, though that doesn't always go the way you hope it will. Yes, there are just two wires going to this switch and three on the other ones. Schematic attached. The ground side of the switch connects behind the instrument cluster and the warning module is to the left of the steering wheel behind the lower dash cover.
liammarsh is offline
post #12 of 46 (permalink) Old 08-26-2010, 01:04 PM Thread Starter
Vehicle: 1991 350SD
Thanks... I'll have a look!
n/m
AtlGator is offline
post #13 of 46 (permalink) Old 08-26-2010, 02:14 PM
Grumpy560's Avatar
Date registered: Aug 2009
Vehicle: 1989 560SEL W126, 1989 ford ranger
Have you tried the dome lamp control relay in the fuse box. correct me if I am wrong but the dome light is actually on a timer activated by both front doors. however the door courtesy lights are not. I believe the rear doors only activate the rear dome light and the courtesy lights seperately. so you say the front passenger door will activate the front dome lamp but not the driver door. try this out for kicks. when you open the passenger side front door and then close it, does the dome light stay on for a few seconds? or does it go out instantly? if it goes out instantly I would suspect the dome lamp control relay.
Grumpy560 is offline
post #14 of 46 (permalink) Old 08-26-2010, 02:22 PM Thread Starter
Vehicle: 1991 350SD
Thanks -- was hoping for that, too! But the passenger door opening/closing resulted in the overhead front light staying illuminated for a few seconds as you said it does. Thanks for chiming in...
AtlGator is offline
post #15 of 46 (permalink) Old 08-26-2010, 02:51 PM
Grumpy560's Avatar
You are welcome. However I just went back and re-read the first post and this statement caught my attention. you said that you removed the driver side door jam switch and completed the circuit by connecting the 2 wires together right? if you did that, well its not going to work. you need to ground each individual wire to a ground source. the switch could be at fault here. or you could simply swap the switch with one from another door, or have you tried this by now?
post #16 of 46 (permalink) Old 08-26-2010, 03:38 PM Thread Starter
Vehicle: 1991 350SD
Yeah, tried switching out switches - didn't work but thanks. n/m
n/m
AtlGator is offline
post #17 of 46 (permalink) Old 08-26-2010, 08:29 PM
Date registered: Oct 2009
Vehicle: '88 560sec (180k mi.), '82 380sec (236k mi.), '86 560sec (?miles)
Ive had a similar problem for a while now, but a little different. My dome light wont work when either doors are opened, (for my SEC). My buzzer works, but only when door opened while headlights left on/key left in...(not sure if this is how it's supposed to be?) Although I just realized my puddle light on my passenger door doesnt work, as ive swapped from my drivers side and it must be wiring. I read the post about the "dome lamp timer relay" in the fuse box. Where is this relay? Ive searched and read every thread on dome lights already. Im getting a lil sleepy from reading Sorry if this is an obvious question....
JW560sec is offline
post #18 of 46 (permalink) Old 09-01-2010, 01:59 PM
Date registered: May 2010
Vehicle: 1991 Mercedes-Benz 420SEL White, 122k
This is interesting... I have the same problem also. Exactly as how this thread describes it. However I swapped the switches from the other doors to the driver's side, and no go. However, if I open any of the three other doors, all the lights illuminate. I haven't pursued it any further, but I'm not much of a whiz with electricity (sorcery if you ask me).
1991 420SEL 122k.
1985 BMW M535i (grey market)
1990 SAAB 900 SPG
1989 Toyota 4-Runner 4WD
AGBullit235 is offline
post #19 of 46 (permalink) Old 09-01-2010, 02:39 PM
Date registered: Oct 2008
Vehicle: '89 420SEL, '93 300E and '07 Hyu Santa Fe
Quoted: 11 Post(s)
Well, I don't know if you already tried but last time my 300E went to shop and came back my dome light was not working while opening door but it would work when i close door at all times. As I didn't even know where that switch may be i looked at door how its opening and closing and show a switch.
I pulled switch out, show two wires going, swap them and operation was back to normal.
Since your light does not come on when inside car i will rule out this situation but hopefully some newbi like me may be helpful knowing this in future.
'93 300E 2.8, Green (205K...)
'07 Santa Fe SE, Natural khaki (95K..)
'04 S500 (122k..)
'89 420SEL, Diamond Blue (154K..) Retired
'08 kawi 250R, Red (10K..) (Sold)
MBCarGuy007 is offline
post #20 of 46 (permalink) Old 09-01-2010, 06:06 PM
liammarsh's Avatar
Next step, test ground. Pull out switch, disconnect ground wire. Connect a test wire from the switch where you removed the ground wire to another ground location. You can use where the battery is grounded or pull off the lower dash carpet cover beneath the steering wheel and look for a ground location up in there. If the light works, you have a ground short. If not run the test ground to the other side of the switch (bypassing the switch). If that doesn't work move on to the warning module.
    Dome light not working when driver door is opened. spicyguy2005 W126 S,SE,SEC,SEL,SD,SDL Class 40 08-18-2012 05:27 PM
    Interior courtesy light / door open switch aa00676 V-Class 1 03-02-2010 12:19 PM
    Where to find a driver side courtesy light? schlitz100 R/C107 SL/SLC Class 7 06-11-2009 01:32 PM
    Driver door does not oprate interior light Ken D W126 S,SE,SEC,SEL,SD,SDL Class 8 11-16-2007 04:59 PM
    interior Light comes on when i lean on driver door pm300d W210 E-Class 3 08-12-2005 10:04 AM
