BROKEN OIL CAP - PLEASE HELP!!! - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-03-2010, 07:53 AM Thread Starter
Date registered: Apr 2009
Vehicle: 1988 560SEL
I have a unique problem. This morning I was going to add some oil to my w126and the plastic cap broke. The top of it broke off but the cap part stayed on the engine. I have no idea how to get it off now. I was wondering if this has happened to anyone else. Also, my car is really low on oil and needs some added desperately. Will it cause any problems if I add oil through the dipstick? Any feedback is much appreciated and will be commended.
jdg15 is offline
post #2 of 4 (permalink) Old 06-03-2010, 08:13 AM
Date registered: Jun 2009
Vehicle: 1989 500SEC
adding through the dipstick should be ok, is there no way you can grip whats left of the cap with some pliers? Other than that you might have to take off the valve cover and smash out the broken cap, that would be a bit drastic though.
1992 190E 2 Litre
1989 500SEC
khimani_mohiki is offline
post #3 of 4 (permalink) Old 06-03-2010, 09:09 AM Thread Starter
Yeah i tried that but the problem is that the part that is left is also made of plastic, so when using pliers it just breaks off. i mite try a wrench this afternoon and try to grip around the edges. i was pretty surpised by the cheapness of the cap, not usual for a mercedes product.
jdg15 is offline
post #4 of 4 (permalink) Old 06-03-2010, 10:04 AM
be careful it doesnt break and fall inside your timing cover
1992 190E 2 Litre
1989 500SEC
    '98 320CLK Oil Fill Cap broken 320CLK C208/A208 CLK-Class 0 04-26-2010 01:17 PM
    Oil Filer Cap Leak - Not a Probelm of Cap stojakovic W201 190-Class 2 10-04-2009 10:47 AM
    W211 E350 Leaking Oil from Oil Filler Cap falcon1960 W211 E-Class 4 04-02-2009 11:56 PM
    Easy oil change w/ MityVac... except I forgot to put the oil cap back on- oye HACK THT W163 M-Class 0 05-03-2007 10:23 AM
    broken oil cap and melted hose Carlo$ R129 SL-Class 2 10-18-2005 10:07 AM
