88' 300 SE in need of help once again... Thanks in advance - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-13-2010, 08:20 AM Thread Starter
Premium Member
LordNikonXTC's Avatar
Date registered: Feb 2005
Vehicle: 1988 300 SE
Premium Member
Send a message via AIM to LordNikonXTC Send a message via MSN to LordNikonXTC Send a message via Yahoo to LordNikonXTC
Red face 88' 300 SE in need of help once again... Thanks in advance
Hello Benz lovers, it is me once again… I have a 1988 300 SE with about 310,000 miles on it. I have a couple of weird things that have taken me for a flip. Hope you guys can help me.
1st… Transmission. It seems recently that my transmission is having difficulty shifting into forth gear. Sometimes it will not shift into forth and there was once incident where it shifted from forth to third gear. Any suggestions? I am about to do a filter and oil change but is there an underline issue that I may cake a gander at?
2nd… Usually from a cold start, there are times when the car has difficult running at idle. First start. After that it runs great. Sometimes I don’t have a problem with it at all in the morning. It starts right up. Other times it will start and give me a rough idle for a few then I am good to go. I have changed the filter, I have good pressure, what could it be?
Looking forward to the advice. If you want you could call me at 843-647-3320. Lester… thanks….
LordNikonXTC is offline
post #2 of 2 (permalink) Old 05-13-2010, 08:16 PM
jdc1244's Avatar
Date registered: Jun 2003
Vehicle: 1991 300 SE
The ATF and filter change may address the problem; if it persists check for vacuum leaks.
Cap/rotor, plugs/wires last changed when? Good fuel pressure or compression? How many miles on the fuel pump?
jdc1244 is offline
    Need parts 88' 190e AC2 W201 190-Class 1 10-14-2008 04:43 PM
    88' 300 SEL Update ColonelRemus W126 S,SE,SEC,SEL,SD,SDL Class 6 10-08-2008 05:38 AM
    88' 300 TE warning indicators DavidMichael W124 E,CE,D,TD Class 4 06-13-2007 08:03 PM
    88' 300e worth it...??? vwbuge W124 E,CE,D,TD Class 7 07-12-2005 08:35 AM
