Fast blinking turn signal + dash burned bulb indicator on - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 05-06-2010, 03:13 PM Thread Starter
mansito's Avatar
Date registered: May 2004
Vehicle: 89 300SE
When I move the turn signal lever down (making a left turn) the left arrow on the dash blinks very fast. In addition the dash burned bulb indicator comes on. I checked the front and rear bulbs, they were good (not burned), they both blink.
Anyway, I went ahead and replaced the front turn signal bulb, and all the bulbs in the rear left cluster (turn signal, stop light, regular night light). I did not replace the reverse light bulb. I also sanded the contact points for all the bulbs.
Still, the left arrow on the dash blinks very fast and the dash burned bulb indicator comes on.
Any suggestions on where should I look next?
Guido
89 300SE, 109K miles
72 250C, 70K miles
05 Lexus GX470, 75K miles
08 Honda S2000, 11K miles
mansito is offline
post #2 of 11 (permalink) Old 05-06-2010, 03:17 PM
jporter16's Avatar
Date registered: Jan 2009
Vehicle: 1982 300SD, 2001 f-150 4x4-348,000 passed tha benz!!
Make sure the light bulb bases are clean, this can cause it, also check the turn signal relay.
jporter16 is offline
post #3 of 11 (permalink) Old 05-06-2010, 03:29 PM Thread Starter
mansito's Avatar
Vehicle: 89 300SE
I lightly sanded the sockets. I installed new bulbs, I assumed they are clean. But I'll go out an clean them. Where is the turn signal relay located?
Thank you.
Guido
72 250C, 70K miles
mansito is offline
post #4 of 11 (permalink) Old 05-06-2010, 06:38 PM
liammarsh's Avatar
Date registered: Apr 2009
Vehicle: 1981 300 SD, 1994 C280, 1990 560 SEC
Turn signal relay in fuse/relay box relay B. Wiper motor runs off the same relay. If your wipers are messed up too then definitely the relay.
liammarsh is offline
post #5 of 11 (permalink) Old 05-06-2010, 06:45 PM
liammarsh's Avatar
Assuming right turn works fine? What happens when you turn on the hazards?
post #6 of 11 (permalink) Old 05-07-2010, 12:37 AM
Denver's Avatar
Date registered: Jun 2007
Vehicle: 380 sel
Pop the trunk, signal left...flashing fast???.... Now Fiddle/manouver the entire light housing on the left. Lift up/pull away from the body etc. Earthing probs me thinks.
Denver is offline
post #7 of 11 (permalink) Old 05-07-2010, 04:20 AM Thread Starter
mansito's Avatar
Vehicle: 89 300SE
right turn works fine. Hazards work fine. Wipers work fine. Only problem is the left turn flashes very fast. I failed NJ inspection because the left and right turn signals do not flash at the same interval.
Guido
72 250C, 70K miles
mansito is offline
post #8 of 11 (permalink) Old 05-07-2010, 04:22 AM Thread Starter
mansito's Avatar
Vehicle: 89 300SE
I read on another post that the turn signal relay is located behind the instrument cluster. My car is an 89 300SE. Did they change the location?
Guido
72 250C, 70K miles
mansito is offline
post #9 of 11 (permalink) Old 05-07-2010, 04:23 AM Thread Starter
mansito's Avatar
Vehicle: 89 300SE
I'll work on finding ground problems over the weekend.
Thanks,
Guido
72 250C, 70K miles
mansito is offline
post #10 of 11 (permalink) Old 05-07-2010, 10:53 PM
Date registered: Sep 2007
Vehicle: 90 420SEL 240,000 miles strong
Send a message via AIM to RickASolis
I once had a problem with a marker lamp that would never work, even with replacing the bulb. I replaced a large relay (its real long, biggest one in the fuse box. I think all the outside lights at one point make their way through that relay) and the marker light magically came back on. This may have something to do with it as well.
Get your timing chain and rails done like you should. I would know more than anyone!! The noise it makes when it goes will make you cry.
RickASolis is offline
Turn Signal Light Fast Blinking???? Haroundb W140 S-Class 4 04-06-2010 09:31 PM
Turn signal not blinking Oake W126 S,SE,SEC,SEL,SD,SDL Class 3 12-22-2008 06:47 AM
Fixed my fast-blinking turn signal; plus need help identifying a part. Brian_R170 R170 SLK-Class 5 01-30-2004 09:12 AM
Passenger side turn signal blinking fast when headlights are on? Brian_R170 R170 SLK-Class 5 01-27-2004 09:34 AM
How to remove the side turn-signal to replace a burned-out bulb? Bob W163 M-Class 4 09-24-2001 04:57 PM
