1984 500SEL broken hood release? - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 04-16-2010, 11:58 AM Thread Starter
Date registered: Dec 2008
Vehicle: 1995 C280
Send a message via AIM to Zak62592
so unfortunately this old dinosaur doesn't run as well as it should. I would like to change the spark plugs/change air filter.. but unfortunately the hood latch inside the car is gone! the only thing left is this black cable, and pulling on it with pliers does not help. Is this a common problem and is there any other way to open the hood?
Zak62592 is offline
post #2 of 10 (permalink) Old 04-16-2010, 02:01 PM
srsomasundaram's Avatar
Date registered: Feb 2006
Vehicle: 1983 300SD,2002 ML500,(MBCA Member)
Send a message via Yahoo to srsomasundaram Send a message via Skype™ to srsomasundaram
I think, pulling it with nose pliers, is about the only way you can open the hood....
I have had this experience and was able to open it with a pliers.....
Good Luck!
Soma
Soma
1983 300SD (250K Miles) ==>Astral Silver on Black MB Tex;
2002 ML500 (120K Miles) ==>Silver on Black Leather Interior:Sport Pkg;
srsomasundaram is offline
post #3 of 10 (permalink) Old 04-16-2010, 06:46 PM
Date registered: Jan 2004
Quoted: 2 Post(s)
It helps (or maybe is the only way) to pull on the steel cable while keeping the plastic sheath from moving. Obviously fix it if you get it open
NordRhein is offline
post #4 of 10 (permalink) Old 04-17-2010, 02:33 AM
Hypnotismo's Avatar
Date registered: Feb 2010
Vehicle: Sold, in the market.
I had a similar problem. If I remember right, pliers worked... was just rediculously tough for some reason!
1994 SL500 R129 (Silver/Blue Leather) _I am really the only one that drives it anymore. --FOR SALE!
2001 E320 Estate (Silver/Ash Leather) _Mother's
1988 260E Custom Sound System, tint, and cheapy paint job, so many memories! - SOLD
1986 420SEL - RIP 1/29/11
http://www.youtube.com/watch?v=xViYiPH9R9Y
http://www.youtube.com/watch?v=cGgNhzl4fr4
Hypnotismo is offline
post #5 of 10 (permalink) Old 04-17-2010, 05:31 AM Thread Starter
Vehicle: 1995 C280
i think i used my super powers too hard and it seemed to pull the cable even further.. hahaha
you would hear a click inside the hood when you would pull the cable but it never opened it, now that the cable is pulled out all the way, nothing is happening.
Zak62592 is offline
post #6 of 10 (permalink) Old 04-17-2010, 01:10 PM
Hypnotismo's Avatar
OOH thats good! when you hear that click go to the front and look at the grille. There should be a small tab sticking out of it. Pull that out a bit and hold as you use another hand to open the hood
post #7 of 10 (permalink) Old 04-24-2010, 06:24 AM Thread Starter
Vehicle: 1995 C280
I know what you mean by that... But it was like the hood was trying to open but no matter how hard i pulled, it didn't happen. i'm afraid i pulled on the plastic wire too hard and the actual cable inside the wire is somewhere in there. Is there any other way to do it??
Zak62592 is offline
post #8 of 10 (permalink) Old 04-24-2010, 10:42 AM
Premium Member
foolio2's Avatar
Date registered: Oct 2009
Vehicle: 1986 420SEL - 2001 BMW 325xiT - 2013 BMW M3
Premium Member
While you are pulling the wire, have someone else pushing on the hood to see if that releases some of the tension on the cable. My hood pull handle broke off too and as other posters described, you must must pull extremely hard to open it with just the cable and pliers. That little handle really multiplies your leverage. Alternatively, that little handle is only line 7 or 8 bucks. Replace it and see if that works. Then, make sure you really lubricate the "catches" that lock the hood down. Mine is like new now after a new handle and a good lube job. I also messed with the tension nut on the cable to tighten it up a bit.
1986 Black on Grey 420 SEL (560 Interior Swap)
1986 Smoke on Burgundy 300 SDL - SOLD
foolio2 is offline
post #9 of 10 (permalink) Old 04-26-2010, 02:12 PM Thread Starter
Vehicle: 1995 C280
Thanks for the advice... but like I said before.. I pulled too hard and it seemed like the cable got extended somehow, and I don't see the threaded wire that was there before anymore, and whenever I pull on the cable, nothing happens, not even a sound that sounds like the latch is trying to open
Zak62592 is offline
post #10 of 10 (permalink) Old 04-26-2010, 03:38 PM
Premium Member
foolio2's Avatar
Premium Member
I see what you are saying now. Maybe if you have long skinny arms you can reach up under the front bumper to release the catches by hand or with a hook of some type?
foolio2 is offline
Hood Release Broken in 1997 SL MACSL R129 SL-Class 4 01-17-2010 09:59 AM
Anyone know how to remove the hood when the release latch inside the car is broken alabbasi W126 S,SE,SEC,SEL,SD,SDL Class 4 01-16-2010 03:44 PM
Broken hood release cable Dik W123 E,CE,D,CD,TD,TE Class 2 01-12-2010 10:42 AM
Plan B for broken hood release handle texholdem W210 E-Class 2 10-18-2009 06:34 PM
Air control lamp and hood release lever both broken luiscorrea1 W210 E-Class 1 08-02-2004 04:32 PM
