Lost/ spongy brakes 280se 1983 - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 04-12-2010, 09:23 AM Thread Starter
Date registered: Oct 2009
Vehicle: 280 SE 1983 Gold Ambassador Pimp
Hi,
I have a 280 se 126 1983 model. Brakes have become really spongy (can push right to floor) there is no loss of fluid in the res. so i was just wondering how to test to see if it is a fault with the brake booster or the master cylinder..? Brake lines have no air in them- have been checked/ bled/ so am assuming the fault is up near the mastercylinder or b/booseter..
thanks in advance for your help. It is my first Mercedes and I have never driven anything like (I feel like a South African Diplomat) it so I really want to get this car back on the road.
cusackotg is offline
post #2 of 6 (permalink) Old 04-12-2010, 09:59 AM
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6.
Quoted: 1084 Post(s)
Originally Posted by cusackotg View Post
Hi,
In the meantime..
Welcome to the forum.
The forum archive has a wealth of information available at your finger tips.
The search function accepts 2 words of at least 3 letters.
For all available resources / forum features / 'how to' navigate the forum etc, please make sure to carefully read the 'Welcome to the Forum' announcement / tutorial sticky on top of the W126 page.
There are also the Google special search box on top of our forum page, or the 'everythingmercedes' search (check the tutorial links).
Both short cuts will lead to the same relevant threads.
Cheers
Teutone is offline
post #3 of 6 (permalink) Old 04-12-2010, 10:00 AM
Firewater's Avatar
Date registered: Jan 2009
Vehicle: 1985 500 SEC EURO AMG/LORINSER; 1988 560SEL, 1995 S500 Sonderschutz
Quoted: 179 Post(s)
Can you pump the brake up to be firm or is it to the floor every time? Have you checked the pads?
LUBE YOUR THROTTLE LINKAGES!
"A little neglect may breed mischief: for want of a nail the shoe was lost; for want of a shoe the horse was lost; and for want of a horse the rider was lost." -Benjamin Franklin
Firewater is offline
post #4 of 6 (permalink) Old 04-13-2010, 05:15 PM
Date registered: May 2009
You could call X to the Z Xibit to pimp your brakes....
Or bleed your brakes and check that your master cylinder is in good shape otherwise you will have to replace it.
GQROD is offline
post #5 of 6 (permalink) Old 04-13-2010, 05:47 PM
akimball442's Avatar
Date registered: Nov 2007
Vehicle: '73 450SL, '83 300CD, '01 E320 4matic
Quoted: 9 Post(s)
same thing happened to my 300SE a few months ago- the rear calipers were leaking quite badly upon close inspection, I replaced them and the problem is solved. They're relatively inexpensive. Check them out!
Pull your vacuum line off the booster. Commonly you will find brake fluid in there if your master cylinder is leaking.
-Aaron
ASE Master tech, specializing in electronics and driveability.
Certified Diesel Master tech.
EPA 609 certified
2001 E320 - 4matic - daily driver
1973 450SL - 191K - Summer Toy
1983 300CD -170K
1989 300SE - on to the next owner
1981 Coupe DeVille.. just because.
1983 Chevy Suburban Diesel... workhorse.
... and many more past and present...
Because Safety is not a luxury. Mercedes-Benz. Engineered like no other car in the world.
akimball442 is offline
post #6 of 6 (permalink) Old 04-18-2010, 01:06 AM Thread Starter
Sorry for the late reply guys- have been on holidays.... I can pump the brake up to be firm- it's not on the floor all the time. i am going to check the pads and the vacuum hose like the other 2 members have advised and get back to you.
cheers
V280 SPONGY BRAKES socket V-Class 6 03-26-2008 09:35 AM
Spongy brakes on my S320-1997 w140benz W140 S-Class 11 02-26-2007 11:33 AM
METAL SQUEAK AND SPONGY BRAKES aggarao G-Class 15 05-03-2006 12:27 PM
Spongy Brakes BAZMAN R171 SLK-Class 4 09-21-2005 06:01 PM
spongy brakes? Gkase G-Class 4 11-22-2004 04:02 PM
