help! dash lights wont work with headlights - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 11-23-2009, 03:08 PM Thread Starter
900$sel's Avatar
Date registered: Apr 2009
Vehicle: 1988 Mercedes Benz 420SEL 258,000 miles (SOLD) 1991 300se 168,000 miles, ASR 1999 GMC Yukon 192,000
Exclamation help! dash lights wont work with headlights
checked fuses 6 and 11, not the problem, all lights seem to work fine just then i turn on the head lights the cabin remains dark..
any advice would be welcome
Thanks,
Troy
]"I'm not getting into that Nazi sled." [/B]
900$sel is offline
post #2 of 6 (permalink) Old 11-23-2009, 03:13 PM
ElRojo's Avatar
Date registered: Jul 2005
Vehicle: 1993 300TE, 1995 E320 Wagon
First thing I'd check is the rheostat /dimmer behind the instrument cluster. These often fail with age-- you can try to rebuild it (it's not too tough), or get one from a JY car (I have a couple to spare too). Just pull the cluster and take off the dimmer from the lower left side (where the dimmer adjustment wheel is).
Best--
1993 300TE, 252K, "Beryl"; Teal blue (888) on cream beige MBtex (175).
1995 E320 Wagon, 190K "Ruby"; Garnet red (512) on cream beige leather (265).
1990 560 SEL, 190K "Ingrid"; Smoke silver (702) on Cream beige leather (265). SOLD
1983 300SD, 106K "Hans"; Orient Red (501) on Java MB tex (154). SOLD
ElRojo is offline
post #3 of 6 (permalink) Old 11-23-2009, 03:47 PM
SIMONVW126's Avatar
Date registered: Feb 2008
Vehicle: 2005 Mercedes-Benz SLK350 Sport Package, 1984 Mercedes-Benz 500sel US Spec
Now that we are on this topic... I repacled mine with an original from another car. This one seems to be made of ceramic and has a spring.
I recently removed one from a 1991 50sel and looks more modern... it's made of metal and plastic. I don't think it has a spring.
Do these fail as much as the originals?
1984 Mercedes-Benz 500SEL US SPEC (114,000 miles)
2005 Mercedes-Benz SLK350 Sport Package (16,000 miles)
SIMONVW126 is offline
post #4 of 6 (permalink) Old 11-23-2009, 04:50 PM
mclare's Avatar
Date registered: Aug 2008
Vehicle: 2012 CL550 4MATIC Coupe
Quoted: 252 Post(s)
Send a message via Yahoo to mclare Send a message via Skype™ to mclare
Best--
Dave is 100% correct here and I only want to add one thing. There are two different (at least that I have found) types of dimmers. There are Ceramic and plastic, and there is also a two pin and a three pin one. My 91 SEC has the three pin one and Mapearso's '89 and Aroundthescenes '86 had the two pin one.
I believe the plastic is the three pin, though I would need to check it again. I also have them if Dave does not have a matching one, though I am sure he does.
Current Stable:
1990-560 SEL - Sedan - 199/261 - Stock. Euro Headlampd & Wipers FOR SALE. - PM ME
Past cars:
1991-560 SEC AMG - Coupe - 199/261 - 300 HP Custom Built Motor - Highly Modified Coupe.
1987 560 SEC Black/Tan
mclare is offline
post #5 of 6 (permalink) Old 11-23-2009, 05:05 PM
slightly creased
420 SE's Avatar
Date registered: Sep 2005
Vehicle: 1988 420 SE; 2015 ML 400
Quoted: 145 Post(s)
mclare, you are correct, plastic 3 pin, ceramic 2 pin and not easily interchangeable.
Ross
OzBenz
beware of fundamentalists
420 SE is offline
post #6 of 6 (permalink) Old 11-24-2009, 01:00 PM Thread Starter
900$sel's Avatar
thanks for the help guys just when you think you know everything about these cars you learn somthing else
i had no idea that the car even had a rheostat...
900$sel is offline
dash lights do not work Derekb3 W123 E,CE,D,CD,TD,TE Class 8 09-20-2009 10:44 AM
2001 ML320- Dash lights come on but engine wont crank? (intermittent) tonykari W163 M-Class 5 09-03-2009 11:51 AM
Dash Lights, Tach, etc. Do not work??? Beebeeper R/C107 SL/SLC Class 9 01-06-2008 12:09 PM
Dash lights and windows don't work kburks1230 R/C107 SL/SLC Class 31 07-07-2007 07:37 AM
Reverse lights wont work help please sonhoang C208/A208 CLK-Class 1 11-24-2006 02:31 PM
