Alternator Wires - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 11-01-2009, 10:11 AM Thread Starter
Date registered: Oct 2009
Vehicle: 1981 300SD Turbo Diesel, 1979 MGB, 2005 Buick LeSabre, 199? Geo Metro, X2 Suzuki Intruders
Alternator Wires
My alternator belt was looser than I would like (read squeals it is so loose) when I picked up the car today.
I tried to adjust the tension but had a difficult time putting enough tension on the belts. I like the double belts, great idea actually, but what (where) is the preferred tensioning lever point for adjusting the alternator?
Also, the PO had clipped the plug from the alternator harness wires and attached three spade terminals to the wires. This poses a few problems for me. One, they are not insulated and could feasibly contact the alternator housing causing a short. I assume I will heat shrink something over them as soon as item two below is figured out...
Two, they are not differentiated so I do not know which terminal goes to which wire except that there is a small lug and two large lugs.
When I started working on the alternator the wires popped off (didn't expect that! ) and I did not know which wire was which. Educated first guess got me running again but I would like to know they are correct!
Which wire goes to which of the three terminals?
The "little" terminal is obvious, the other two are both "hot" all the time.
Cap'nVideo is offline
post #2 of 9 (permalink) Old 11-01-2009, 11:09 AM
Rmac58's Avatar
Date registered: Nov 2007
Vehicle: 2013 MINI Copper S Clubman, '84 300CD-weekend car
Quoted: 139 Post(s)
I posted a pic of the jump box on the 123 forum.
'13 MINI Cooper Clubman S-daily driver
'84 CD-weekender!
Rmac58 is offline
post #3 of 9 (permalink) Old 11-01-2009, 05:49 PM Thread Starter
Yes you did, I appreciate it but it does not tell me which wire goes to which terminal at the alternator or are their positions on the alternator interchangable?
post #4 of 9 (permalink) Old 11-01-2009, 11:15 PM
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6.
Quoted: 990 Post(s)
The forum archive has a wealth of information available at your finger tips.
The search function accepts 2 words of at least 3 letters.
For all available resources / forum features / 'how to' navigate the forum etc, please make sure to carefully read the 'Welcome to the Forum' announcement / tutorial on top
Cheers
File Type: pdf 15-600 testing alternator regualtor in vehicle.pdf (147.8 KB, 128 views)
Teutone is offline
post #5 of 9 (permalink) Old 11-02-2009, 07:38 PM Thread Starter
Thank you for your input Teutone.
I do not need an "Alternator Testing Procedure" PDF file.
Do you plan on providing the information I requested?
RMAC I hope you can get under the car and let me know, I truly appreciate your efforts.
post #6 of 9 (permalink) Old 11-02-2009, 08:45 PM
MrBits's Avatar
Date registered: Apr 2008
Vehicle: '87 560SEC: '86 AMG 560SEC: '87 560SEL - PAST: Heckflosse 190 & 230S
Lightbulb Say what?
RMAC I hope you can get under the car and let me know..
Did Rmac58 say he'd do that?. Why not crawl under your car to take photos that document your question.
MrBits is offline
post #7 of 9 (permalink) Old 11-02-2009, 09:41 PM
AzimuthAviation's Avatar
Date registered: Apr 2006
Vehicle: 1982 380SE AMG euro(parted out),1983 300SD "Good Girl", 1984 500SEL AMG euro "Bad Girl"
Hmmmm..... I'll give some benefit of doubt that you're really not aware how your responses came across.
The two large wires are common to each other and are tied together further away going toward other systems. It doesn't matter which terminal they connect to.
AzimuthAviation is offline
post #8 of 9 (permalink) Old 11-03-2009, 05:59 AM
Rmac58's Avatar
Quoted: 139 Post(s)
Yeah, I mentioned I'd get under there, but things are piling up and haven't had a chance. He needs to know which wire goes where, as he has after market plug ends.
Yet the above post should make any further investigation moot.
'84 CD-weekender!
Rmac58 is offline
post #9 of 9 (permalink) Old 11-03-2009, 11:06 AM Thread Starter
Thank you Azimuth Aviation. I appreciate knowing that it does not matter which of the large ones go where, it answers my question completely.
Thank you RMAC58 for your offer but it isn't necessary to get under the car at this point.
MrBrits, I fail to see why it surprises you that one enthusiast would crawl under their car to aid another! In the MG world of enthusiasts we drive 50 or more miles to spend the afternoon working with each other's vehicles, to share talents, knowledge and muscle or to point out something that defies verbal description.
Crawling under my car and taking a picture would have served no purpose in that it would have shown three wires and three spade lugs. My question would not have changed; "The small goes on the small, which spade goes in the middle?"
The answer to which was simply "It doesn't matter."
Here are a couple of photos of the alternator as it sits. I do not like the fact that the DPO didn't put insulated connectors on , they could short to the housing of the ALT.
Thin skin never helps you on the web, or under the hood.
    Help-Running new speaker wires/power wires hoggertp R129 SL-Class 11 12-03-2013 04:09 PM
    Cannot get Alternator Belt tight enough - Alternator Bracket jonbobshinigin W123 E,CE,D,CD,TD,TE Class 9 04-15-2009 02:35 PM
    Serp belt snapped. Alternator seized. New alternator ... doesn't fit??? Qualm W124 E,CE,D,TD Class 0 03-30-2009 08:05 PM
    Spark plug wires / Ignition Wires DETANE W163 M-Class 11 04-24-2007 06:29 AM
    Help -:- What kind of wires should I use for running wires for the blinker LEDs? Thanks for any info RLO R170 SLK-Class 0 05-31-2002 11:05 AM
