Caliper Rebuild kit? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-20-2009, 09:46 PM Thread Starter
mramay's Avatar
Date registered: Feb 2005
Vehicle: '87 570SEC (FrankenBenz) '87 560SEL (Lisa), '87 560SEC (Bling)
Quoted: 171 Post(s)
I can get a rebuild kit for the rear calipers on my son's '83 380SEL but it will take a couple of days. The dust covers look good, just leaking brake fluid.
It's just an o-ring that's bad so is there anything special about that o-ring? If I can find a high temperature viton o-ring that's the same size (from a local hydraulic hose shop), can I use it??
Viton is good to 1450psi and 400F for extended periods, the best rating of the common o-ring materials.
Thanks,
Mike
//leaking from the rear!
Blasphemous Mike
US '87 560SEC with Euro headlights, clear markers, H&Rs, 18x8.5, ATE slotted rotors with semi-metallics, BergWerks FGS, 3.07 Limited Slip.
In progress - FrankenBenz SEC: GM LS6 5.7L engine with custom 4L60E 4-spd overdrive transmission, GM rack and pinion.
One of my goals with the FrankenBenz is to scare women and children, and to have Lexus drivers spill their latte.
mramay is online now
post #2 of 4 (permalink) Old 10-20-2009, 09:55 PM
mclare's Avatar
Date registered: Aug 2008
Vehicle: 91 560SEC AMG w/300HP Custom Built Motor; 90 560SEL Stock
Quoted: 249 Post(s)
Send a message via Yahoo to mclare Send a message via Skype™ to mclare
No Mike. As you know I just did mine and the O ring is square not round in cross-section.
Current Stable:
91-560 SEC AMG - Coupe - 199/261 - 300 HP Custom Built Motor - Highly Modified Coupe
90-560 SEL - Sedan - 199/261 - Stock
mclare is offline
post #3 of 4 (permalink) Old 10-21-2009, 10:16 AM Thread Starter
mramay's Avatar
Quoted: 171 Post(s)
OK, I'll check the local stealership then the auto parts houses.
Thanks!!
Blasphemous Mike
post #4 of 4 (permalink) Old 10-21-2009, 01:50 PM Thread Starter
mramay's Avatar
Quoted: 171 Post(s)
Stealership would have to order it and it would be "between $36 and $86, depending on which brand of caliper".
The major brand auto parts stores ( Autozone, Checkers, Pep Boys, Napa) either can't get the kit or want "5-7 working days" to get the kit here.
Found a place called Nevada Brakes here in Vegas that for all of $23, will have the kit here tomorrow. I ordered two.
Thanks for the help!!
Blasphemous Mike
    Brake caliper rebuild? How? kh500 W123 E,CE,D,CD,TD,TE Class 12 07-04-2013 03:40 AM
    caliper rebuild tips? rookierokus W123 E,CE,D,CD,TD,TE Class 21 11-14-2010 08:30 PM
    Caliper rebuild mess up binglax09 W123 E,CE,D,CD,TD,TE Class 10 09-24-2008 11:46 AM
    83 300sd front caliper rebuild AzimuthAviation W126 S,SE,SEC,SEL,SD,SDL Class 1 05-11-2007 09:51 PM
    rebuild caliper or replaced them? 83turbodiesel W123 E,CE,D,CD,TD,TE Class 7 04-25-2006 06:13 PM
