ASR Light on 1991 300SE (Red vs. Yellow) - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 10-09-2009, 07:43 AM Thread Starter
Date registered: Sep 2009
Vehicle: 1991 300SE
Hi All,
I just bought a 1991 300SE, according to the owner’s manual the ASR light is yellow located between the check engine light and the ABS light. My car has a solid red light with no ASR inscription on it? Does anyone know what the difference is? Could this be a replacement dash? Any insight into this will be appreciated.
Thanks,
Tim
nhcamper is offline
post #2 of 18 (permalink) Old 10-09-2009, 08:02 AM
ianrandom's Avatar
Date registered: Jul 2008
Vehicle: 1986/1990 W126
Quoted: 755 Post(s)
No symbol on the red light at all?
'86 420SE
'90 420SEC
'89 2CV6
Daily transport 9spd Giant DH Comp downhill bike
ianrandom is offline
post #3 of 18 (permalink) Old 10-09-2009, 09:09 AM
Premium Member
Dr.Grillz's Avatar
Vehicle: Mercedes
Quoted: 231 Post(s)
Are you sure your 300SE has ASR? I understood that ASR was an option on for V8's. I've seen ASD instead on 6 and 4 cylinder models. Sounds like you may have a Euro model 300SE.... any more info on it?
1980 Mercedes 280TE AMG
1989 Mercedes 560SEC
1990 Mercedes 560SEL with AMG parts modifications
1991 Mercedes 190E AMG with Brabus 4-cyl M102 2.6
Dr.Grillz is offline
post #4 of 18 (permalink) Old 10-09-2009, 09:09 AM
Always Remembered RIP
cascade's Avatar
Date registered: Nov 2006
Vehicle: 1991 560SEC AMG
Location: Grass Valley, N. Calif. / Gardnerville, Nevada
Quoted: 17 Post(s)
Send a message via AIM to cascade
The 1991 ASR light.
Going by the 1991 S class US spec sales brochure, the best I can figure is this:
You could NOT buy the ASR and THE ASD options BOTH at the same time for the 300SE. But you could buy either of them as an option for this model.
When they came on, a small orange box on the speedometer cluster (right at near where 160 kph would be) would illuminate, with a picture inside the little orange box, with an exclamation point inside a triangle would light up.
The ASD illumination light, located, between the CEL on right, and the SRS light on the left, in the catalogue, *appears* to be red, and the CEL appears orange. But the colors aren't clear and there is no picture for the ASR light, in the picture, but its (ASR) location would be where the ASD lamp shows.
I specifically looked for and purchased, a US spec '91 560SEC WITHOUT wither the ASR or ASD option. When you turn on the ignition all the warning lights along the bottom of the dashboard illuminate for a moment, to show you the BULBS are ok, and on my car, where the ASR or ASD lights would be, between the CEL on right and the SRS on the left, show two blank, unilluminated spaces where the warninbg light would be.
Does this shed a "lght" on things or muddy the waters further?
Ask mclare, he has a '91 560SEC with the ASR, and it gave him a lot of trouble, where his ASR light is, and what color it is.
Jim
<--- superschnelle 300 hp 10:1 ECE euro HV, Hochverdichtung = high compression (11/2011) ... Wie im Freien Fall. Nur horizontal.
"I swear to god, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity." >'='<
cascade is offline
post #5 of 18 (permalink) Old 10-09-2009, 09:23 AM
cascade's Avatar
Quoted: 17 Post(s)
For US spec 1991 300SE vehicles, on the last page of the 1991 US spec S class w126 AND R129 sales brochure, ASR is mentioned SPECIFICALLY, as a 300SE option.
ASD was NOT available on this model.
Jim
cascade is offline
post #6 of 18 (permalink) Old 10-09-2009, 10:48 AM
Premium Member
Dr.Grillz's Avatar
Vehicle: Mercedes
Quoted: 231 Post(s)
I've yet to see a 300SE/L with an ASR option, only ASD.
I do know that the ASD option was not available for the V8's... and remember, the ASD and ASR are totally different things. ASD is an EXCELLENT option, while ASR is what can give you problems.
Here are pictures of a 300SE with ASD:
post #7 of 18 (permalink) Old 10-09-2009, 12:15 PM
mclare's Avatar
Date registered: Aug 2008
Vehicle: 91 560SEC AMG w/300HP Custom Built Motor; 90 560SEL Stock
Quoted: 249 Post(s)
Send a message via Yahoo to mclare Send a message via Skype™ to mclare
Yes, I do have ASR on my car and it is non-functional and will stay that way.
Jim is correct in that it is a major pain in the ass and an option to be avoided at all costs. He is a little off (understandably) in the location of the warning lights.
There are two:
The first one is the "System Failure" light as Jim pointed out correctly, on the dash in between the CEL and the SRS lights. I believe it is red. I can check later when I go to the shop and look at it.
The second one is the "System Engaged" light and that is in a little different position than Jim described. It is in the speedo, but at the top under the "90" mph (maybe Jim meant 160 Kph? I am sure he did) and above the ODO. That light comes on whenever you do a maneuver in the car where the ASR has to take over from you. That is what that light does.
When the one on the dash comes on, bad things happen. The car goes into what is called the "Limp Home Mode" where the power of the engine output is reduced by ONE THIRD by means of taking away the full throttle control from you and reducing the amount of power you can give the car.
This is why I am removing it. Even if it worked, I am a good enough driver having gone to race school, that I can fully control the car in all aspects of a skid. It also disables the ABS since they are interlinked. So when you lose ASR, it takes out the ABS too. Both of which I can live without.
To see if your car has ASR, look on your brake ABS unit and it is larger by twice than the regular unit and it will say "ASR" on top.
Current Stable:
91-560 SEC AMG - Coupe - 199/261 - 300 HP Custom Built Motor - Highly Modified Coupe
90-560 SEL - Sedan - 199/261 - Stock
mclare is offline
post #8 of 18 (permalink) Old 10-12-2009, 05:15 PM
Date registered: Jul 2009
560 SEC 1991 ASR LIGHT ON
HI, MY MB 1260451A606492 DOES LIKE SLIPPAGE ON TRANSMISION OR GEARBOX AND THE WARNING LIGHT ON THE SPEEDO TURNS ON, AND THE CAR LOSES POWER OR TRACTION. ANY HELP?
Joubert López
MB 500 SEC '84 - "Lead Lady" (221k km)
MB 500 SEC '85 - "Blue Girl" (160k km)
MB 500 SEC '86 - "Silver Baby" (211k km)
MB 560 SEC '91 - "Wine Lover" (86k km)
(all euro - riding in Venezuela - for me!)
560sec91 is offline
post #9 of 18 (permalink) Old 10-13-2009, 11:24 AM
mclare's Avatar
Quoted: 249 Post(s)
If your ASR light comes on then it is in the "Limp Home" Mode and the power is retarded unless you defeat the TPS as I did.
Current Stable:
mclare is offline
post #10 of 18 (permalink) Old 10-13-2009, 07:34 PM Thread Starter
Vehicle: 1991 300SE
ASR
Thank you for your insight into my ASR questions. 1. There is no lettering on the solid red light in-between the ABS and CEL lights. 2. I ran the VIN. through the Russian site and it was correct except for one option, 268 located in the number 30 spot under equipment. I still do not know what option this is. The Russian site didn't recognize the option 68 in my VIN? I surmise it is actually option 268. None of the options listed mention ASR or ASD.
nhcamper is offline
    1991 300te ASR light jellyfishes111 W124 E,CE,D,TD Class 2 10-03-2009 05:59 PM
    yellow and red light on my differentials lock balticstone G-Class 8 02-06-2009 05:06 PM
    ABS/ASR Instrument yellow Lights are on swestbury R129 SL-Class 4 11-01-2007 01:23 PM
    92 300SE ASR light on valenta37 W140 S-Class 6 05-06-2007 06:49 PM
    Steering Fluid, red or yellow? Mike2001 W210 E-Class 4 04-10-2005 06:13 AM
