replacing rear vent/quarter window - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 02-12-2009, 02:18 PM Thread Starter
Vehicle: 1990 560SEL
My driver's side rear vent window/quarter window, what ever you call it was recently broken. Along with this, the chrome sill on the passenger's side rear door below the window was damaged too. I've got an estimate for $422 to replace the window, chrome and a few pieces of weather striping, but I'm sure I could do it for much less on my own.
I'm curious if any of you have replaced this window before, is it hard, or something I should let a professional do? I have taken the interior of the door apart before, so I have a loose idea of how to start.
W126fahrer is offline
post #2 of 14 (permalink) Old 02-12-2009, 04:53 PM
Date registered: Jun 2005
Vehicle: 300se, 560sel
Quoted: 2 Post(s)
Send a message via AIM to RakNaks
just did it, not bad but a bit tricky and time consuming!
RakNaks is offline
post #3 of 14 (permalink) Old 02-12-2009, 05:17 PM
Quoted: 2 Post(s)
First if you have the door panel off locate the two bolts that hold the window track on the bottom. They should be in the rear of the window towards the quarter glass. Take those out.
Next try to pry the actual track bar out. Next loosen the window regulator, should be two bolts and one nut. Now begin to wiggle the whole motor out.
Be careful as the window my want to come down. Let it come down and let it sit below. Only when you get the whole regulator/ motor out!
Next pry out the track seal from the top. You will see a tiny phllips head screw on the upper part of the trim next to the quarter window inside.
Once removed take out the chrome piece. You will have to play with it to get it out. Just be gentle and twist it around as you pull out.
Now the quarter window will slide out! Just give her a gentle tug and she will slide out. On your install just soap up the rubber and slide it back in!
Hope this helps!
Rick
RakNaks is offline
post #4 of 14 (permalink) Old 02-12-2009, 08:54 PM
500MPL's Avatar
Date registered: Jan 2004
Vehicle: 1984 500 SEL euro, 1989 560 SEL, 1980 450 SL, 1981 DeLorean, 2013 F10 BMW
Quoted: 4 Post(s)
I think your chrome piece is the drip rail moulding that runs horizontally. That piece is held in by 4 or 5 clips that you will see with the door panel off. The gasket is a one piece unit that the replacement glass will sit inside the seal.
Follow the directions already posted and you should be fine.
Regards,
500MPL is offline
post #5 of 14 (permalink) Old 03-02-2009, 02:09 AM Thread Starter
My window has finally arrived, so I've started taking the door apart. However, it's been a while since I've done this and I can't figure out how to get the panel off. I seem to remember that it slides off, but I can't remember in which direction. It doesn't seem to want to really move.
I can't seem to remove the ash try surround as well, which is probably why the whole panel won't come out. The actual ash tray is out, but the black surround is still in, how does that come out? I've tried prying it but I don't want to damage the panel anymore.
post #6 of 14 (permalink) Old 03-02-2009, 02:24 AM
slightly creased
420 SE's Avatar
Date registered: Sep 2005
Vehicle: 1988 420 SE; 2015 ML 400
Quoted: 139 Post(s)
NO!!!! you do not need to take the ashtray bracket out and the door card/trim lifts straight up in line with the window - anything else and you will break the plastic hangers and be looking for a new door card. The card is HUNG on the door, the hangers are part of the plastic card frame...
Ross
OzBenz
beware of fundamentalists
420 SE is offline
post #7 of 14 (permalink) Old 03-02-2009, 02:27 AM Thread Starter
um, never mind, I found my a post that I started almost six years ago about removing the panel, problem solved.
post #8 of 14 (permalink) Old 03-02-2009, 02:30 AM
mclare's Avatar
Date registered: Aug 2008
Vehicle: 91 560SEC AMG w/300HP Custom Built Motor; 90 560SEL Stock
Quoted: 247 Post(s)
Send a message via Yahoo to mclare Send a message via Skype™ to mclare
PM Sent with link to the service manuals
Current Stable:
91-560 SEC AMG - Coupe - 199/261 - 300 HP Custom Built Motor - Highly Modified Coupe. FOR SALE - PM ME
90-560 SEL - Sedan - 199/261 - Stock. FOR SALE. - PM ME
mclare is offline
post #9 of 14 (permalink) Old 03-02-2009, 10:01 AM Thread Starter
Awesome, thanks!
post #10 of 14 (permalink) Old 03-02-2009, 10:48 AM
mclare's Avatar
Quoted: 247 Post(s)
You are welcome! Good Luck!
Current Stable:
mclare is offline
    FS rear left quarter window w 123 coupe marinos90209 For Sale/Wanted/Trade/Giveaway 0 10-11-2007 10:46 AM
    Rear Quarter Window Inop Sgooter R170 SLK-Class 5 08-03-2005 06:23 PM
    Has anyone every had the rear quarter window ... Jacques R170 SLK-Class 5 08-17-2003 05:13 PM
    Powered Rear-quarter Vent Windows JFR W163 M-Class 2 05-04-2003 09:26 PM
    Leaving rear quarter window down with top up... DanPro (Montréal) R170 SLK-Class 2 05-06-2002 10:41 AM
