86 560sec Blower Fuse location? - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 02-04-2009, 06:35 AM Thread Starter
Date registered: Jan 2008
Vehicle: 1986 560 SEC (Regular USA Model)
I've surfed the forum but need help in locating the fuse for a 86 560sec Blower. Seen a pic of a 90 560sec, but my 86 doesn't show the same location. Any help would be appreciated. It's been cold here in Oklahoma and my kids want the blower fan to work to warm em up. Fortunately the heated seats still work.
560XTC is offline
post #2 of 8 (permalink) Old 02-04-2009, 11:28 AM
Chadahar's Avatar
Date registered: Apr 2008
Vehicle: '82 Euro 500SEL, '85 Euro 500SEC AMG WB Cabriolet,'86 Euro 500SEC RUF
Quoted: 366 Post(s)
Look in front of the fuse box against the false firewall. there should be a fuse block and cover about 3/4" wide and 2 1/2" long. It may be on the drivers side wheel well as well. I think they moved it to the false firewall area later in the proiduction(1988?) Pull the cover off and there is a strip fuse in there that is probably blown. They are 30 or 50 amp. to rig a fuse between the poles(screws go to a auto parts store and buy a spade fuse and holder with the wire pigtails and simply wire that in between the screws. that will work until you can get to a MN dealership fo the strip fuses. You might try your favorite Indy as well. I found a couple at a local Indy shop and didn't have to do a 56 mile RT to buy the fuses. Buy a couple or three and put them in the glove box for future use.
"I know you think you understand what you thought you heard me say, but what you thought you heard me say is not necessarily what I meant!"
Chadahar is offline
post #3 of 8 (permalink) Old 02-04-2009, 04:30 PM
granit560's Avatar
Date registered: Dec 2007
Vehicle: 1987 560 sec impala metalflake over cream
Quoted: 10 Post(s)
mine i think is on rh side of air cleaner ? & a quick question chadahar, will the air work if this fuse is blown?
granit560 is offline
post #4 of 8 (permalink) Old 02-04-2009, 04:52 PM
Always Remembered RIP
cascade's Avatar
Date registered: Nov 2006
Vehicle: 1991 560SEC AMG
Location: Grass Valley, N. Calif. / Gardnerville, Nevada
Quoted: 17 Post(s)
Send a message via AIM to cascade
fuse diagram for '86 560 SEC
Here you go
1986 Fuse Diagram
Jim
<--- superschnelle 300 hp 10:1 ECE euro HV, Hochverdichtung = high compression (11/2011) ... Wie im Freien Fall. Nur horizontal.
"I swear to god, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity." >'='<
cascade is offline
post #5 of 8 (permalink) Old 02-04-2009, 05:17 PM
mramay's Avatar
Date registered: Feb 2005
Vehicle: '87 570SEC (FrankenBenz) '87 560SEL (Lisa), '87 560SEC (Bling)
Quoted: 173 Post(s)
Here
Blasphemous Mike
US '87 560SEC with Euro headlights, clear markers, H&Rs, 18x8.5, ATE slotted rotors with semi-metallics, BergWerks FGS, 3.07 Limited Slip.
In progress - FrankenBenz SEC: GM LS6 5.7L engine with custom 4L60E 4-spd overdrive transmission, GM rack and pinion.
One of my goals with the FrankenBenz is to scare women and children, and to have Lexus drivers spill their latte.
mramay is offline
post #6 of 8 (permalink) Old 02-04-2009, 06:36 PM
Chadahar's Avatar
Quoted: 366 Post(s)
My Blower fuse is located on the top of the driver's fenderwell in my(are you ready for this) 1984 Euro 500SEC. I didn't think they were installed that early, but maybe the Euro's were different.
My fuse for the 1989 SEC is where Mike pictured it.
As to the AC working? I would think it would, but no blower. I don't know for sure. Someone else will have to expound upon that question.
Chadahar is offline
post #7 of 8 (permalink) Old 02-07-2009, 09:57 AM Thread Starter
WOW!... Isn't the internet amazing! Gr8 Job everyone for their contribution and helping me solve this puzzle. Once I check the various suggestions I'll get back with the one that fits the 1986 specific location.
The pic posted by mramay is the same I've seen for the 1990 sec, but unfortunately isn't the same for the 86. Uuugh.
Cascade, thanks for including the fuse diagram! My 86 still has this in the fuse box lid, but I certainly appreciate the scanned copy you attached. MUCH EZr to read for my 50+ year old eyes.
Thanks again.... 560xtc
560XTC is offline
post #8 of 8 (permalink) Old 02-07-2009, 11:00 AM Thread Starter
What the (BLANK)?!?! I've checked (again) the above suggestions with no success.
I'm tempted (Just to prove myself) to post a pic of the '86 I'm dealing with of the similar location that mramay sent. Checked both sides of the breather, top of the driver's side wheel well, along both firewalls.... just can't seem to find the blower fuse.
Looked and checked ALL the fuses in the fuse box as well. MAJOR RATS, RATs,RatS!!!
I know for a fact the engine bay had been rewired due to a small electrical fire... I wonder if the Previous Owner (PO) had neglected to locate the blower fuse in the original location??? Again to ALL.... Thanks for your HELP! But I could still use anyone's instruction.
560xtc
560XTC is offline
    Location of blower motor fuse for W124 1989 300TE???? rcs hawaii W124 E,CE,D,TD Class 3 05-22-2012 08:01 PM
    Blower Motor/fuse Location 97 E420??? Help?? dobbes W210 E-Class 2 10-30-2006 10:36 AM
    Location Of The Blower Motor, 86/ 560SEC Blacksea W126 S,SE,SEC,SEL,SD,SDL Class 2 07-14-2006 10:04 AM
    420 sel blower fuse location Ted Taylor W126 S,SE,SEC,SEL,SD,SDL Class 1 05-30-2006 01:56 PM
    560sec VSS sensor location ibrahim83 W126 S,SE,SEC,SEL,SD,SDL Class 1 09-29-2003 08:52 PM
