Old 09-10-2008, 09:36 AM   #1 (permalink)
Date registered: May 2008
Amsoil Hydraulic Oil in Self Leveling System
thinking about trying the Amsoil Tractor Hydraulic/Transmission Oil in the self-leveling system of a 1991 560SEL. somewhat less expensive than the FEBI oil, link to product below (top product, tractor/hydraulic oil). any chance using this oil might harm the self leveling system?
AMSOIL Synthetic Hydraulic Oil and Lubricants
PurpleBarney is offline   Reply With Quote
Old 09-10-2008, 10:33 AM   #2 (permalink)
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: 1991 560 SEC
Send a message via AIM to jhodg5ck
Sure...or I find that John Deere fluid works Well too
Jonathan
Blue Ridge Mercedes/AMG East (temp down!)
Offering Enthusiast Service, Restoration and Tuning.
Providing quality parts to all parts of the world.
Located in the Atlanta area
96 S600 Euro
91 560SEC ECE (for sale)
91 560 SEC 226/271 Undergoing TT conversion
89 190E 2.6 5sp
89 300TE (Mosselman TT waiting..)
88 560SEC AMG Euro ECE (parts)
89 560SEC AMG mech. lifter/68K rpm conv.
87 Hammer 6.0L 32V
86 560SEL AMG 6.0L 32V
jhodg5ck is offline   Reply With Quote
Old 09-10-2008, 10:46 AM   #3 (permalink)
the manual says it takes 3.5 quarts if flushed. it appears there is a drain plug on the fluid reservoir. do I merely drain the fluid or is there a flushing operation that needs to take place? if so, what might be the procedure for flushing the self-leveling system? thanks!
Old 09-10-2008, 05:56 PM   #4 (permalink)
Bergwerks Steve's Avatar
Date registered: Aug 2007
Vehicle: 1987 560 SEC 1989 300CE
This is one of the areas where you have to ask yourself; is saving a few dollars worth the possible grief? The oil viscosity is not an issue but the additives may promote failure and you won't know unless it happens. Struts are quite expensive and fluid is cheap, why take a chance.
Steve
Bergwerks Steve is offline   Reply With Quote
Old 09-10-2008, 07:37 PM   #5 (permalink)
jhodg5ck's Avatar
That's just it, the items/parts in the JD tractor that we use said oil in makes the SLS struts look Very cheap...my other thought being the conditions/strain the SLS systems sees pale in comparison to what the tractor goes through.
I've been running it in my white coupe for almost 4 years now (one flush thus far) and everything is A Ok!
Jonathan
Old 09-11-2008, 08:05 AM   #6 (permalink)
thank you for the input, I ended up purchasing the mercedes OEM product due to availability and shipping considerations, i.e., the seller gave free shipping if the order was over a certain dollar amount. Now, I need to know how to flush the self-leveling system properly. Do I simply drain the fluid reservoir or is there another procedure (evaculation, etc.) that is required?
Old 09-11-2008, 09:18 AM   #7 (permalink)
jhodg5ck's Avatar
If you search around flushing the SLS system has been written up in detail. To flush it (as well as one can w/o taking the struts off) will require 1-2 gallons to Really get things looking/staying clean.
I also add a W123T filter to the 560's screen.
Jonathan
Old 09-11-2008, 01:47 PM   #8 (permalink)
what is a W123T filter? is there a mercedes part number? thanks!
Old 09-11-2008, 02:39 PM   #9 (permalink)
jhodg5ck's Avatar
It's the SLS filter for a W123 touring... easy enough to find... One more reason why it's handy to order parts from someone that deals w/ these cars day in and day out, eh?
Jonathan
Old 09-11-2008, 02:56 PM   #10 (permalink)
absolutely. I noticed that you are into modifications on these cars. I was wondering if a 119 engine would drop into a 1991 560SEL. if so, it would probably need a different transmission, correct? also, could one cryogenically treat an M119 engine and supercharge it? I imagine the car would be good for at least 170 MPH or so.......
Self leveling hydraulic system (in w126) AL-MEHDAR W126 S,SE,SEC,SEL,SD,SDL Class 8 08-26-2008 12:20 PM
W124 estate hydraulic suspension system contaminated with engine oil lesm W124 E,CE,D,TD Class 3 06-16-2008 09:48 AM
Non MB Oil For The Self Leveling System? rockwool W123 E,CE,D,CD,TD,TE Class 4 12-28-2007 06:31 PM
Replacing 560SEL Suspension Leveling System Hydraulic Hose at Pump Famquat W126 S,SE,SEC,SEL,SD,SDL Class 4 01-09-2007 09:31 PM
Hydraulic Self-Leveling Suspension MorrisTigerson69 W126 S,SE,SEC,SEL,SD,SDL Class 4 11-23-2004 09:26 AM
