Old 09-09-2008, 09:26 PM   #1 (permalink)
Date registered: Apr 2008
Vehicle: 1989 Mercedes Benz 420 SEL
Wink Question on the Sturt Rod Mounts
Hi all,
I wanted to know if there was a special tool to hold the nut that is at the top of the sturt mount bushing. Let me explain a little more. You know the 2 big bushing that can be replaced easy buy removing the 2 long bolts about 3 inches in length they have a nut that is on a piece of then metal that sticks out of each side of the frame well I have on that is just the nut and no metal to hold the nut. I have tried combination wrenches and to fit that nut they don't fit in that opening to get on the nut.
So I hope someone can tell me how to take care of this.
Thanks
edwardgwright is online now   Reply With Quote
Old 09-09-2008, 10:49 PM   #2 (permalink)
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: 1991 560 SEC
Send a message via AIM to jhodg5ck
Oh, that's bad...the piece is supposed to be captive via a set of arms that stick through the chassis.... when the cars see a lot of salt etc the 'arms' rust off..you're best bet is a sturdy long set of needle nose pliers and lots of pen oil....
If you look @ your new pieces you'll see the part that I'm talking about and how what's on your car is broken.
Jonathan
Blue Ridge Mercedes/AMG East (temp down!)
Offering Enthusiast Service, Restoration and Tuning.
Providing quality parts to all parts of the world.
Located in the Atlanta area
96 S600 Euro
91 560SEC ECE (for sale)
91 560 SEC 226/271 Undergoing TT conversion
89 190E 2.6 5sp
89 300TE (Mosselman TT waiting..)
88 560SEC AMG Euro ECE (parts)
89 560SEC AMG mech. lifter/68K rpm conv.
87 Hammer 6.0L 32V
86 560SEL AMG 6.0L 32V
jhodg5ck is offline   Reply With Quote
Old 09-10-2008, 10:00 AM   #3 (permalink)
Serintek's Avatar
Date registered: Aug 2007
Vehicle: Mercedes 1982 380 SL, 1988 560 SEL Navy Blue
Send a message via Skype™ to Serintek
Jonathan
Got them changed a few months ago. If I remember correctly, the mechanic had to cut in the frame to get to the bolt, than weld a peice of metal to the nut to hlod it properly in re-installint long bolts, then re weld the frame after the job, both sides... Too much rust ot this nut...
But it did the job.
Good luck
Martin Richer
New Brunswick Canada
1982 380 SL Grey
2002 Mazda Tribute V6 4X4
1999 Yamaha Roadstar 1600 cc
Serintek is offline   Reply With Quote
Guide rod mounts mckellyb W126 S,SE,SEC,SEL,SD,SDL Class 1 06-12-2008 06:53 PM
Tie rod question. AirCooledRules W123 E,CE,D,CD,TD,TE Class 4 03-21-2007 11:32 PM
Tie Rod Question LeeMc R/C107 SL/SLC Class 4 04-10-2006 05:52 PM
Tie Rod Question... bse500sel W126 S,SE,SEC,SEL,SD,SDL Class 3 01-14-2005 02:06 PM
Replacing the Guide Rod Mounts gasparetto W126 S,SE,SEC,SEL,SD,SDL Class 11 09-24-2004 08:58 PM
