I installed an arm from the salvage yard last year. Earlier this year it stopped working. The gears and mechanism were all perfect. It would retract but not extend. I spent an afternoon reverse engineering the mechansim and found the problem. The arm has two actuators on the bar which engage with two limit switches next to the motor. The limit switch which engages the closing actuator on the bar had become loose. The loctite material cracked and allowed the limit switch to move upward. I adjusted the switch downward until I could hear the click of the switch when the arm was in the retracted position. Once this was done the arm worked perfectly again. I cemented the screws with thick super glue after adjustment.
I hope this helps some of you fix the presenters.
'89 MB 560 SEC
Euro RUF ECE Engine, Euro Tri Y Headers, Stainless Steel Twin Down Pipes, Euro Headlights and Wipers System, Chrome 18" AMG R129 Wheels, H&R Springs, First Gear Start, EBC Green Pads and EBC Slotted/ Dimpled Rotors.
'94 BMW 850 CSi
Dinan Chip Set, M Mirrors, M Four Piston Brakes W Floating Rotors, Chrome 18" RGR Racing Dynamics Wheels.
Glad it solved the problem for you. The seatbelt presenter is one of the fun features of the SEC.
Regards,
Axel
1990 SEC, Arctic White w/gray interior, M119.960 326 Hp. engine from 1992 500 SL, 722.370 transmission from 500E (reinforced clutches), 2:82 Differential, Euro Headlamps, 1st Gear Start module, One-Touch Window module and Keyless Entry module all from BergWerks, Bilstein HD Shocks on front axle, H&R lowering springs front and rear, AMG 3-piece 17" rims, 8.5" in the front and 10" at the rear.
