Old 08-15-2008, 08:19 PM   #1 (permalink)
Date registered: Apr 2008
Vehicle: 1987 300SDL
Nailing Even After Injectors Replaced
My 300sdl has cylinder 1 and 2 that produce a nailing sound at idle.
I verified this by loosening the injector supply lines, one at a time, which made the sound go away and made the engine run rough.
I replaced all injectors with Bosch rebuilt injectors. The nailing remains.
Other than the nailing sound at idle, the car runs great, over 25mpg and adequate power.
I read another thread on this topic for a 300sd nailing, adjusting the valves was mentioned as a remedy.
The 300sdl has hydraulic valves, could they be needing adjustment?
I removed the #1 injector and saw a fairly clean pre chamber.
Is the nailing hurting the engine?
What else can be the cause?
gmarkisj is offline   Reply With Quote
Old 08-15-2008, 10:04 PM   #2 (permalink)
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6, bought 07/08 with 50k original miles.
I have no experience with diesel engines. In case you are not familiar in how to search the forum, please read http://www.benzworld.org/forums/w126...ease-read.html
Teutone is offline   Reply With Quote
Old 08-15-2008, 10:58 PM   #3 (permalink)
AzimuthAviation's Avatar
Date registered: Apr 2006
Vehicle: 1982 380SE AMG euro (parted out) , 1983 300SD, 1984 500SEL AMG euro
I've found that the 617 has it's own sound. Kill the fuel to and injector and no sound. You can try to move the injectors around but you'll probably still have a diesel sound at idle. Does it sound different above 1000rpm? Put some Diesel Clean in her and haul ass up to towards Ice House on hwy50 and see how she does afterwards
AzimuthAviation is offline   Reply With Quote
Old 08-15-2008, 11:08 PM   #4 (permalink)
At 1000 RPM the sound goes away. Diesel Clean....where is this obtained? I have moved the injectors around and the sound remains with cylinders 1 and 2.
If its not hurting the engine, I can live with it.
Old 08-16-2008, 09:58 AM   #5 (permalink)
It's much easier to find than the LubroMoly products. Check out any of the local auto parts places. Walmart also carries the stuff. My bad, it's spelled Diesel Kleen. Here's the bottle: PS302512 DIESEL KLEEN ADDITIVE 32 OZ
I prefer the stuff in the grey bottle over the white since it will boost cetane higher than the white. Put in the recomended amount and don't be afraid to drive the car like an angry meth addict. Do a search on Italian Tune Up. These cars do suffer if they are babied when you drive them and will not show you their true potential.
Old 08-16-2008, 10:26 AM   #6 (permalink)
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: 1991 560 SEC
Send a message via AIM to jhodg5ck
Or, run her on a can or two of diesel purge...we've had Great luck with it!
The kleen makes a good maint. additive but the purge Really cleans out the junk...and as AA said, run her Out! The diesels really do better when driven Hard.
Jonathan
Blue Ridge Mercedes/AMG East (temp down!)
Offering Enthusiast Service, Restoration and Tuning.
Providing quality parts to all parts of the world.
Located in the Atlanta area
96 S600 Euro
91 560SEC ECE (for sale)
91 560 SEC 226/271 Undergoing TT conversion
89 190E 2.6 5sp
89 300TE (Mosselman TT waiting..)
88 560SEC AMG Euro ECE (parts)
89 560SEC AMG mech. lifter/68K rpm conv.
87 Hammer 6.0L 32V
86 560SEL AMG 6.0L 32V
jhodg5ck is online now   Reply With Quote
Old 08-16-2008, 08:52 PM   #7 (permalink)
Jonathan
I'll try the Diesel Purge. Where is the "junk" located? I removed the intake tube that crosses over the valve cover and its thick with black carbon junk. I disconnected the EGR, so hopefully I won't be adding more crust. When I get a chance I want to remove the intake manifold and have it cleaned.
Old 08-16-2008, 09:45 PM   #8 (permalink)
jhodg5ck's Avatar
In the combustion chamber :-P
Cleaning the intake manifold yields minimum benefit.
Jonathan
1997 S500 No Fuel at Injectors (fuel pumps already replaced) dleroux W140 S-Class 10 07-29-2008 11:05 AM
What exactly is nailing? Alan Bush W123 E,CE,D,CD,TD,TE Class 6 10-15-2007 07:12 PM
Injector nailing p100 W123 E,CE,D,CD,TD,TE Class 2 03-08-2007 05:34 PM
OM617 nailing noise "injector knock" Chrisgd300 G-Class 14 03-19-2006 02:39 AM
my nailing engine floridabenzboi W123 E,CE,D,CD,TD,TE Class 13 05-11-2005 10:22 PM
