Old 07-30-2008, 10:31 PM   #1 (permalink)
85 500sel's Avatar
Date registered: Jul 2008
Vehicle: 1985 500sel
im a newb and i need some help bad!
i have an 85 500sel and the car has sat for four year. i had to put a new fuel pump in it it bearly stated. and bearly runs it did idle but would only go up to 2000 rpms and after driveing around for tweny minutes around the naighbor hood BEARLY able to get up to 25 mph i came back home and looked under it and the cat was RED hot so i cut it off and the thing was PLUGED as f*&#K. i stated it runs a little better but still bad. do i started pulling spark plugs that were bosch platnim + 4s and ive pulled only three two were fireing and one was like packed with crap. could that be due to plugged cat? and should i run a compression test??? how much pressure should each be at? and when i re do the exhaust should i put a cat back on? i would love some oppinions. THANKS
85 500sel is offline   Reply With Quote
Old 07-31-2008, 12:15 AM   #2 (permalink)
scott1999's Avatar
Date registered: Feb 2008
Vehicle: w126
sounds like you are on the right track
as for the cat does it have a 02 sensor after the cat , if so , that can be a problem ,
but sure there are more knowlagable people on the forum that can help , good luck
these are great cars to own and run
scott1999 is offline   Reply With Quote
Old 07-31-2008, 12:39 AM   #3 (permalink)
a3jeroen's Avatar
Date registered: Jun 2006
Vehicle: 1982 280 se aut. ecc. - sold
Welcome.
Please (re)read the welcome to the forum stickie. It'll tell you how to fill out your profile and how to do a search.
We had some threads about clogged cats.
IIRC someone (AA?) ran his car without the exhaus just to try and then replaced the cats since it revved great without the exhaust.
For plugs I'd change to non-resistor NGK BP6 ES's.
gr J
"Look for the ridiculous in everything and you will find it" Jules Renard
a3jeroen is offline   Reply With Quote
Old 07-31-2008, 12:16 PM   #4 (permalink)
85 500sel's Avatar
no sensor.. but i bought autolite 66's will they work?
Old 07-31-2008, 02:30 PM   #5 (permalink)
85 500sel's Avatar
i put the new plugs in and IT RUNS. yay!
Old 07-31-2008, 08:03 PM   #6 (permalink)
scott1999's Avatar
Vehicle: w126
nice one well done
Old 07-31-2008, 11:07 PM   #7 (permalink)
85 500sel's Avatar
but it still runs rough and is REALY hard to start. it still has alot of bad gas maybe thats why. what kind of injector cleaner should i run with fresh gas?
Old 07-31-2008, 11:31 PM   #8 (permalink)
I just had the same problem with my 87 560SEL. It is probabaly just bad gas. Gas gets old and turns to varnish. Drain it all out and put good stuff in. Also, the car proabaly has 2 fuel pumps, bad gas ruins fuel pumps, make sure both are working. Bad gas killed both my fuel pumps, I took them out and got them working again by hooking up power to them and then reversing the power a bunch of times until they broke free again. Then I blew up my fuel pump relay trying to run them on bad gas. I changed that, drain the bad gas, put in new gas and it fire right up.
tripleblk is offline   Reply With Quote
A New B for a newB martman W245 B-Class 9 04-04-2008 03:19 PM
Newb hr forte Off-Topic 6 07-10-2007 08:26 PM
Newb with Newb question. What is this? jexx1 GL Class 5 02-21-2007 11:05 PM
Newb please help chiplee W209 New CLK Class 1 11-25-2006 06:05 AM
another newb 514boost W201 190E, D-Class 3 04-24-2006 03:27 PM
