Old 06-12-2008, 08:18 AM   #1 (permalink)
BigD560's Avatar
Date registered: Feb 2008
Vehicle: 1990 Mercedes 560SEL
Propane Powered Mercedes?
I come from Jeeps and off-road vehicles, and enthusiasts have recently raved about the benefits of propane as an alternate fuel.
Has anybody ever considered what it would take to convert a gas powered Mercedes to propane?
Those diesel guys are rubbing the veg oil in our faces.....with rising fuel costs, I wonder if propane injection could be made to work with the CIS on our gassers?
We're adding a little something to this month's sales contest. As you all know, first prize is a Cadillac Eldorado. Anybody want to see second prize?
Second prize is a set of steak knives.
Third prize is you're fired.
BigD560 is offline   Reply With Quote
Old 06-12-2008, 08:27 AM   #2 (permalink)
AzimuthAviation's Avatar
Date registered: Apr 2006
Vehicle: 1982 380SE AMG euro (parted out) , 1983 300SD, 1984 500SEL AMG euro
Have you tried the forum search function? BWAHAHAHA! Had to say it! There have been several post from guys who did the conversion from Europe and in Oz too IIRC. Hell, this would be the bomb if we converted both our AC and fuel to propane!
AzimuthAviation is offline   Reply With Quote
Old 06-12-2008, 08:59 AM   #3 (permalink)
BigD560's Avatar
I'll dig some more. It was an impulse!
Old 06-12-2008, 10:21 AM   #4 (permalink)
Date registered: May 2008
Vehicle: MBZ 300SD
I have considered adding propane the the diesel/vegioil in my 300SD but I will first put a system in the diesel motorhome since it has all it needs.
It is supposed to give a 25% improvement on milage.
AndreiRN is offline   Reply With Quote
Old 06-12-2008, 10:36 AM   #5 (permalink)
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6, bought 07/08 with 50k original miles.
There are several threads in the archive. I keep seeing propane powered W126 on German Ebay.
Teutone is offline   Reply With Quote
Old 06-12-2008, 10:45 AM   #6 (permalink)
AMG junkie / W126 mod
Snibble's Avatar
Vehicle: 1990 560SEL 72k miles, 1991 190E 214k kilometers
Send a message via AIM to Snibble Send a message via MSN to Snibble Send a message via Skype™ to Snibble
Do a search on "LPG".
There are 2 systems... one that fuels LPG via the air intake. The other injects it straight into the cylinder chamber. The latter is whats more efficient, but more expensive to install.
I drive my 190E occasionally on LPG, but tend to stick with gasoline. Its got a 35L tank in the spare wheel well. Its doable in a mercedes, but you need to be careful as the rubber bits in the engine compartment tend to stress out from the LPG and can crack.
1990 Mercedes-Benz 560SEL soon to be Euro-spec clone AMG (summer of '09)
1991 Mercedes-Benz 190E AMG (undergoing restoration: July 1 - October 17, 2008)
Snibble is offline   Reply With Quote
Old 06-12-2008, 11:06 AM   #7 (permalink)
Vehicle: MBZ 300SD
Here is the basic kit you find easy.
Old 06-12-2008, 12:28 PM   #8 (permalink)
BigD560's Avatar
That kit looks like it should fit on a carbuerated intake....
I'm sure one would be able to make it work, but I'm wondering how it can be adapted to the CIS....
Seeing as LPG is a constantly pressurized system, wouldn't there need to be something done regarding the fuel pumps and the FPR? I understand the FPR is designed to cut off gas flow in the event of a wreck along w other responsibilities, but is it as simple as bypassing these steps in the fuel delivery process?
Maybe the cost outweighs the benefits, but there has to be a simple system one could fab up to do a LPG/GAS switchable option. It would definitely be nice to have.
Old 06-12-2008, 01:41 PM   #9 (permalink)
Vehicle: MBZ 300SD
My plan is diesel/propane (gas/propane) that simply adds propane to the intake in the air filter at a constant volume and at long trips to improve the consumption.
You can have 3 stabil levels of volume delivered.
Old 06-12-2008, 03:34 PM   #10 (permalink)
Date registered: Jun 2008
Vehicle: 1984 300sd turbo
Propane is cleaner then gasoline but it has less energy. 25.5 megajoules per liter for propane and 34.8 for regular gasoline. Propane is just slightly better the ethanol. With ethanol at 23.5. To use propane you have to burn about 1.5 times as much to get the same distance down the road. I don't think it's cost effective.
And diesels run on more the just veggy oil. They will run on just about any oil.
ArkRoyal is offline   Reply With Quote
powered by mercedes CivicTuning2 V-Class 1 06-02-2006 06:43 PM
WTB POWERED MY MERCEDES BADGE CivicTuning2 For Sale, Trade & Wanted Items 2 04-04-2006 09:34 AM
powered by mercedes logo CivicTuning2 W126 S,SE,SEC,SEL,SD,SDL Class 1 04-03-2006 09:56 PM
