Old 05-15-2008, 05:34 AM   #21 (permalink)
Michael Pillay's Avatar
Date registered: Oct 2003
Vehicle: 1990 300 SEL
Originally Posted by brandon671 View Post
I WAS ABLE TO GET IT OFF!!!! With little bit of a time i heard a crack i thought i lost the grove on the top but i kept going and it was able to come out, I loaded it with lots and lots of grease it was some rust i found on the inside. THANKS TO YOU ALL FOR ALL YOUR HELP IT IS VERY MUCH APPRECIATED.
Great. I know that was a good feeling!!!
Mike
1990 Mercedes Benz 300 SEL
2001 Mercedes Benz ML320
1999 Mercedes Benz SLK230
1986 Porsche 911 Carrera
Michael Pillay is offline   Reply With Quote
Old 05-15-2008, 09:35 AM   #22 (permalink)
crunk04gtp's Avatar
Date registered: Nov 2006
Vehicle: 1983 300sd
I'm certainly happy you managed to get the bolt off, but a little disappointed I didn't get to share my trick... so I'm going to do it anyway.
I was putting a 3" downpipe on my Pontiac. Exhaust temps + constantly getting splashed with water, so of course the the old nuts were rusted and stuck on like nothing else. So I put the wrench over the nut, positioned at 4 o'clock. I put a jack underneath it, slowly pumped it up until it touched the wrench. Then just a couple more pumps and crrrraaaaackk! Most beautiful sound in the world.
Are you veggin?
crunk04gtp is offline   Reply With Quote
Old 05-15-2008, 10:56 AM   #23 (permalink)
brandon671's Avatar
Date registered: Jul 2007
Vehicle: 1990 Mercedes Benz 420 SEL
Yes! that was a great feeling, It's funny because my father has a W140 and there is ALWAYS that one bolt/screw/nut that will not come off, and this time. even though i was able to get them off there was that one that was giving me that extra 10 minutes of hard work!
brandon671 is offline   Reply With Quote
Old 05-15-2008, 11:01 AM   #24 (permalink)
brandon671's Avatar
Old 05-15-2008, 11:48 AM   #25 (permalink)
crunk04gtp's Avatar
Vehicle: 1983 300sd
Whoa buddy! How did that happen?
Old 05-15-2008, 01:28 PM   #26 (permalink)
granit560's Avatar
Date registered: Dec 2007
Vehicle: 1987 560 sec impala metalflake over cream
a good way to fix that is shoe goo!
granit560 is offline   Reply With Quote
Old 05-15-2008, 03:15 PM   #27 (permalink)
Date registered: Nov 2005
Vehicle: 1991 560 SEL, 2003 BMW M3
Send a message via AIM to blnk124
use a bolt extractor. i had a broken lug nut that no one would even look at it. went to sears picks up a set of bolt extractors and took it out myself. BOOYAH! but be careful not to drill into the rim, which i didnt do. BOOYAH!
blnk124 is offline   Reply With Quote
Old 05-15-2008, 03:16 PM   #28 (permalink)
nevermind. you already got it off. good for you. i was no help. no booyah.
Old 05-27-2008, 12:55 AM   #29 (permalink)
Date registered: Dec 2003
Vehicle: 1989 300SE, 1989 420SEL, 1965 220S, 2002 Ford Crown Vic Police Interceptor
I had to take my rear wheel off yesterday and it was also hard to get the bolts out, they really made a noise when I loosened them. When I finished what I was doing and put the wheel back on, I put a little anti-sieze on the conical part of the bolt.
Near Manassas Va. '89 300SE, 2002 Ford Crown Victoria Police Interceptor, 89 420SEL
Had '65 220SE, 67 230S, 72 280SE 4.5 Dad had '65 300SE LWB, '65 220SE
"Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive." C.S. Lewis
wbain is offline   Reply With Quote
Old 05-27-2008, 03:04 AM   #30 (permalink)
brandon671's Avatar
i remember mercedes' selling a high heat lubricant in a brown bottle. Works great. but in this case would this help? and to the question of how that happened. from the looks of it i may have been driving it on the rim on the rubber i was only a few hundred feet away from my home when i noticed it and i thankfully didn't damage the rim.
lug nut torque??? to loss W123 E,CE,D,CD,TD,TE Class 5 01-11-2008 02:12 PM
lug nut? zazeem W201 190E, D-Class 0 10-29-2007 05:57 AM
lug nut help hcalmar W124 E,CE,D,TD Class 5 05-27-2005 12:39 AM
lug nut differences jlee021 R170 SLK Class 10 03-14-2003 01:16 PM
Lug nut caps Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 0 12-10-2001 03:03 PM
