Old 05-09-2008, 09:43 AM   #1 (permalink)
Htown's Avatar
Date registered: Apr 2005
Vehicle: 1990 300SE
Cool Where is the Thermo Time Switch
Can someone tell me where the theremo time switch is located on the straight six, how to diagnose, remove and replace? Also, how do I remove and replace the Cold Start Valve? Yes, I have searched the forum and found no info on remove and replace.
Htown is offline   Reply With Quote
Old 05-09-2008, 10:14 AM   #2 (permalink)
talbir's Avatar
Date registered: Dec 2004
At the rear of the block, on top....it is a green colour with two prongs sticking out. It is the only green coloured sensor on the block.
A 22m deep thin wall socket will be required to remove.
If engine is hot when removing, release the water system pressure by opening the rad reservoir cap half-turn.
The cold start valve is located between injectors 3 and 4 on the intake manifold and is simply removed by removing the 5mm allen bolt. The electrical plug simply unclips off and the fuel line is undone using a 12mm or 14mm spanner. Remove the fuel line before removing the 5mm allen bolt holding down the injector.
Talbir
Mercedes w124 500E 1993 Black 040
Mercedes w124 500E 1992 Silver 744
Mercedes AMG 560SEC Option 822 1988
Mercedes AMG DOHC M117 w126 AMG Widebody SEC 1985
Mercedes 560SE Carat Duchatelet 1987 Option 822
Mercedes 500SEL Brabus
Mercedes 300TE - Carlsson
Porsche 911 Turbo SE Slantnose 1986
Mercedes 560E - w124 5.6 DOHC 360bhp by Stratton
Ferrari 328 GTS Quattrovalvole 1986 Koenig Widebody
talbir is offline   Reply With Quote
Old 05-09-2008, 11:07 AM   #3 (permalink)
Htown's Avatar
Vehicle: 1990 300SE
Thanks T,
Two question though. Seems as like I read somewhere in this forum that the TTS was colored red on the straight 6, yes/no?
Also, I assume there is little or no gas pressure when removing the CSV thus minimal gas squirt?
1990 300E Thermo Time Switch frobi W124 E,CE,D,TD Class 7 05-01-2008 05:51 PM
thermo-switch? lander91 W126 S,SE,SEC,SEL,SD,SDL Class 2 09-17-2007 09:41 PM
thermo time switch mountainredneck W124 E,CE,D,TD Class 5 03-10-2007 07:02 PM
thermo time switch location?? 300e mountainredneck W124 E,CE,D,TD Class 0 03-07-2007 04:41 PM
thermo switch banflu W123 E,CE,D,CD,TD,TE Class 6 10-06-2005 03:51 PM
