Old 05-07-2008, 10:20 AM   #1 (permalink)
Date registered: Jan 2008
Vehicle: '90 300SE, '86 560SL
Smog/Air pump clanking
I've read where it has been recommended to "cut the belt", but I don't see how that is possible:
I don't need it, and I'd rather not spend $300 if it isn't necessary....so how do I remove it and use the same (or order a different?) belt?
Rick
Rickysa is offline   Reply With Quote
Old 05-07-2008, 10:23 AM   #2 (permalink)
markusfmeyer's Avatar
Date registered: Nov 2005
Vehicle: 86 300SEL Euro, 87 560SEC, 88 560SEC (parts car), 89 560SEL (running again!), 90 300SEL (parts car)
The V8's have separate belts, but the inline 6 just has the one serpentine belt. I wonder if you can just unplug the electrical connection for the air pump and still leave the regular belt on there. Or remove it and get the euro belt - my euro 300 has no air pump and hence a shorter belt.
markusfmeyer is offline   Reply With Quote
Old 05-07-2008, 11:03 AM   #3 (permalink)
Thanks for the reply Mark....I hadn't realized the difference re: V8 vs. V6
I don't believe unplugging would have any affect, as it does it all the time...large "clunking" noises as the pump turns while the engine is at temp...not just when cold.
Air/smog pump JimAB W201 190E, D-Class 1 11-26-2007 08:44 AM
Air/smog Pump/see Picture MBUSER W201 190E, D-Class 0 04-08-2007 12:07 PM
Smog / Air pump radunegru W124 E,CE,D,TD Class 0 03-28-2005 09:34 PM
Need HELP!!! Air / Smog Pump Removal TURBOAMG W201 190E, D-Class 1 03-01-2004 03:11 PM
Air (Smog) Pump Replacement Nehdad R129 SL Class 1 08-03-2003 07:33 AM
