Old 04-22-2008, 05:01 PM   #1 (permalink)
Date registered: Apr 2008
Vehicle: 1987 300SDL
300SDL noisy belt tensioner
At idle a loud tapping type sound comes from the belt tensioner. If engine speed increases to 1000 RPM, the sound goes away. If I push on the spring facing the passenger side I strongly feel the vibration, if I push hard the sound goes away.
I'm thinking the spring is weak and needs replacement.
gmarkisj is offline   Reply With Quote
Old 04-24-2008, 11:29 AM   #2 (permalink)
Upon further inspection, the belt tensioner damper (looks like mini shock absorber) is defective. It has lost it charge of oil or gas, since the piston moves quite freely.
Old 04-25-2008, 12:44 AM   #3 (permalink)
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6, bought 07/08 with 50k original miles.
They can be re build / re conditioned. The experts advise against after market tensioners, and recommend MB dealer only.
I tried an after market one, and threw it out when it stopped working properly after only a few month.
Have you tried a forum search?
Welcome, to take advantage of all the forum features, please make sure to read the 'Welcome to the Forum' tutorial sticky on top of the W126 page, as well as the two DIY stickies.
It will show how to search the forum (3 words min.), and has a link to the Russian MB site where you can run a VIN#. The forum archive has a wealth of information.
Cheers
Teutone is online now   Reply With Quote
Belt Tensioner Funkytuqe R129 SL Class 12 03-04-2008 08:39 AM
BELT Tensioner? 1990.300E W123 E,CE,D,CD,TD,TE Class 1 02-24-2008 06:46 PM
How to change the belt tensioner on '05 C230 K and where to buy tensioner??? Kevin Greene W203 C-Class 2 08-19-2007 08:51 PM
BELT TENSIONER??? smokiesman W124 E,CE,D,TD Class 5 04-03-2005 09:10 PM
re.. 1987 300SDL brake and tensioner problems whitemikefl W126 S,SE,SEC,SEL,SD,SDL Class 6 02-12-2005 06:47 AM
