Old 02-26-2008, 04:32 PM   #21 (permalink)
and007ca's Avatar
Vehicle: 1986 560SEC TT KS,1988 300CE,1990 560SEC 2nd GEN.KS.1990 560SEL AMG,1985 W126 [parts]
Originally Posted by HeirKranz View Post
Axel, thanks for the info--just have to find a decent radiator shop around here!
I would also like to give a special thanks to Blasphemous Mike for the information to help locate some important documentation on this vehicle as well as all those that helped contribute to this endeavor!
Remus! mmmmmmm--can't wait to get the engine in!
It's almost to nice to install it and get it dirty.Love to hear it
and007ca is offline   Reply With Quote
Old 02-27-2008, 09:27 AM   #22 (permalink)
HeirKranz's Avatar
Date registered: Oct 2002
Vehicle: 1982 500sec EURO AMG, 500sec convertible (euro swap) TWO 1984 US 500SECs, w203coupe, 300d, 500sel
ok, quick question--this car came with country horns that appear to be stock one on each side behind the bumper---where is the switch for these or do all 4 horns sound off at the same time--i have never had these?
also, what would a 1 inch rubber air tube from the side of the engine be doing going to connect right after the Cats and linked to both?? weird EGR setup, vent, or what? usually this vent system goes to the air pump right? JONO?
maybe the original euro setup had this venting to the air???
<img src=http://www.benzworld.org/forums/image.php?type=sigpic&userid=3031&dateline=1190977 839>
My convertible video http://www.youtube.com/watch?v=2ou4e0gMnd4
My w126 Pics http://www.benzworld.org/gallery/sho...&way=&cat=3415
My w203 Pics http://www.benzworld.org/gallery/sho...23/ppuser/3031
HeirKranz is offline   Reply With Quote
Old 02-27-2008, 11:26 AM   #23 (permalink)
Vehicle: 1988 420SEL
Some vechicles had air injector lines going to the cats for quicker warmup... but no idea why it would be connected after the cats. Probably a kludge to get those non-OE parts to work.
mhamilton is offline   Reply With Quote
Old 02-27-2008, 01:51 PM   #24 (permalink)
AxelWulff's Avatar
Date registered: Oct 2004
Vehicle: 1990 SEC
The usual place for the Country/City horn switch is above the coin tray, but some cars had the switch on the AC panel.
The switch is between only the horns in behind the grille, or both sets at once.
Regards,
Axel
1990 SEC, Arctic White w/gray interior, M119.960 326 Hp. engine from 1992 500 SL, 722.370 transmission from 500E (reinforced clutches), 2:82 Differential, Euro Headlamps, 1st Gear Start module, One-Touch Window module and Keyless Entry module all from BergWerks, Bilstein HD Shocks on front axle, H&R lowering springs front and rear, AMG 3-piece 17" rims, 8.5" in the front and 10" at the rear.
AxelWulff is offline   Reply With Quote
Old 02-28-2008, 05:18 AM   #25 (permalink)
johnhef's Avatar
Date registered: Mar 2007
Vehicle: 84-300TD-Euro 87-300D 80-500SE 82-380SEL 83-380SEC 84-500SEC 84-500SEC-Euro 86-560SEL-Carat 06-R350
Send a message via AIM to johnhef
Yeah, earlier ones had the horn switch above the acc unit.
johnhef is offline   Reply With Quote
Old 02-28-2008, 05:48 AM   #26 (permalink)
HeirKranz's Avatar
I'll have to look, Hef does your new sec have these? same year 82 right? Will be posting the factory options the car has as soon as I am able to get some time--It is off to Virginia Sunday though -- around Harpers Ferry, too bad I can't take the SEC for a drive through Shenandoah!
I believe I will be working on pulling the engine out of the 500SEL all day saturday in an attempt to get it set up in the blue one before I leave!
Old 02-28-2008, 07:05 PM   #27 (permalink)
johnhef's Avatar
hey you wont be far from here! gimmie a shout if you want to swing by. The 500 is at my shop but I have the 380 here still, its better then nothing
Mine is an 84, it's got the horn switch, second hole from the right above the climate unit.
I was thinking... On my euro wagon, it has the two sets of horns but no switch. I saw another euro wagon with the switch above the acc unit too and I suddenly realized- my wagon had a dealer installed A/C system, they put the compressor off/on switch in the slot where the horn on e was, so I'm betting I'll find mine behind that panel f I take it apart.
Did your car come with a/c or was it added? check behind that panel for an extra connector and you may find your switch.
Old 02-29-2008, 09:22 AM   #28 (permalink)
HeirKranz's Avatar
i haven't really messed with it but will look when i get home--PM me your number I'll be up there all week--what is the icon on the switch usually? anyone have a pic
Old 02-29-2008, 07:36 PM   #29 (permalink)
johnhef's Avatar
here's one, on a 123 but same switch.
Old 03-12-2008, 07:26 AM   #30 (permalink)
HeirKranz's Avatar
that's the one! I have it on my dash in about the same location--- right now it looks like the sec is one of those ghetto sleds with the engine removed--- all jacked up--- looks like Monday I might clean out the engine bay and start the restoration on the wires-- anyone know of a flexible shielding I can buy in bulk rolls to replace the cracked engine harness wires??? (other than that tubing crap they sell at auto zone?)
416 Restoration almost complete! unimogtom Unimog 7 02-08-2008 01:00 AM
Euro 500sec, U.S. 500sec and the 560sec...buy Q's... FloridaCole W126 S,SE,SEC,SEL,SD,SDL Class 14 10-31-2007 10:48 AM
500sec restoration project complete! Lots of pics!! SECdriver W126 S,SE,SEC,SEL,SD,SDL Class 73 03-12-2007 03:53 AM
500SEC restoration UPDATE 3! supermerc W126 S,SE,SEC,SEL,SD,SDL Class 7 08-01-2006 07:52 AM
500SEC restoration (progress after 3 weeks) supermerc W126 S,SE,SEC,SEL,SD,SDL Class 23 07-03-2006 10:14 PM
