Old 02-12-2008, 06:12 AM   #1 (permalink)
Date registered: Jun 2004
Vehicle: 300 SE 1991, 300 TE, ARMY JEEP M38A1 1967, Jaguar E-TYPE 1962, Bentley conv 1969
Question water temp sensor orientation
I am trying to change out the water temp sensor for the cis-e injection system on my 91 300se. The plug and sensor are both four pronged, but the plug seems to have a flat spot on its connector that would orientate it to the sensor prongs, and the neither the old sensor or the new one seem to have a mating flat spot. How does one know the oreintation to attach the plug to the sensor correctly? does the oreintation matter? it looks as though I could attach it any of 4 different orientations by spinning the plug 90 degs each attempt. thanks for your help
andytechinc is offline   Reply With Quote
Old 02-12-2008, 09:17 AM   #2 (permalink)
a3jeroen's Avatar
Date registered: Jun 2006
Vehicle: 1982 280 se aut. ecc. - sold
Please fill out your profile. You can do this by using the "control panel" button.
Members may be able to provide better help.
I don't recall this problem being covered, but our archives provide a wealth of info.
Did you do a forum search?
gr J
"Look for the ridiculous in everything and you will find it" Jules Renard
a3jeroen is offline   Reply With Quote
Old 02-12-2008, 09:51 AM   #3 (permalink)
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6, bought 07/08 with 50k original miles.
Welcome; Please make sure to read the 'Welcome to the Forum' sticky on top of the W126 page.
Teutone is online now   Reply With Quote
Old 02-12-2008, 10:41 AM   #4 (permalink)
Date registered: Nov 2004
Vehicle: 1991 420sel
orientation doesnt matter. There are 2 temp senders, both the same, and 2 grounds. The pins for the senders and grounds alternate, so no matter how the plug is put on both temp circuits sense the right resistance. Check the manual, I think you will find this specific info, plus the resistances for the temp senders so you can make sure the new one is good.
benzwag is offline   Reply With Quote
Old 02-14-2008, 06:43 AM   #5 (permalink)
Thanks
Thanks for the orientation info!
Water Temp Sensor... Jrs2000 W124 E,CE,D,TD Class 9 08-07-2007 09:15 PM
Replacing Water Temp sensor Erin W123 E,CE,D,CD,TD,TE Class 2 05-01-2005 09:49 PM
More water temp sensor questions......sorry Michael Pillay W126 S,SE,SEC,SEL,SD,SDL Class 0 03-05-2005 11:43 AM
Water Temp Sensor????? Michael Pillay W126 S,SE,SEC,SEL,SD,SDL Class 8 03-02-2005 12:23 AM
Water Temp ? TappedOut R170 SLK Class 3 10-03-2004 08:12 PM
