1991 560SEL: Do I have to fix the hydraulic fluid leaking / suspension problem - Mercedes-Benz Forum
post #1 of 39 (permalink) Old 01-28-2008, 01:49 PM Thread Starter
Date registered: Jan 2008
Hi
Foremost, I did see how to correct this problem. My question is really do I HAVE TO fix this?
My dad drives a 1991 Mercedes Benz 560 SEL (4 door sedan) with about 188,000 miles on it. He drives it about 30 miles a day (4 days a week) mainly on highway.
We noted that the hydraulic fluid reservoir was emtpy so he bought a can from the MB dealership and filled it up. We noted that it was empty again after few days.
I know the repair work can be costly. Since this is an old car and he does not want to put much, what is the harm if we do not fix the hydraulic fluid leaking issue? I am not sure of how the self leveling suspension works in the car. I am a an idiot when it comes to cars.
P.S. He is the only one who drives to work so there is not much that load on the car other than weight of the car and him in it.
The MB dealership simply said that it was bouncing a lot (just by pushing it up and down) when he bought the fluid. My dad just does not want to give them $150 for diagnosis and then get more bad news.
Thank you so much for your help and advice!!!!!
Raza
mukarram2000 is offline
post #2 of 39 (permalink) Old 01-28-2008, 05:30 PM
PAS
Date registered: Dec 2007
Vehicle: 1989 560SEL
Well the MB hydraulic fluid here at MB of Miami was $20.25/liter, so that will add up fast. If you let the hydraulic pump run dry it will need replacing $$$. There are not that many parts to the system, reservoir, pump, leveling valve (not sure of the official name), accumulators (air cells), and shocks. Either you have a leaky fitting somewhere or one or more of the parts has a leak. The parts are easy enough to have a look at see if you can find the leak. If not pay someone to do it for you dealer or independent. Pay a little now or a lot later.
I just replaced the accumulators on my car this weekend only took about 2 hrs, and the ride is a million times better.
Thanks,
Paul
PAS is offline
post #3 of 39 (permalink) Old 01-28-2008, 06:03 PM
Date registered: Apr 2007
Vehicle: Mercedes 420 SEL
You could also convert it to a regular shock system, still kind of spendy, but that could fall under general maintenance.
Just a thought.
guarddog is offline
post #4 of 39 (permalink) Old 01-28-2008, 06:48 PM
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6.
Quoted: 1015 Post(s)
Welcome. To take advantage of all the forum features, please re visit the 'Welcome to the Forum' tutorial sticky on top of the W126 page, as well as the two DIY stickies. It will show how to search the forum, and even has a link to the Russian MB site where you can run a VIN#. The forum archive has a wealth of information.
Teutone is offline
post #5 of 39 (permalink) Old 01-28-2008, 07:03 PM
markusfmeyer's Avatar
Date registered: Nov 2005
Vehicle: too many
If its leaking that much there should be evidence on the ground where its leaking, either in the front of the car where the reservoir and pump is, or towards the back of the car where the accumulators, valve and shocks are. Of course it could be in the lines from front to back, but again, with that much coming out that quickly, there should be evidence of where it is leaking pretty easily.
markusfmeyer is offline
post #6 of 39 (permalink) Old 01-28-2008, 07:39 PM
to loss's Avatar
Vehicle: 1982 300TDT 150,000 miles 1985 380SE 130,000 miles 1991 560SEL 81,000 miles (a/k/a the nightmare)
It's worth it to bring it to a shop after you've located the leak to bring it by your usual (hopefully well qualified mechanic who is very familiar with these cars and the hydraulic suspension system) to see how much it will cost to rectify... replacing a hose in one of our cars fixed our SLS problem... however, I think you'll be needing a bit more than that... good luck, and post some pics of where the car is leaking from, as some here might be able to help you with rough estimates...
"I don't think it's nice, you laughin'. You see, my mule don't like people laughing. He gets the crazy idea you're laughing at him. Now if you apologize, like I know you're going to, I might convince him that you really didn't mean it."
"I love the smell of diesel in the morning... smells like... like victory"
to loss is offline
post #7 of 39 (permalink) Old 01-28-2008, 08:33 PM
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: Depends on the day!
Quoted: 14 Post(s)
Send a message via AIM to jhodg5ck
I'm going to bet it's the high pressure line that's leaking.. 135 for the Real deal. Bit of a PITA to install around the US air pump, but not horrible.
Jonathan
Blue Ridge Mercedes/AMG East
Jonathan Hodgman
http://www.blueridgemb.com/
Enthusiast Service, Restoration & Tuning.
Authorized RENNtech Dealer & Installer
Follow Us on Facebook!
Located in the Atlanta area
87 Hammer Wagon 6.0L 32V
87 Hammer 6.0L 32V
86 560SEL AMG 6.0 32V
etc....
Mercedes Repair Atlanta
jhodg5ck is offline
post #8 of 39 (permalink) Old 01-30-2008, 02:31 PM Thread Starter
Thank you all for replying so quickly and so passionately.
However, my dad does not want to spend money UNLESS he ABSOLUTLEY has to. So perhaps I was not clear in my initial query as to:
What would happen if he does NOT fix hydraulic fluid leaking problem? Other than a smooth ride, would it be dangerous or would it lead to something damaging that would stall or destroy the car.
Apparently, he wants to drive the car till it stops driving (gasoline excluded ). He only wants to do oil changes for the next 4000 miles on the car.
Thanks again!
post #9 of 39 (permalink) Old 01-30-2008, 04:14 PM
Vehicle: too many
If that pump runs dry you will can ruin it which may lead to more trouble. It will also make the car harder to sell as well if that's what he is looking to do. If its just a hose, like Jonathan mentioned as a possibility, that isn't too much money to be spending as a fix, is it? Or, you can keep spending money on the fluid you are replacing but it sounds like that will add up quickly. Not to mention the compromised ride quality without a true working rear suspension.
post #10 of 39 (permalink) Old 01-30-2008, 08:07 PM
jhodg5ck's Avatar
Quoted: 14 Post(s)
To yank the system properly will mean removing the pump and adding a block off plate, purchasing new springs and new rear shocks.
Replacing the high pressure hose is a Lot cheaper.
Not fixing the SLS and driving around on it broken can as mentioned above cause the pump to seize which will Not be pretty as it is on the same drive as the distributor.
Also, w/o the aid of the SLS the rear will be Very bouncy and sag, thus eating the inside edge of your rear tyres..turning a 50,000 miles tyre into a 10,000 mile tyre if you're lucky. Never mind that when you do go over a bump or mid corner ripple the car will bounce repeatedly w/o the SLS system there to dampen the springs compression/rebound.
Either fix the system properly, or remove it in it's entirety. If neither of those options are viable sell the car and buy a Honda.
Jonathan
Jonathan Hodgman
87 Hammer 6.0L 32V
etc....
jhodg5ck is offline
    Adaptive Damping System (ADS) Hydraulic Suspension on a 1991 500SL... help... canuckcarnut R129 SL-Class 14 12-27-2014 10:00 PM
    Replacing 560SEL Suspension Leveling System Hydraulic Hose at Pump Famquat W126 S,SE,SEC,SEL,SD,SDL Class 6 03-25-2009 07:15 PM
    Lowered my 1997 SL600 , now it's leaking hydraulic fluid... BadassDmax R129 SL-Class 22 07-21-2008 05:20 AM
    Hydraulic Suspension fluid for sls in 300te jgilbert W124 E,CE,D,TD Class 5 03-02-2007 02:48 PM
    1991 300E 4Matic Hydraulic fluid leak mkrish07 W124 E,CE,D,TD Class 0 07-28-2005 07:07 PM
