Old 01-20-2008, 09:22 AM   #1 (permalink)
granit560's Avatar
Date registered: Dec 2007
Vehicle: 1987 560 sec impala metalflake over cream
what color? flexer or not
iv got an 87 560 sec. the hood & trunk are aluminum, cuz magnet wont stick! do they all have alum? as i want to paint the bumpers, i thought id maby paint the trunk& hood,being as the clearcoat is cracked.can i strip off just the clear? im planing touse flexer in the paint for bumpers, for the lids too? also im having trouble finding site with the color iv got. it was said to be a rare color(desert toup), cant find it!
granit560 is offline   Reply With Quote
Old 01-20-2008, 12:00 PM   #2 (permalink)
AxelWulff's Avatar
Date registered: Oct 2004
Vehicle: 1990 SEC
All the SECs had aluminium hoods and trunk lids. Its the sedans where it varies, some have steel, others have aluminium.
Desert taupe, a kind of golden beige, is not that rare and you should find the color on your car's ID card on the crossmember in front of the radiator. If you need a sample, just get a can of touch-up paint from your local MB dealer.
I'm not a paint expert, but I've been told that the MB paint process on our cars have 7 layers and an expert can buff off the oxydized top layer and bring "new" paint back.
In your case you'd have to remove the clear coat, buff up the base paint and then re-spray the clear. Not many paint shops that want to do that sort of work.
Regards,
Axel
1990 SEC, Arctic White w/gray interior, M119.960 326 Hp. engine from 1992 500 SL, 722.370 transmission from 500E (reinforced clutches), 2:82 Differential, Euro Headlamps, 1st Gear Start module, One-Touch Window module and Keyless Entry module all from BergWerks, Bilstein HD Shocks on front axle, H&R lowering springs front and rear, AMG 3-piece 17" rims, 8.5" in the front and 10" at the rear.
AxelWulff is offline   Reply With Quote
Old 01-21-2008, 06:30 PM   #3 (permalink)
granit560's Avatar
thanks
deciding on paint color, interior color...etc. go in and give me your opinion. 560se W126 S,SE,SEC,SEL,SD,SDL Class 9 01-06-2006 11:55 AM
Is this an original color for a '85 300D??? I love the color combo!!! jtoma878 W123 E,CE,D,CD,TD,TE Class 15 09-02-2005 05:13 PM
would the light gray soft top color look good w/ charcoal metallic body color? foreyes R129 SL Class 1 01-02-2005 02:04 PM
does anyone knows the color code for the red color in the interior dash i need it asap? orlando R170 SLK Class 2 10-12-2001 09:09 AM
With all this talk of color, what color would you choose from the complete MB lineup? Me: Techtite. Norb R170 SLK Class 15 08-03-2001 03:46 AM
