Old 01-08-2008, 09:43 PM   #1 (permalink)
Date registered: Sep 2006
timing chain guide rail pin stuck ......
i have a 91 560 sel . i am doing the timing chain/ guide rail job that i hear soo much about on here . most of the pins have come out just fine . the one that is giving me a problem is the one on the bottom of the tensioner guide rail . i removed the little plug , but that little bastard pin does not want to slide out . its kinda funny how all of the alleged "tough ones" came out just fine . any help would be greatly appreciated !
mustangman1992 is offline   Reply With Quote
Old 01-08-2008, 11:27 PM   #2 (permalink)
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6, bought 07/08 with 50k original miles.
Welcome, the 2 DIY threads above have a number of write ups on your problem.
Also, the forum archives have a wealth of information, and the search function on the top right of the W126 page will accept two words, try 'rail pins.' To re visit the 'Welcome to the Forum' tutorial sticky will help you take advantage of the forum's features.
Teutone is online now   Reply With Quote
Old 01-09-2008, 12:22 AM   #3 (permalink)
mckellyb's Avatar
Date registered: Sep 2007
Vehicle: '89 420 SEL, 142K
What's happening? Is your bolt bottoming out in the pin?
I found a tap from the auto parts store was well worth the $4 so they'd have threads all the way to the 'bottom'. Made a huge difference when trying to get two nasty ones out.
Kelly B
'89 420 SEL, almost bone stock, 144K miles
Wife's ride: '02 Lexus RX300 AWD, all the options but a hitch, 69K miles
'99 Fleetwood Bounder Diesel 39Z diesel pusher motorhome, which has visited 10 Canadian provinces and 49 states under our ownership, 117K miles and many modifications
mckellyb is offline   Reply With Quote
Old 01-09-2008, 07:18 AM   #4 (permalink)
its the pin at the bottom of the tensioner guide rail , the big, metal backed , banana shaped one . i cant get that pin to slide out . the problem is that there are no threads to grab on to inside of this pin. its not supposed to be pressed in . everyone just says it slides out . mine does not seem to want to budge .
Old 01-09-2008, 07:59 AM   #5 (permalink)
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: 1991 560 SEC
Send a message via AIM to jhodg5ck
Take an appropriate sized flat head screw driver, one that will slide all the way throgh the pin. Heat the tip, bend it over giving you a small 5-7mm tip. Let that cool and you should be able to hook it from the back and pull the bugger out.
Jonathan
Blue Ridge Mercedes/AMG East
Offering Enthusiast Service, Restoration and Tuning.
Providing quality parts to enthusiasts all over the world.
Located in the Atlanta area
96 S600 Euro
91 560SEC ECE (for sale)
91 560 SEC 226/271 Undergoing TT conversion
88 300E AMG
89 190E 2.6 5sp
89 300TE (Mosselman TT waiting..)
88 560SEC AMG Euro ECE (parts)
89 560SEC AMG mech. lifter/68K rpm conv.
87 Hammer 6.0L 32V
86 560SEL AMG 6.0L 32V[/url]
jhodg5ck is offline   Reply With Quote
Old 01-09-2008, 09:22 AM   #6 (permalink)
Date registered: Dec 2003
Vehicle: 1989 300SE, 1989 420SEL, 1965 220S, 2002 Ford Crown Vic Police Interceptor
When I did my 420SEL, I used a pair of needle nosed pliars to get the barrel pin out. Move the chain guide back and forth to help in removing it. It's a loose fit.
Near Manassas Va. '89 300SE, 2002 Ford Crown Victoria Police Interceptor, 89 420SEL
Had '65 220SE, 67 230S, 72 280SE 4.5 Dad had '65 300SE LWB, '65 220SE
"Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive." C.S. Lewis
wbain is offline   Reply With Quote
Old 01-09-2008, 09:37 AM   #7 (permalink)
jhodg5ck's Avatar
Sometimes they get covered in goo making it a Very tight fit.. that's what led me to making the above tool from an old screw driver.. Rarely they can be a Real PITA..!!
Jonathan
Old 01-09-2008, 12:22 PM   #8 (permalink)
thanks for all of the great replies ! i will let you guys know how it turns out .
Old 01-09-2008, 09:16 PM   #9 (permalink)
jonathan - your idea worked great !! even with the home made tool i still really had to put alot of force into it .. thank you sooo much !!
Old 01-09-2008, 09:26 PM   #10 (permalink)
jhodg5ck's Avatar
No problem..I use it all the time..
Glad it worked for you!
Jonathan
Broken Timing Chain Guide Rail.. HELP! Rokkett450SL R/C107 SL/SLC Class 2 07-08-2007 03:17 PM
Oil pump chain guide rail Rollingstone W126 S,SE,SEC,SEL,SD,SDL Class 1 08-22-2006 11:35 AM
Timing Chain Guide Rail BNZ W126 S,SE,SEC,SEL,SD,SDL Class 3 03-23-2006 07:15 AM
3.0 Timing Chain Guide Rail Evan W124 E,CE,D,TD Class 5 11-01-2005 02:33 PM
Timing Chain Guide Rail Replacement Litton W126 S,SE,SEC,SEL,SD,SDL Class 1 12-02-2002 09:43 PM
