Old 10-02-2007, 03:51 PM   #1 (permalink)
Date registered: Mar 2007
Vehicle: Mercedes 420 SEL
Oil pressure ok after oil change????
Ok, so finally got around to changing my oil today--a bit overdue, but not too bad.
Pull out old filter put in new--happy to say the oil plug was not cross threaded, so all is good. Button it all up--AND steady oil pressure.
Before, the needle was bouncing all over the place. After some work to it, and fixing some vaccum lines that had golf tees in them, the oil pressure was better, but still bouncing a bit.
Now, rock steady.
Weird...
guarddog is offline   Reply With Quote
Old 10-02-2007, 10:14 PM   #2 (permalink)
a3jeroen's Avatar
Date registered: Jun 2006
Vehicle: 1982 280 se aut. ecc.
Prob. the new filter did the trick!
gr J
"Look for the ridiculous in everything and you will find it" Jules Renard
a3jeroen is offline   Reply With Quote
Old 10-03-2007, 06:58 AM   #3 (permalink)
I was thinking maybe the rubber o-ring might have been bad, causing a vacuum leak? Possible?
Ok, oil pressure gauge was rock steady. Found a vacuum leak in my brake booster line, taped it up until i can get a replacement... Idle dropped, and now the oil pressure gauge is haywire again.
Maddening...
Old 10-03-2007, 07:46 AM   #4 (permalink)
zviratko's Avatar
Date registered: Jan 2007
Vehicle: W124 400E
Send a message via ICQ to zviratko Send a message via Skype™ to zviratko
This is normal and is caused both by the oil filter letting the pressure through and different parameters of the oil.
I switch brands of oil quite often and every batch behaves differently, sometimes it's a steady 3, sometimes it drops to 1.5... sometimes after 7000 miles it starts dropping to 2 and sometimes it doesn't.
Usually a freshly changed oil holds a steady 3 bar.
zviratko is online now   Reply With Quote
Poll: mileage between oil change / brand of oil / DIY or dealer ?? Thanks! Rohf (Seattle) R170 SLK Class 27 08-05-2008 07:58 PM
Oil Change in 81 240d cause lack of power and lower oil PSI? Cobb2 W123 E,CE,D,CD,TD,TE Class 12 07-15-2008 10:51 PM
Oil Pressure drop after oil change???? threepoint1415926 W124 E,CE,D,TD Class 22 05-12-2004 09:05 AM
oil pressure and oil temp sender NickT G-Class 6 09-03-2002 09:42 AM
oil exceeds max warning....i get this everytime i get an oil change with 8.5 qrts..is that too much. concerned W208 CLK Class 2 10-21-2001 05:56 PM
