» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W126 S,SE,SEC,SEL,SD,SDL Class
Old 01-06-2009, 01:35 AM   #91 (permalink)
some random dude...
420 SE's Avatar
Date registered: Sep 2005
Vehicle: 1988 420 SE
Send a message via Skype™ to 420 SE
replacing ignition tumbler
http://www.benzworld.org/forums/w126...n-tumbler.html
Ross
Politicians are like baby's nappies - they both need to be changed often, and for much the same reason.
OzBenz
beware of fundamentalists
420 SE is offline   Reply With Quote
Old 02-03-2009, 08:29 PM   #92 (permalink)
some random dude...
420 SE's Avatar
Electrical Manual - Gen 2
http://www.benzworld.org/forums/w126...ng-manual.html
Old 03-06-2009, 12:13 PM   #93 (permalink)
Huntrtylr's Avatar
Date registered: Jan 2009
Vehicle: 1982 500SL AMG "Darmstadt Branch"
Repairing Painted Wheel Curb Scratches
Repairing Painted Wheel Curb Scratches - Autopia.org
1982 500SL AMG Schwarz (040) Schwarz (231) "Fully Documented"
"JACQUELINE"
Huntrtylr is offline   Reply With Quote
Old 03-11-2009, 07:52 PM   #94 (permalink)
Aspect's Avatar
Date registered: Jun 2004
Vehicle: 1987 420SEL
722.3xx secondary pump removal and replacement
http://www.benzworld.org/forums/3356515-post2.html
Aspect is offline   Reply With Quote
Old 04-21-2009, 09:46 AM   #95 (permalink)
Huntrtylr's Avatar
SUSPENSION ISSUES and COMMON REMEDIES
 Left and right lower ball joints Common Symtoms: High pitched squeal when turning.
 Upper control arms with ball joints Common Symtoms: Looseness and clunking
 Upper control arms rubber bushings Common Symtoms: Front end shake and looseness
 Steering Tie Rods (Replace as a set of two) Common Symtoms: Loose steering
 Wheel bearing kit Common Symtoms: Howling noise especially when turning - wheel shimmy
 Lower Support / guide rod mount (same part 2 required) Common Symtoms: Clunking when braking
 Lower control arm to frame inner bushing kit Common Symtoms: Wandering front end - excess tire wear
 Lower control arm Eccentric bolt kit Common Symtoms: Difficult to maintain front end alignment
 Guide rod to lower control arm mount kit Common Symtoms:Clunking or looseness when braking
 Guide rod Common Symtoms: Bent from accident
 Idler arm bushing repair kit Common Symtoms: Looseness and squeaking in steering
 Front shock absorbers (replace as a set of 2) Common Symtoms: Bouncing front end - diving while cornering
 Center Steering Drag Link Rod Common Symtoms: Looseness in steering
 Steering Shock Common Symtoms: Steering feels unstable
 Steering Box Common Symtoms: Wandering Steering
 Flex Disk Symptoms: Possible Steady Floor Vibration on Highway
 Non-Hubcentric Spacers Symptoms: Wheel Vibration at high speeds
 Tires & Tire Balance Symptoms: Vibration -----Recommend a Hunter Forced Wheel Balance. Google for Info.
Old 05-05-2009, 06:10 PM   #96 (permalink)
johnhef's Avatar
Date registered: Mar 2007
Vehicle: Too Many
Send a message via AIM to johnhef
SLS Block Off Plate etc. part numbers
Originally Posted by MrBits View Post
Hbro111 - just for posterity can you post that part# ? I searched 4-5 different phrases without finding it, even by including johnhef's sig. Adding the part# here should make it pop-up better in the future.
Plate: 116-015-02-09
Gasket: 117-015-00-80
Bolt: 001-990-93-12 (x4)
GWS-MBCA Vice President
Join Us! I am #H013278
1980 500SE/AMG Euro
1981 300SD - parts car
1981 500SEL Euro
1982 380SEL
1983 380SEC
1983 500SEC/AMG Euro
1984 500SEC - parts car
1984 300TD Euro
1986 190E 2.3-16
1986 560SEL/Carat
1987 300D
1991 300D 2.5
1997 C36 AMG
johnhef is offline   Reply With Quote
Old 05-22-2009, 04:02 AM   #97 (permalink)
some random dude...
420 SE's Avatar
water pump R & R
http://www.benzworld.org/forums/w126...-pump-r-r.html
Old 05-24-2009, 06:15 AM   #98 (permalink)
markusfmeyer's Avatar
Date registered: Nov 2005
Vehicle: too many
Front suspension rebuild:
markusfmeyer is offline   Reply With Quote
Old 06-13-2009, 03:12 PM   #99 (permalink)
ElRojo's Avatar
Date registered: Jul 2005
Vehicle: 1990 560 SEL
Parts list for Idle Air Supply lines 420/560 engines
I put together this list after responding to several threads for "lumpy idle". If you have never had these items replaced, they are 18+ years old by now and probably brittle. A potential source of vacuum leaks too. An easy DIY to replace in an hour or so. If you go further and replace the injector seals and holders (also recommended if they are original), add another hour plus. Replacing the injectors at the same time adds no more time, but it does add to the cost. Attached list is from AutohausAZ (I wanted to credit their format).
Best-
Dave
File Type: pdf 073-215 removal, reinstallation of injection valves.pdf (57.3 KB, 64 views)
1990 560 SEL, 150K. Smoke silver (702) on Champignon ("mushroom") leather (265). Euro headlights, euro amber turns and tails, pushbutton FGS, blacked out grille, Pioneer headunit w/ Polk db650 rears/doors, db1000 fronts, rear "dummy" lights activated as brake lights, 35% bronze tints, 15" 8-hole wheels, keyless entry system.
1983 300SD, 106K. Orient Red (501) on Java MB tex (154). SOLD
ElRojo is offline   Reply With Quote
Old 06-20-2009, 01:44 AM   #100 (permalink)
some random dude...
420 SE's Avatar
EFI conversion
JoeSEC's thread here
http://www.benzworld.org/forums/w126...on-thread.html
diy thread miki_com_au W126 S,SE,SEC,SEL,SD,SDL Class 10 05-29-2009 09:19 AM
Do It Yourself (DIY) repair thread W124/300E GHM W124 E,CE,D,TD Class 9 05-28-2009 06:40 PM
Symmetrical tyre, asymmetrical thread - is it acceptable for ML? Alex L W163 M-Class 0 07-01-2008 08:45 AM
W126 Diy Thread BILLSONG Test 4 08-31-2006 03:15 PM
Not another WHEEL thread, but a SPACER thread Kalifornia W126 S,SE,SEC,SEL,SD,SDL Class 7 07-30-2006 03:06 AM
