Holly carburetor on a W126 - Mercedes-Benz Forum
post #1 of 23 (permalink) Old 08-24-2007, 09:10 PM Thread Starter
GotTheBenz's Avatar
Date registered: Sep 2005
Vehicle: '82 380SEC, '74 280S
I have a friend who has a 1985 500 SEC. He's planning to replace his Bosch CIS fuel injection system with a Holly carburetor + amenities. Is this really possible? If so, how easy would it be, because I would certainly love to get rid of this fuel injection system....too much trouble, IMO.
GotTheBenz is offline
post #2 of 23 (permalink) Old 08-24-2007, 10:10 PM
lander91's Avatar
Date registered: Oct 2005
Vehicle: "500"sel, 560sec
not cheap, but give near 50 more hp.
File Type: jpg my_old_engine_one_way_to_do_things.JPG (105.2 KB, 4938 views)
"500"sel - M117.968 --> M119.960 conversion, standalone LinkPlus ECU (linkecu.com) tuned to ~260kw, full dual 2.25" mandrel bend exhaust, AMG 2nd Gen full body kit & interior mods, Bilstein HD's and custom springs. 17" SSR wheels 8.5J front 9.5J rear (235, 255 tyres)
560sec - I hate sec's
You're unique, just like everyone else.
lander91 is offline
post #3 of 23 (permalink) Old 08-24-2007, 10:29 PM Thread Starter
GotTheBenz's Avatar
I love how simple looking the engine begins to look. What's it look like with the carburetor? How did you replace the fuel lines and injectors? and where did you get that intake manifold (is it custom made?) Sweet ride, eh? Any pics with the AMG kit?
post #4 of 23 (permalink) Old 08-24-2007, 10:39 PM
lander91's Avatar
The inj holes where welsh/frost plugged, the water crossover gallery has been replaced with the part form the standard intake manifold you can just cut it off with a bandsaw (you see here two threaded fittings but this didnt allow enough flow). Fule pump is a holley blue, fuel lines are left stock only with the addition of an adjustable fuel regulator and the appropriate length hoses to the carb.
The car has hot cams, mechanical lifter conversion with 130lb(i think) Beehive springs now and high compression with custom Tri y extractors into a twin 2.5" exhaust that exits ouit the side in fron tof the rear left wheel well. It idles like a beast and the torque twist when its revved is phenominal. All reciprocating parts have been lightend and ballanced as has the flywheel, it can rev up to 7400rpm and has put out just a tad over 400Hp.
lander91 is offline
post #5 of 23 (permalink) Old 08-25-2007, 07:43 AM
mramay's Avatar
Date registered: Feb 2005
Vehicle: '87 570SEC (FrankenBenz) '87 560SEL (Lisa), '87 560SEC (Bling)
Quoted: 175 Post(s)
Beautiful intake assembly!
FYI - those maroon chain guides are the proper color for a failure that is about to occur soon. HIGHLY recommend getting them out of the engine. Check your cam timing and if it's out of tolerance (5 degrees), then (pun intended) it's time for a new chain and tensioner.
Blasphemous Mike
US '87 560SEC with Euro headlights, clear markers, H&Rs, 18x8.5, ATE slotted rotors with semi-metallics, BergWerks FGS, 3.07 Limited Slip.
In progress - FrankenBenz SEC: GM LS6 5.7L engine with custom 4L60E 4-spd overdrive transmission, GM rack and pinion.
One of my goals with the FrankenBenz is to scare women and children, and to have Lexus drivers spill their latte.
mramay is offline
post #6 of 23 (permalink) Old 08-25-2007, 07:56 AM
Vehicle: 1990 Mecedes-Benz 420SEL
Good eye, Mike!
Dave
dave420 is offline
post #7 of 23 (permalink) Old 08-25-2007, 09:54 AM
allnpt0's Avatar
Date registered: Mar 2006
Vehicle: 1983 380SEC: 1995 S600 Coupe: 1993 600SEL
Smile Awesome intake
Who made the intake? I would love to have one for my 500 motor. I've got a Demon carb that would be perfect for that setup.
allnpt0 is offline
post #8 of 23 (permalink) Old 08-25-2007, 11:29 AM
Cirrus2's Avatar
Date registered: Oct 2006
Vehicle: 1982 300CD|1998 GMC Sierra 2500 6.5 Turbo Diesel|2008 Chevy Cobalt 2.2L DD
Quoted: 16 Post(s)
Send a message via Yahoo to Cirrus2
Wow, I woudl Love that too.. ALSO has anyone fitted A Mallory or MSD Ignition system on a w126?? I am looking to do it but have no idea where to start..
1982 300CD (motor and trans from an '83)
Adjusted ALDA|Rebuilt Garrett Turbo W/60 Trim Compressor Side(13PSI)|Half Boxed Intake W/Catch Can And K&N|
Depo Euros|Full 3IN Turbo Back Exhaust|EGR Block|Monark Injector Nozzles|
1998 GMC 6.5 Diesel 4X4
Heath Lift Pump|Marine Injectors|Gauges|Performance Chip|AFE Intake|
4in Exhaust To 6in Stack|GM8 Set To 15psi| Way Too Much More!
SOLD AND MISSED:
85' 380SE
83' 500SEL
Cirrus2 is offline
post #9 of 23 (permalink) Old 08-25-2007, 12:46 PM
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: Depends on the day!
Quoted: 16 Post(s)
Send a message via AIM to jhodg5ck
MSD's are a waste of $$ unless you are running a seriously tweked engine, ie, like landers or one w/ forced induction. It's on my black coupe and the only thing I've found it good for is going through cap/rotor's quicker then usual. Prob. for around what the carb/intake runs one could do a MS II Conversion and have true stand alone EFI/Ignition. Jonathan
Blue Ridge Mercedes/AMG East
Jonathan Hodgman
http://www.blueridgemb.com/
Enthusiast Service, Restoration & Tuning.
Authorized RENNtech Dealer & Installer
Follow Us on Facebook!
Located in the Atlanta area
87 Hammer Wagon 6.0L 32V
87 Hammer 6.0L 32V
86 560SEL AMG 6.0 32V
etc....
Mercedes Repair Atlanta
jhodg5ck is offline
post #10 of 23 (permalink) Old 08-25-2007, 01:18 PM
The Doggfather's Avatar
Date registered: Aug 2006
Vehicle: 1986 Mercedes-Benz W126 560 SEL
What size is your Demon?
The Doggfather is offline
Oh, holly hell I'm gettin' a 600!! SVanHorne W140 S-Class 12 12-04-2005 11:06 AM
Carburetor BILLSONG Benzworld Site issues forum 0 11-05-2005 06:40 PM
carburetor fugu W201 190-Class 1 05-23-2005 11:55 PM
w123 carburetor jing280ce W123 E,CE,D,CD,TD,TE Class 9 12-21-2004 09:04 PM
Holly Iceberg Batman…(long post) Peter Schneider W163 M-Class 33 12-20-2001 07:33 AM
