My car has a problem, I noticed both my camshafts were worn down and that I should probably replace the towers(camshaft bearings) and rocker arms at the same time. Car currently makes the ticking sound.
I then contacted the nearest mercedes mechanic and over the phone he told me that this happens because something else is wrong with the car. He said if you fix it the same will probably happen again. Is that true? Has anybody else had this situation before.
I have about 183K miles on the beast. Jonathan my timing chain rails tensioner are in superb shape. So do you think that I should replace the items or go with a better used engine installed with labor for $3500
Thanks
I'm not much of a used engine fan unless you get the full books and records from the car it came from.. You're just buying into an unknown qty. w/o testing/inspecting etc, etc.
With that in mind I'd prob. replace the cams if everything else was/is in good shape.. How was your hot oil pressure @ idle?
Would be a great time to swap to hot cams/headers;-)
