» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W126 S,SE,SEC,SEL,SD,SDL Class
Closed Thread
Old 04-18-2007, 09:28 AM   #21 (permalink)
Date registered: Apr 2007
Vehicle: Mercedes 420 SEL
why are we overlooking the PCV which recirculates blowby and oil vapors? thats 100x more oil than a properly oiled K&N is inducing..
As you said, not an issue since there isn't a MAF. On a car with a maf, however, the PCV is routed after the MAF, so it wouldn't contaminate it.
I take it the K&N issue is like talking about synthetic or non-synthetic oil.
guarddog is offline
Old 04-18-2007, 05:52 PM   #22 (permalink)
NüR-SPEC's Avatar
Date registered: Jul 2006
Vehicle: EURO 500SEL
yes, PCVs are routed after the MAF on an EFI motor, but the blowby/oil causes valve deposits, and generally just coats the interior of the plenum, runners, ports, throttle, and vlaves with coke. the K&N vs paper filter isn't a debate for me. there's absolutely nothing wrong with a Hengst/Mann filter for your daily driver. and there also nothing wrong with a K&N either. i feel like syn vs dino is a matter of new school and old school. some people are so dead set on the factory recomendations, while overlooking useful modern technology.
NüR-SPEC is offline
Old 04-18-2007, 08:22 PM   #23 (permalink)
BenzWorld Elite Host
cyberdrakon's Avatar
Date registered: Dec 2002
Vehicle: 560SEC(1990) CLK500(2005) SLK55 (2006)
Send a message via AIM to cyberdrakon Send a message via MSN to cyberdrakon
mbcoupes member tested the K&N on dyno, resulted in a loss of 5 hp. Anyway, i beleive paper to filter better anyway, and i'd rather not get my hands dirty with the damn oil.
BTW. My K&N is for sale, used and dirty, but good condition otherwise (lifetime warranty?) $25 + shipping. get your own oil. PM me.
eddie aka cyberdrakon aka drakon
rexaccelero.com widebody slk 55 AMG
cyberdrakon is offline
Old 04-18-2007, 08:31 PM   #24 (permalink)
Date registered: Feb 2007
Vehicle: 300SD
This is the first time I ever saw anybody trying to sell a used K&N filter.
And I take an exception to the statement that K&N filters filter just as good as paper filters. I saw plenty of evidence that disputes that.
p100 is online now
Old 04-18-2007, 08:53 PM   #25 (permalink)
bgoin's Avatar
Vehicle: Classic 92 190E 2.6
Originally Posted by Batou
thanks for the input!
i'm getting the k&n from kragen tomorrow... i just needed to use the car today to run errands.
So without the filter, did you notice any increase in HP?
bgoin is offline
Old 04-18-2007, 10:22 PM   #26 (permalink)
NüR-SPEC's Avatar
a loss of 5hp? peak hp means nothing to me. where's the dyno sheet? i bet there were gains of 5hp all throughout the powerband and probably a boost in torque too. when it comes down to it, if you just replace your factory filter with a K&N that is the same exact dimensions, your not changing a whole lot aside from the filtration material. i don't care what anybody says, but i think the factory airbox is pretty damn restrictive. ditching it and using a K&N with a positive source of ambient air will give you a noticeable kick in the pants. and if you don't like K&N filters, then don't use them. just don't spew myths about what you've heard and base your opinion on other peoples BS they pulled outta thier arse without a valid study to back it up. many people have been using K&N filters for decades with no issues. (aside from EFI MAF contamination) when used with carbs, CIS, or MAP you can have a reliable, effective filter that will last for years.
NüR-SPEC is offline
Old 04-19-2007, 05:29 AM   #27 (permalink)
Date registered: Aug 2006
Vehicle: 1980 380 SE (Euro)
not really anything major, but i DID notice a faster throttle response time, and it seemed like it was pulling slightly more... i think it might have been the placebo effect though.
but yea, the throttle response and nice engine growl weren't my imagination ;]
Batou is offline
Old 04-20-2007, 07:44 PM   #28 (permalink)
bgoin's Avatar
So obviously the K&N filter is not going to increase the HP.
bgoin is offline
Old 04-21-2007, 12:59 AM   #29 (permalink)
well, i didn't dyno my car with a woman's panties hanging out of my airbox...
it's all personal opinion, let's not too rowdy shall we?
Batou is offline
Old 04-23-2007, 06:06 PM   #30 (permalink)
I'm not 'spewing myths'. it wasn't a CONTROLLED study, but it was back to back filter test between the two filters. K&N on, OEM on. you can find the dyno charts yourself in the mbcoupes archives. the difference between 2 filters IS ALL ABOUT the material versus the amount of surface area. OEM has a LOT more surface area and has a better gasket. the HP/TQ changes varied at different RPMs, however there was no significant advantage with either, at a 5 hp loss at peak.
Based on the quality of MY K&N i would say any gain in airflow is probably from the gaps between gasket and the airbox from careless installation (the filter is stiff and the gasket is even stiffer, hard to align properly against the lid). The only time the K&N would have an advantage is that it can be cleaned frequently at no significant cost, versus the paper, which needs to be changed out. I would guess the K&N companies own tests are clean freshly oiled K&Ns versus dirty clogged paper filters.
Anyway Nurspec, you can take your bad attitude and stuff it up your dirty #(&$*.
Closed Thread
FS: 3.2 V6 (etc) OEM air filter, oil filter Mann, Mahle ashman78 For Sale, Trade & Wanted Items 2 06-26-2006 07:49 AM
Engine air filter and cabin air filter life tempoct R170 SLK Class 2 05-03-2005 10:01 PM
Dirty air filter/bad mass air flow sensor 4benzes W163 M-Class 1 01-05-2005 05:49 AM
Hello, is an open air filter for mercedes slk 200k or 230k?? I mine so a filter, how k&n... devil R170 SLK Class 12 02-04-2003 10:43 AM
Air filter and driving through deep water! Steve (Austria) W163 M-Class 2 09-02-2002 08:04 PM
