» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W126 S,SE,SEC,SEL,SD,SDL Class
Old 03-12-2007, 11:12 PM   #11 (permalink)
S_Class_Don's Avatar
Date registered: Jul 2005
Vehicle: 89' 300SE 80' 240D
Originally Posted by dennisB
Damm ... wrong Jugs!
yeah i got that impression too lol!
Euro Headlights/Corners
Optima Battery {Red}
Alpine Head Unit
MB Quart Component Door And Rear Speakers
2 Alpine Type S 12's W/ A Alpine Amp At 1000W X 1
Earl J...
S_Class_Don is offline   Reply With Quote
Old 03-13-2007, 02:42 AM   #12 (permalink)
BNZ
Date registered: Jan 2006
Vehicle: SEC
Originally Posted by strife2
I
I'll know that you are obsessed when you do the water pump and power steering pump I did.
What kind of preparation to only paint them ?
BNZ is offline   Reply With Quote
Old 03-13-2007, 02:52 AM   #13 (permalink)
Jukka L.'s Avatar
Vehicle: Euro 1989`500 SEC "Buffalo soldiers edition"
Nice!!
Jukka L. is offline   Reply With Quote
Old 03-13-2007, 07:27 PM   #14 (permalink)
mercedesman91's Avatar
Vehicle: 91 420 SEL
so if i spend lots of time... and lots of help from my friends i can get valve cover like that.... hmm seems very much worth it to me.. just making a fine automobile even finer! and i think my water pump is starting to go so i spose before i throw a new one in i will make it look nice... and whats the best thing to do for my intake cover.. its all pitted like... i dont like it like it like that since i am going to do the valve covers.. what an awesome idea.. what different grit disks did you use.. and also how fast did your sander spin? i can't wait to get this doneee!!
Erik J. L.
91 420 SEL w/a 5.6 V8
89 300 TE Wagon
99 E 320
previous
95 C 280
93 190 E 2.3
95 E 320
mercedesman91 is offline   Reply With Quote
Old 03-13-2007, 07:54 PM   #15 (permalink)
DarkOneSK's Avatar
Date registered: Feb 2007
Vehicle: 1985 500 SEC, 2005 E320
slow speed drill sander. used 220 grit to start. then a light hand sand with 400 the rest was all metal buffing wheels.
If your air filter is pitted, you may want to get a new one. they aren't very thick. if the pits are not very deep, don't sand it. just use the buffer wheels as described. Sanding the air filter with anything but 400 hand paper or steel wool is a no-no. I only used a sander on the valve covers to sand down the imperfections which were always there from new. They never intended for them to be buffed, so, they weren't really critical on the smoothness. The air filters were made fairly perfect new, and only require steel wool and a buffing wheel. the kit I used to do this was bought here.
Caswell Inc. - Aluminum & Copper Alloy Polishing Kit
DarkHorse Automotive... We Don't Do Cute...
Constantly in pursuit of perfection
DarkOne's 1985 500SEC Lots of pics!
Detailed pictoral of restoration here.
Watch Her Take Off!
Euro headlights, Viper & key less entry, 2.5" Flowmaster exhaust HEAR IT. new vid as of 5-19-07, no cats, KYB Sport Shocks, Intrax lowering springs, 3.06:1 rear. 25% tint, Too much 2 list.
DarkOneSK is offline   Reply With Quote
Old 03-14-2007, 01:02 AM   #16 (permalink)
strife2's Avatar
Date registered: Jul 2004
Vehicle: 560SL,380SL
One little additional comment: when you do these parts, clean them REALLY THOROUGHLY after they are done, inside and out, with engine cleaner, and then let them rince with water and dry. All this buffing stuff is grit, after all, and you do not want this to get into the engine.
_________________________
Homebrew MB First Gear Start!
http://juliepalooza.8m.com/sl/mercedes.htm
strife2 is offline   Reply With Quote
Old 03-14-2007, 12:24 PM   #17 (permalink)
DarkOneSK's Avatar
Here are some before and after shots of the engine and my buffing and cleaning frenzy.
Day 1. Clean with Simple green (BIG MISTAKE) and Gunk engine degreaser Gel (Safe alternative)
Day 2: Valve covers, as posted on page 1
Day 3: Detail engine with mothers protectant, buffing wheels, sand paper, steel wool, emery cloth, and wire brushes.
Old 03-14-2007, 12:43 PM   #18 (permalink)
DarkOneSK's Avatar
and here's another higher rez photo
Before: Note everything is a whitish corroded mess after cleaning.
After: Man that sucked to polish.
A Nice high res image. If this image is lagging people. let me know and I'll take it off
Old 03-14-2007, 04:33 PM   #19 (permalink)
AzimuthAviation's Avatar
Date registered: Apr 2006
Vehicle: 1982 380SE AMG euro(parted out),1983 300SD "Good Girl", 1984 500SEL AMG euro "Bad Girl"
THE CORROSION WAS THE SIMPLE GREEN!!!
You've done a great job. That CCA has got some serious bling factor to it! I doubt I could ever put that much effort under the hood. I'm usually too pooped from cleaning the outside to want to wander into polishing anything most people won't see. It's kinda like the house. The front is always mowed and edged but I might skip the backyard a week or two! Again, looks great!
AzimuthAviation is offline   Reply With Quote
Old 03-14-2007, 09:00 PM   #20 (permalink)
DarkOneSK's Avatar
Yeah yeah. I know better now. The simple green was a mistake. Thanks for the compliments though. Keep checking back. I'm gonna use this thread for my ongoing work on this car.
Check engine electronics, Check oil level.+ others bondale W210 E-Class 5 11-10-2006 01:02 AM
Check your door Check! dvdguy W140 S-Class 1 10-12-2005 08:50 AM
Check these out ThrillKill W208 CLK Class 2 08-22-2005 02:49 PM
Any help removing pin holding door check strap? I want to replace a loudly creaking check. Brett San Diego W140 S-Class 4 08-25-2004 02:57 PM
Check out this auction, this MB owner needs to check out the SLK32 :) kenny R170 SLK Class 0 10-28-2001 12:33 AM
