1986 MB 420 SEL Start Problem - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 02-18-2007, 08:27 PM Thread Starter
Date registered: Feb 2007
Vehicle: 2007 E350, 2006 E350, 2003 C230K. Previous: 89 420 SEL, 87 300E, 92 190E, 91 190E
Send a message via AIM to kunleade Send a message via Yahoo to kunleade
I recently bought this '86 420 SEL with 174K miles. It wouldn't start, which is one main reason the previous owner sold it. I had a feeling it would not be a big problem...
Turning the ignition key, you could hear something making some noise in the engine compatment. The fan blade would roll, but car wouldn't start. Going through several forums, I had a feeling the problem was related to the fuel delivery system...
I put some gas in the carburetor and the car started briefly and then died...
Taking out the fuel pump relay and smelling it, you can smell that it got burnt.
From the forums, I decided to jumper ports 30 and 87 on the fuel pump relay. The car started right away. I left the relay on and the following morning it appears the battery went dead. Put in a replacement battery and the car started again. Right now, I have the defective fuel pump relay out of the car so it wouldn't run down the battery again. Will get replacement from a MB dealer anytime soon.
Kunle
kunleade is offline
post #2 of 9 (permalink) Old 02-19-2007, 01:53 AM
wbain's Avatar
Date registered: Dec 2003
Fuel pump relay problems are a common problem. Take the cover off and resolder all the connections especially the larger ones. Vibration causes the joints to break. Save money, $0.00 in cost to you.
wbain is offline
post #3 of 9 (permalink) Old 02-19-2007, 10:17 PM Thread Starter
Thanks. I might try just that.
Kunle
kunleade is offline
post #4 of 9 (permalink) Old 02-20-2007, 03:43 PM
Date registered: Jan 2007
Vehicle: Mercedes-Benz 1987 420SEL
Thumbs up
I have the same problem. Can you please tell me how to take the cover off?
Uli73 is offline
post #5 of 9 (permalink) Old 02-20-2007, 03:50 PM
talbir's Avatar
Date registered: Dec 2004
Quoted: 2 Post(s)
In the fuse box on pre 86 cars and in front of the brake booster on post 85 cars.
It has the label 'kickdown' on it.
talbir
Mercedes w124 500E 1993 Black 040
Mercedes w124 500E 1993 Spruce Green
Mercedes AMG 560SEC 1988
Mercedes AMG DOHC M117 w126 AMG Widebody SEC 1985
Mercedes 560SE Carat Duchatelet 1987
Mercedes w126 SEL Brabus
Mercedes w124 T Brabus
Porsche 911 Turbo SE Slantnose 1986
Mercedes 560E - w124 5.6 DOHC 360bhp by Stratton
Ferrari 328 GTS Quattrovalvole 1986 Koenig Widebody
Porsche 928 S4 by Strosek, Supercharged 550bhp
Mercedes 190E AMG Widebody
Mercedes SEC by Gemballa 6.9
talbir is offline
post #6 of 9 (permalink) Old 04-12-2008, 09:06 PM
Date registered: Apr 2008
Vehicle: 1986 mercedes 420 sel
i've got a 1986 420 sel that will run sometimes but recently will not. when it doesnt run its not geting fuel cuz it starts if i pour gas in the intake for a few secs. i was wondering what it could be and how to tell what it is. im debating between the fuel pumps or the fuel pump relay is what i think also how did you jumper the relay?
dylandominick_13 is offline
post #7 of 9 (permalink) Old 04-12-2008, 09:59 PM
Aspect's Avatar
Date registered: Jun 2004
Vehicle: w126
Quoted: 38 Post(s)
You just pull the relay out of the socket and place a jumper wire between terminals 30 and 87(see above) in that socket.
Aspect is offline
post #8 of 9 (permalink) Old 04-13-2008, 12:09 PM
okay that worked to get it started but if the throttle is put to the floor it acts like its staving for fuel because it only revs up to 4000 rpms and will not go any higher with very little power. i was wonder since it has two fuel pumps could one of them be bad only giving enough fuel to start the car? how do the fuel pumps run? one at low gas need and both at high need or do they both always run? thanks
post #9 of 9 (permalink) Old 04-13-2008, 08:30 PM
chinny4290's Avatar
Date registered: Aug 2005
Vehicle: '94 E320 Coupe W124 (RIP) - '75 280S W116 - '11 Honda Accord Coupe V6 6-Spd (DD)
Carburetor?
I'm confused...I thought M116s were CIS-E....
chinny4290 is offline
    1986 420 sel Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 10 05-23-2008 08:05 PM
    considering buying a 1986 420 SEL Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 5 05-23-2008 01:33 PM
    420 SEL 1986 HELP PLEASE SoFlor00 W126 S,SE,SEC,SEL,SD,SDL Class 9 11-18-2004 12:40 AM
    1986 420 SEL on Ebay Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 6 04-16-2004 11:41 PM
    I have some questions my 1986 420 SEL teradule W126 S,SE,SEC,SEL,SD,SDL Class 5 08-29-2003 03:30 AM
