Old 01-29-2007, 06:01 PM   #1 (permalink)
Date registered: Feb 2006
Vehicle: 1983 300SD
Why can't I find the right winter motor oil for my 83 300SD?
Owners manual indicates motor oil of 10w-30 for winter use, yet it seems even at the tractor supply shops the closest I can find is 15w-30.
For those of you with the older diesels, what are you running and where are you finding it? I don't want to put off oil changes just because I can't find the right oil.
I don't know why this is so confusing and so hard to find the right oil. It's almost enough to make me want to go back to petrol.
Thank you.
hubsocket is offline   Reply With Quote
Old 01-29-2007, 06:19 PM   #2 (permalink)
S_Class_Don's Avatar
Date registered: Jul 2005
Vehicle: 89' 300SE 80' 240D
Thank you.
advance auto...auto zone...walmart?
Euro Headlights/Corners
Optima Battery {Red}
Alpine Head Unit
MB Quart Component Door And Rear Speakers
2 Alpine Type S 12's W/ A Alpine Amp At 1000W X 1
Earl J...
S_Class_Don is offline   Reply With Quote
Old 01-29-2007, 08:46 PM   #3 (permalink)
mssdoglover's Avatar
Vehicle: 1986 300SDL 311,500
Send a message via AIM to mssdoglover
I'm running Rotella dino 15w40 year-round... the absolute coldest I'd EVER expect for my area is above zero by a few degrees, and even that is in an astonishing winter... for winter use in colder climes, I'd use Rotella 5w40 or something like that, just a tad thinner for the cold but not much different. They're not too picky.
Michael S.
86 300SDL *329,500 miles *
"I am a firm believer in psychology when it agrees with my own opinions."
mssdoglover is offline   Reply With Quote
Old 01-30-2007, 02:31 PM   #4 (permalink)
Date registered: Jun 2004
Vehicle: 1984 300 SDC, 1983 300 SDC, 1985 300 SD,
I use 0W40 synthetic in my Diesels in the winter time, night and day difference starting in the cold, I havent needed my block heater yet. Im up here in Canada btw.
Icefire is offline   Reply With Quote
Old 01-30-2007, 03:43 PM   #5 (permalink)
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6 (50k original miles)
BTW, you can edit / add the car mod and location to your personal profile to the left of your post. Cheerio
Teutone is offline   Reply With Quote
Old 01-30-2007, 07:43 PM   #6 (permalink)
Vehicle: 83 300sd
You have to make sure you get diesel oil like Rotella or you'll kill your engine.
Also you can't run 0w-4o in NJ as it gets too warm here for that.
hooligan is offline   Reply With Quote
Window Motor, 82 300SD mwrluthier W126 S,SE,SEC,SEL,SD,SDL Class 1 01-20-2007 11:53 PM
Where do I find a 83-85 300sd F.S.? mbsd For Sale, Trade & Wanted Items 1 06-05-2006 10:13 AM
where i can find the motor number? miguelmachado W208 CLK Class 1 02-25-2006 05:21 AM
Where to find rebuilt 300SD engine ? 4amStudios W126 S,SE,SEC,SEL,SD,SDL Class 5 04-23-2004 06:17 PM
85 300SD has worn engine . Any advice on where to find low milage motor ? 4amStudios W126 S,SE,SEC,SEL,SD,SDL Class 7 04-04-2004 08:40 PM
