Old 12-18-2006, 07:20 PM   #1 (permalink)
Date registered: Jun 2004
Vehicle: 560SEC
camshaft
Hello forum,
Just wanted to ask how do you tell if your cams need replacing. I have mechanic who says mine are to flat and they should be more rounded like a cone. How much is reasonable price?
lyrics10 is offline   Reply With Quote
Old 12-18-2006, 07:24 PM   #2 (permalink)
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: 1991 560 SEC
Send a message via AIM to jhodg5ck
Are you going with stock or aftermarket? hot or standard grind?
Jonathan
Blue Ridge Mercedes/AMG East (temp down!)
Offering Enthusiast Service, Restoration and Tuning.
Providing quality parts to all parts of the world.
Located in the Atlanta area
96 S600 Euro
91 560SEC ECE (for sale)
91 560 SEC 226/271 Undergoing TT conversion
89 190E 2.6 5sp
89 300TE (Mosselman TT waiting..)
88 560SEC AMG Euro ECE (parts)
89 560SEC AMG mech. lifter/68K rpm conv.
87 Hammer 6.0L 32V
86 560SEL AMG 6.0L 32V
jhodg5ck is offline   Reply With Quote
Old 12-18-2006, 07:25 PM   #3 (permalink)
NüR-SPEC's Avatar
Date registered: Jul 2006
Vehicle: EURO 500SEL
are there aftermarket companies who make cams for the merc V8s???
TUNINGGRüPPE.COM
NüR-SPEC is offline   Reply With Quote
Old 12-18-2006, 07:31 PM   #4 (permalink)
jhodg5ck's Avatar
Estas, TRW, Lemforder...I forget who else.
Jonathan
Old 12-18-2006, 07:39 PM   #5 (permalink)
NüR-SPEC's Avatar
whaaat!?! i never knew this.. probably won't pass emissions with any kind of overlap over stock, though.. got links to distributors of these bumpsticks?
Old 12-19-2006, 01:47 AM   #6 (permalink)
Vehicle: 560SEC
I want to go with the application that gives me more performance. What do you think?
Old 12-19-2006, 01:52 AM   #7 (permalink)
Vehicle: 560SEC
Hey jonathan are the camshafts suppose to be more cone shaped at the tips, mine seem to be more flat. Could you explain how it should look like. Thanks
Old 12-19-2006, 05:46 AM   #8 (permalink)
NüR-SPEC's Avatar
this cone shape is called the "lobe". the lobe can wear down from insufficient lubrication to the valvetrain. i can't imagine the factory camshaft wearing down like that. if you had pics of it, i'm sure we could diagnose it better.
Old 12-19-2006, 12:01 PM   #9 (permalink)
Date registered: Nov 2006
Vehicle: 1983 Mercedes Benz 380 SEC
Send a message via MSN to lilbilly11
I had a mechanic tell me that my camshafts were the cause of my 380sec running rough and "misfiring", he claimed it had nothing to do with my plugs and wires and I could change all kinds of parts but if I didn't replace those it would still run the same. I never had him do the work, he also told me $1000 to fix my heating issues when it was only the monovalve (simple, low cost repair), so I don't plan on going back to him anymore either.
lilbilly11 is offline   Reply With Quote
Old 12-19-2006, 01:20 PM   #10 (permalink)
NüR-SPEC's Avatar
well, i've seen n00bs ruin a new cam by improperly torquing the bearings or not using an engine assembly lube (or equivalent) during initial startup, but i've never seen flat spots. when a scandelous "mechanic" sees a merc pull up, they have dollar signs in thier eyes.
Camshaft longevity isobars W126 S,SE,SEC,SEL,SD,SDL Class 0 03-09-2006 11:15 PM
Camshaft specs Splas W126 S,SE,SEC,SEL,SD,SDL Class 1 03-08-2005 05:47 AM
camshaft broke raylee R129 SL Class 0 10-11-2004 11:18 PM
Camshaft question. Neo420 W126 S,SE,SEC,SEL,SD,SDL Class 11 01-21-2004 08:54 AM
Bent Camshaft naomilla W126 S,SE,SEC,SEL,SD,SDL Class 8 01-18-2004 06:38 PM
