Old 09-27-2006, 11:42 PM   #1 (permalink)
Date registered: Sep 2006
420sel idle speed control valve?
Thanks guys , I'm new to the world of Benz.
Got 118K on a 91. It starts fine but stalls about 10 seconds later.
I checked Idle Speed control valve.A plastic tube runs between the two rubber hoses, but one end of the tube is closed.Is this correct?What gives?.
embee2 is offline   Reply With Quote
Old 09-28-2006, 07:51 AM   #2 (permalink)
Date registered: Nov 2004
Vehicle: 1991 420sel
Hi--The problem is unlikely to be the idle air valve. It is normal for the little plastic cross tube to have one end closed. MB found that the open tube made it too hard for the valve to keep the idle speed down and so closed it. Just the way it is. If the car is starting it probably has enough air. You could disconnect the idle air valve (2-pole connector) which should have the effect of making it idle at about 1300 rpm. If it is starting but dying, it sounds like the cold start valve is getting gas but there is a problem with fuel delivery to the injectors. Get the manual on CD's, cheap from MB now, and read up on the system. Charlie
benzwag is offline   Reply With Quote
Old 09-29-2006, 02:47 PM   #3 (permalink)
Also there is a thread today on the exact same subject where problem appears to be intermittent power to fuel pumps, either FPR or fuel pump or wiring.
Old 03-07-2007, 07:42 PM   #4 (permalink)
Date registered: Mar 2007
Dies
hello:just a thought went thru same problem with my 560 sel.stalled after engine temp reched 80,degrees.turned out to be fuel pump relay.my brother has a 420sel.so we took his out tried on mine.ditto car runs great..good luck.
car560sel is offline   Reply With Quote
Hard start (esp. when Cold), low idle-- Idle Control Valve? Erwin8r W124 E,CE,D,TD Class 10 09-26-2006 11:33 AM
Idle Speed Control and Idle Valve triskaideka W126 S,SE,SEC,SEL,SD,SDL Class 4 09-02-2006 02:36 AM
Idle Valve Control Derrick W124 E,CE,D,TD Class 3 02-23-2004 01:16 PM
idle control valve jimery W126 S,SE,SEC,SEL,SD,SDL Class 0 11-22-2003 11:49 AM
idle control valve vs idle control unit Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 1 04-15-2002 12:38 PM
