Installed new fuel pump - pictures - Mercedes-Benz Forum
post #1 of 22 (permalink) Old 08-07-2006, 09:42 AM Thread Starter
Ramesh's Avatar
Date registered: Apr 2003
Vehicle: 1990 Mercedes 560SEL
Thanks to all of you who advised me. I went to my friend Mike's place. He had an empty parking lot behind his apartment. We put the rear wheel on ramps. Mike is very experienced in working with Boeing planes. He did almost all the work, while I assisted him. Had some misadventures. Got fuel showers. But changed the fuel pump. We took step by step pictures. See a few pictures attached to this message. May be I should write up some thing. If Dan Watt is interested, I can put it up on his website. Thanks once again to all of you guys. All comments and suggestions for a future fuel pump change are welcome.
Ramesh.
ID:	94520   Click image for larger version
ID:	94521   Click image for larger version
ID:	94523   Click image for larger version
Ramesh is offline
post #2 of 22 (permalink) Old 08-07-2006, 09:51 AM Thread Starter
Ramesh's Avatar
New Fuel Pump and Filter
Here are pictures of the new Bosch Fuel Pump and Mercedes Fuel Filter that we put in. I bought the fuel pump from AutoHaus for around $90 each. The fuel filter from the dealer for around $59.
Ramesh.
ID:	94525   Click image for larger version
Ramesh is offline
post #3 of 22 (permalink) Old 08-07-2006, 10:06 AM
allerton's Avatar
Date registered: Jul 2006
Vehicle: 1990' 560SEL
looks like there are two fuel pumps, and you replaced one?
1990 560SEL @200500miles
Chassis: 126.039
Engine: 117.968
Tranny: 722.350
Columbus, OH
http://mbw126.com
allerton is offline
post #4 of 22 (permalink) Old 08-07-2006, 10:18 AM Thread Starter
Ramesh's Avatar
Hi Allerton,
I replaced both the pumps. Check this picture.
Ramesh.
Ramesh is offline
post #5 of 22 (permalink) Old 08-07-2006, 10:47 AM
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1046 Post(s)
Nice work
DP is offline
post #6 of 22 (permalink) Old 08-07-2006, 10:56 AM
Date registered: Jan 2006
Vehicle: 1987 420SEL, 1987 560 SEC 2003 CL 55 AMG
Originally Posted by Ramesh
Hi Allerton,
Ramesh.
Great camera work and the job looks well done. I am ready to change both of mine for peace of mind. Why did you change yours?
Just wondering if the car can run on one pump. Why is there 2 pumps? Anybody know?
Thanks
Cheelyv is offline
post #7 of 22 (permalink) Old 08-07-2006, 11:03 AM
danwatt's Avatar
Date registered: Aug 2004
Vehicle: 1990 300SE
Send a message via AIM to danwatt
Needs two pumps to maintain the correct pressure for CIS to function at higher speeds. I may put it on my site, thanks!
danwatt is offline
post #8 of 22 (permalink) Old 08-07-2006, 11:06 AM
Thanks for the tech tip danwatt!
Cheelyv is offline
post #9 of 22 (permalink) Old 08-07-2006, 12:49 PM
lander91's Avatar
Date registered: Oct 2005
Vehicle: "500"sel, 560sec
a little tip, when doing work on the fuel system disconnect the power to the pumps and crank the engine, this will get rid of the fuel still in kept in the lines by the residual pressure valve.
"500"sel - M117.968 --> M119.960 conversion, standalone LinkPlus ECU (linkecu.com) tuned to ~260kw, full dual 2.25" mandrel bend exhaust, AMG 2nd Gen full body kit & interior mods, Bilstein HD's and custom springs. 17" SSR wheels 8.5J front 9.5J rear (235, 255 tyres)
560sec - I hate sec's
You're unique, just like everyone else.
lander91 is offline
post #10 of 22 (permalink) Old 08-07-2006, 02:32 PM
guage
Guest
Posts: n/a
Quoted: Post(s)
Good stuff
    Changed my fuel pump to fix my fuel gauge, and got an added BONUS. mikewired W163 M-Class 15 03-04-2012 08:52 AM
    fuel air mix / testing fuel pumps and pump pressure william.wood W126 S,SE,SEC,SEL,SD,SDL Class 0 11-09-2005 11:32 AM
    380sel where is the fuel pump fuse? have no power to pump meggala W126 S,SE,SEC,SEL,SD,SDL Class 3 08-02-2005 03:44 AM
    leaking hand pump vs fuel pump benzmeover W123 E,CE,D,CD,TD,TE Class 4 01-30-2005 07:36 PM
    Pictures of my pre-2000 Slk fuel pressure regulator installed................ Linh R170 SLK-Class 2 08-05-2002 12:47 PM
