» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W126 S,SE,SEC,SEL,SD,SDL Class
Old 08-04-2006, 12:52 PM   #1 (permalink)
Ramesh's Avatar
Date registered: Apr 2003
Vehicle: 1990 Mercedes 560SEL
Jacking up the car for fuel pump change
How much do I lift the car for a fuel pump change? If I drive the front wheels up the Rhino ramps - will there be enough space for me to work on the fuel pump? Or is it possible to drive the rear wheels up the Rhino ramps?
Should the passenger side rear wheel be removed? (In this case I will have to use a jack and jack stand). Let me know.
Ramesh.
Ramesh is offline   Reply With Quote
Old 08-04-2006, 01:32 PM   #2 (permalink)
drewprof's Avatar
Vehicle: 560SEL, 190E
You should have enough space if you drive up the ramps. O don't see why not. The fuel pump and filter are located on the opposite side of the muffler.
I replaced my rear hydraulic system for the suspension using the ramps.
You will need a lot of light and an open lid bucket to receive the gasoline. Make sure that the light source is away from the fumes and use florescent
drewprof is offline   Reply With Quote
Old 08-04-2006, 02:55 PM   #3 (permalink)
Ramesh's Avatar
Hi Professor,
Thank you for the info. I will get you pictures of the fuel pump change. Are you seriously going to sell your car?
Ramesh.
Old 08-04-2006, 03:23 PM   #4 (permalink)
AMG junkie / W126 mod
Dr.Grillz's Avatar
Vehicle: 1990 Mercedes-Benz 560SEL and 1991 Mercedes-Benz 190E
Send a message via AIM to Dr.Grillz Send a message via MSN to Dr.Grillz Send a message via Skype™ to Dr.Grillz
I have not changed a fuel pump myself, but do know that its located near the rear right wheel. You may also want to put a jack on that side and remove the wheel to give you better access. Any time putting a car on jacks/ramp... be very careful and double check everything. The last thing you want to experience is a W126 lying on top of you.
Gen II European conversion : AMG conversion
1991 Mercedes-Benz 190E AMG
Dr.Grillz is offline   Reply With Quote
Old 08-04-2006, 03:28 PM   #5 (permalink)
drewprof's Avatar
Yes I was about to do it but everyone in here and in OT have convinced me otherwise. Another saved w126 I guess. I am going to put a new cat converter and cross my fingers that it will pass.
I will not be able to put in the car using ramps I am sure. So It's going to mechanic that has a lift. His labor and the cat's price should add up to the waiver value for a cycle exemption if it fails again.
One thing I am hoping for after all, is that I notice a major performance appreciation from a new cat, that would be a bonus.
Old 08-04-2006, 07:14 PM   #6 (permalink)
Kalifornia's Avatar
Date registered: Nov 2005
Vehicle: 1987 420SEL
I don't think driving your FRONT wheels onto a ramp alone is going to do anything for you, quite the contrary. You should have enough space to do it by jacking up the rear without removing the wheel...unless you are 300 pounds, of course. Use fuel precautions, and I would suggest you have a couple of plugs handy for the fuel lines as well as a basin. I think it's a good idea to change out both fuel pumps while you are at it and to use new OEM parts as they are relatively cheap when bought under list.
All that being said, I just watched my mechanic do it on the side...switched out both, took about 15 mins max.
Kalifornia is offline   Reply With Quote
Old 08-04-2006, 08:34 PM   #7 (permalink)
Date registered: Jun 2006
Lifting the front will makes things more difficult. Back up on the ramps or just jack up the rear of the car a couple of feet. Fuel pumps and filters are no big deal. Just use common sense when working with fuel. Make sure you pinch off the main feed hose from the tank other wise you WILL have a big mess. If in doubt take it to the shop, it honestly takes less than 1/2 hour.
Dave D is offline   Reply With Quote
Old 08-04-2006, 10:20 PM   #8 (permalink)
500MPL's Avatar
Date registered: Jan 2004
Vehicle: 1984 500 SEL euro, 1989 560 SEL, 1980 450 SL, 1981 DeLorean
You will need to jack the rear of the car and absolutely use jack stands for your safety. You will also need hose clamp pliers for the fuel lines or you will have the entire contents of your tank drain out.
Be safe and be cautious while handling open fuel lines.
Regards,
500MPL is offline   Reply With Quote
Old 08-04-2006, 10:40 PM   #9 (permalink)
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: 1991 560 SEC
Send a message via AIM to jhodg5ck
what ashley said..You want the rear of the car up as high as possible. Be sure to remove the gas cap before venturing forth. Ideally I like to run the cars WAY down on the reserve...less potential energy trying to make it's way out..
Jonathan
Blue Ridge Mercedes/AMG East
Jonathan Hodgman
http://www.blueridgemb.com
Enthusiast Service, Restoration & Tuning.
Providing quality parts to enthusiasts all over the world.
Located in the Atlanta area
97 C36
96 S600 Euro
94 E420 (Parts)
93 300SE
93 500E (Parts)
91 E300D 2.5
91 560SEC ECE
91 500SL Jap Spec
91 560SEC 226/271
88 300E AMG
89 190E 2.6 5sp
89 300TE
88 560SEC AMG Euro ECE (Parts)
89 560SEC AMG solid lifter
87 Hammer 6.0L 32V
86 560SEL AMG 6.0L 32V
jhodg5ck is offline   Reply With Quote
Old 08-05-2006, 01:31 AM   #10 (permalink)
jdc1244's Avatar
Date registered: Jun 2003
Vehicle: 1991 300 SE
Exclamation Disconnect the battery before you start.
There is a possibility you may need to replace the rubber lines if they are original.
Good luck and be careful.
1991 300 SE (w126.024/M103.981) 140,000 miles
jdc1244 is online now   Reply With Quote
Fuel pump stays on AFTER I shut off the car! HELP! FatTony W126 S,SE,SEC,SEL,SD,SDL Class 3 09-05-2005 03:29 PM
Attempted Car Jacking hang_man R171 SLK Class 47 07-04-2005 07:48 AM
Car will not start, no power to Fuel pump NewMBie W126 S,SE,SEC,SEL,SD,SDL Class 5 05-13-2005 01:31 PM
Car dies - O2 sensor or fuel pump relay? boucha W201 190 Class 3 05-31-2004 10:48 PM
Fuel Pump? Car wont start? Guest (MBNZ) W201 190 Class 6 05-05-2002 05:59 PM
