300SD: Fuel return line size? - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W126 S,SE,SEC,SEL,SD,SDL Class
Old 08-03-2006, 11:19 PM   #1 (permalink)
Vehicle: 1991 190e 2.6, 1984 300sd, 1982 VW Caddy (diesel) 1974 BMW-2002 (pending s14 swap)
Hello,
Does anyone know the ID of fuel return lines on the injectors for a 1984 300SD? Mine are leaky, I want to replace but couldn't find what size hose to get anywhere. Also, is it a high pressure hose or will any ordinary fuel hose of the correct diameter work ok?
And has anyone done a write-up on how to replace the motor mounts on a w126? Our's has 250K on it and it's a bit clunky in that respect. The car is pretty new to me.
TIA.
getouttamyway is offline   Reply With Quote
Old 08-04-2006, 12:52 AM   #2 (permalink)
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6, bought 07/08 with 50k original miles.
Check out the online manual: http://mb.braingears.com/126_DISC2/program/matrix.htm . As far as I know, all that needs to be removed is the radiator shroud. A good source for parts/motor mounts is autohausaz (free shipping on orders over $ 50 and good prices). You'll need a strong enough bottle jack or full size floor jack (2 1/2 to 3 ton, with a piece of wood under the oil pan). Don't forget to block the wheels. Have a look at the DIY thread above, it has lots of DIY write ups and the link to the official mbusa service CD's for only $ 20. Also click on the 'search this forum' box on the top right, and type in your question. It will get you all write ups on the topic from the archives. To include your car mod and location in your profile would makes it easier to offer advise. Here are two more links for info: http://www.*****************/Wikka/DoItYourSelf http://www.mbcoupes.com/w126index.htm ........... Good luck.
Teutone is offline   Reply With Quote
Old 08-04-2006, 09:00 AM   #3 (permalink)
Great, thanks for the links. I have the 2 CD set from ebay... not so helpful. Does Bentley make a manual for the w126?
As for the fuel lines, I just need to replace the fuel return lines from the injector, I wouldn't imagine upsizing those lines would affect performance at all. And I need the lines to fit over the little barbs on the injectors, so I need to make sure I get a snug fit on there.
Old 08-04-2006, 11:07 PM   #4 (permalink)
CH4S Artist
Teutone's Avatar
The $ 20 official Mercedes Benz USA service manual on 2 CD's is very helpful when downloaded to hard drive with Steve Nervig's free search index. With the index you'll be surprised how much intormation there is. The links are in the DIY. These are non ebay.
Old 08-05-2006, 01:37 AM   #5 (permalink)
Ok, for the record the fuel return lines from the injectors are 3.2mm, (or 1/8") ID. I got 3 feet of the line at the local Mbz shop for $5 and no more leaky injectors. Took like 20 minutes with a pair of needle nose pliers and a pair of scissors. The old lines were noticably brittle compared to the new lines, they practically crumbled when I tugged them off.
The car is already turbo charged and running on recycled vegetable oil cut with 20% gasoline, I don't expect this 120hp 3,800 lbs automatic beast to ever go fast... I just want it to be pretty and be a reliable 2nd car. I think i'll slap on my e-codes next weekend.
I'll check out the DIY threads and figure out how to work out all the kinks on this car, one by one! Thanks for the help.
Old 08-05-2006, 01:45 AM   #6 (permalink)
haha yeah.. if it wasn't diesel it would be a different story. If this diesel motor ever craps out though... you better believe I'll be looking for a 5.6L v8 to drop in there.
Old 05-20-2010, 10:08 PM   #7 (permalink)
Renntag's Avatar
Date registered: May 2010
Vehicle: 1986 300SDL, 1983 300TDT, 1982 300SD, 1987 300TDT
Send a message via Skype™ to Renntag
Any suggestion where to find these 2 cd's and search index?
~Colin
'83 300TDT '86 300SDL '87 300TD '98 E300
Renntag is offline   Reply With Quote
Old 05-21-2010, 05:01 AM   #8 (permalink)
Rmac58's Avatar
Date registered: Nov 2007
Vehicle: '83 300SD-daily driver '84 300CD-weekend car
The ones from MBUSA have sold out. I understand MercedesManuals.com has 'em, albeit for $40.00, it's on sale!
Mercedes-Benz 300 SD, 300SDL, 300 SE, 300 SEL, 350 SD, 350 SDL, 380 SE, 380 SEL, 380 SEC, 420 SEL, 500 SEL, 500 SEC, 560 SEL, 560 SEC 1981-1991 Repair Manual
'83 SD-daily driver
'84 CD-weekender!
Rmac58 is offline   Reply With Quote
Bookmarks
Fuel line - braided return lines MBeige W123 E,CE,D,CD,TD,TE Class 24 07-24-2008 12:06 PM
300SD fuel line replacements sack W126 S,SE,SEC,SEL,SD,SDL Class 2 04-13-2006 05:13 PM
No fuel pressure at Injectors or return line consumidor W201 190 Class 10 01-07-2006 06:11 PM
SLS return line(s) Clatterpastor W126 S,SE,SEC,SEL,SD,SDL Class 2 12-02-2005 03:56 AM
SLS pressure/ return line repair esde W123 E,CE,D,CD,TD,TE Class 5 08-21-2005 02:09 AM
