» Site Navigation
» Other Sites
Old 07-24-2006, 07:13 PM   #1 (permalink)
Kalifornia's Avatar
Date registered: Nov 2005
Vehicle: 1987 420SEL
Not another WHEEL thread, but a SPACER thread
Gentlemen,
I went to the scrap yard today to pick up a "new" condenser and saw a wrecked w124 300CE with nice 16" RS90 Lorinser chromes sitting there. I know, I know...anticipating another "w124 to w126" rim question, the crowd moans in anguish. But hark!
These turned out to be LK 112, 7.5 wide, ET 35 so AS WE ALL KNOW, I will need spacers for those to fit, but for 200 bucks for the set I could not wait for the answer to the question and had to bag them, stat.
Now, I am wondering what spacers to get and what a good place to order from would be. Also, if I should go with 10mm ones to make it back to stock offset, or bring the wheels out ever so slightly to fill out the wheel wells a little. From prior threads I assume that 15mm spacers would still be reasonable and that either way, "hub-centric" ones are the way to go. Should I go screw-on or screw-through, and will I need new lug nuts for either technique and size?
Pretty much, I'd like to hear your valued opinions and experiences.
Basic info: I am currently running OEM 15", my front fender lips are rolled (I guess per factory), and my suspension setup I assume to be all stock.
Thanks in advance!
Kalifornia is offline   Reply With Quote
Old 07-24-2006, 11:08 PM   #2 (permalink)
~BANNED~
MBZER's Avatar
Vehicle: 560/sel/sec/Jag XJS
Originally Posted by Kalifornia
Gentlemen,
Thanks in advance!
You said it all.
(Screw through)
MBZER is offline   Reply With Quote
Old 07-25-2006, 12:05 AM   #3 (permalink)
danwatt's Avatar
Date registered: Aug 2004
Vehicle: 1990 300SE
Send a message via AIM to danwatt
Spacers that small should be fine. Just be wary of the brand. I've heard plenty of great things about H&R spacers.
Here is a set of 15mm H&R spacers in Long Beach
http://orangecounty.craigslist.org/pts/174863753.html
danwatt is offline   Reply With Quote
Old 07-25-2006, 01:42 AM   #4 (permalink)
BenzWorld W126 Host / Mod
Snibble's Avatar
Vehicle: 1988 300SEL(RIP) / 1990 560SEL /1991 190E 2.0
Send a message via AIM to Snibble Send a message via MSN to Snibble Send a message via Skype™ to Snibble
I could have sworn I saw Lorinser 10 or 15mm spacers on ebay not long ago.
Page with AMG & W126 items for sale: Page link
1990 Mercedes-Benz 560SEL
1991 Mercedes-Benz 190E (undergoing restoration: July 1 - October 1, 2008)
Snibble is offline   Reply With Quote
Old 07-25-2006, 02:55 AM   #5 (permalink)
Kalifornia's Avatar
Yeah, I am kinda shooting for H&R ones after a little online research.
I did see the Lorinsers on eBay, but they're 7mm...might be cutting it a little close at ET 28. Or???
Old 07-25-2006, 04:33 AM   #6 (permalink)
AxelWulff's Avatar
Date registered: Oct 2004
Vehicle: 1990 SEC
The 7 mm Lorinser spacers could work. The rims are only 7" wide so an offset of 28 mm should be fine.
The wheels would look a whole lot better with the 15 mm spacers though.
You may need new lug bolts, at least with the 10 or 15 mm spacers.
To ensure that your wheels are on correctly the bolts must be able to do 10 full turn in the mounting plate. The 39 mm standard shank is not long enough for both the wheels and the spacer.
Regards,
Axel
1990 SEC, Arctic White w/gray interior, M119.960 326 Hp. engine from 1992 500 SL, 722.370 transmission from 500E (reinforced clutches), 2:82 Differential, Euro Headlamps, 1st Gear Start module, One-Touch Window module and Keyless Entry module all from BergWerks, Bilstein HD Shocks on front axle, H&R lowering springs front and rear, AMG 3-piece 17" rims, 8.5" in the front and 10" at the rear.
AxelWulff is offline   Reply With Quote
Old 07-25-2006, 12:47 PM   #7 (permalink)
mramay's Avatar
Date registered: Feb 2005
Vehicle: '87 570SEC & '87 560SEL
Originally Posted by AxelWulff
---snip---
In addition, watch the amount the lug bolts go into the hub. In the front it doesn't matter how far since there isn't anything in there. The parking brake mechanism is inside the rear hub and not too far in at that.
Make sure you spin the rear tires by hand after the new rims are on there to verify that you're not hitting anything. If you're hitting the brakes and back out of the driveway, you'll trash the parking brakes (empirically derived data, don't ya know).
Blasphemous Mike
US '87 560SEC with Euro headlights, clear markers, H&Rs, 18x8.5, ATE slotted rotors with semi-metallics, BergWerks FGS, 3.07 Limited Slip.
In progress - FrankenBenz SEC: GM LS6 5.7L engine with custom 4L60E 4-spd overdrive transmission, GM rack and pinion.
There is a very fine line between "hobby" and "mental illness."
mramay is offline   Reply With Quote
Old 07-30-2006, 02:06 AM   #8 (permalink)
Kalifornia's Avatar
Thanks to all who responded. I found two sets of H&R spacers with twenty 50mm lug bolts for under $70 total and will go with those. I will make sure not to screw them into my parking brakes!
Yet another 15" to 17" wheel upgrade thread gutowskia W124 E,CE,D,TD Class 3 01-10-2006 05:03 AM
Thread Hijacking or Thread Bullies firstmb W164 M-Class 7 08-27-2005 10:11 PM
Steering wheel thread again Benzonline W126 S,SE,SEC,SEL,SD,SDL Class 14 04-27-2005 10:53 AM
Interesting thread regarding using the OBD II port. Periokid, you might want to read this thread... SteveL R170 SLK Class 2 04-30-2002 01:29 PM
