» Featured Product
» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W126 S,SE,SEC,SEL,SD,SDL Class
Old 03-27-2006, 07:55 PM   #1 (permalink)
Aaren's Avatar
Date registered: Feb 2006
Vehicle: 1988 Mercedes 560SEL
88' 560SEL Door Locks
Ok all of a sudden my door locks have stopped working. I can of course lock and unlock each door manually, but none of the automatic locking or unlocking?
I tried seaching this forum but each time it timed out and failed.
Can someone give me a few things to look for first or better yet explain the system. I have a wiring diagram for the locks but it doesn't actually tell you where things actually are and what's a good troubleshooting checklist.
Thanks to anyone who takes the time...
Aaren Jensen - B.C. Canada
Dark Grey 1988 Mercedes-Benz 560SEL
Aaren is offline   Reply With Quote
Old 03-27-2006, 08:05 PM   #2 (permalink)
mssdoglover's Avatar
Vehicle: 1986 300SDL 311,500
Send a message via AIM to mssdoglover
RE: 88' 560SEL Door Locks
When mine did that, it was a blown fuse.
The fuse was blown because one of the rear under-door lights had come loose, gotten slammed in the door, the plastic broke, and the socket grounded to the frame of the car or something and blew the fuse... my dad figured it out finally.
IDK which fuse number, should be a diagram... but check for a blown fuse before you get too involved with the vacuum system.
Could be a vacuum line slipped loose, or perhaps (but not as likely, in my opinion) a suddenly-failed vacuum pump... but failing a fuse I"d look for a broken vacuum line, and I"m sorry I don't know where to look for the specific ones... perhaps somebody who's done it will give you a map.
Michael S.
86 300SDL *329,500 miles *
"I am a firm believer in psychology when it agrees with my own opinions."
mssdoglover is offline   Reply With Quote
Old 03-28-2006, 01:57 PM   #3 (permalink)
Aaren's Avatar
Well I have a burnt fuse and I know when I purchased the vehicle about a month ago all the fuses were intact.
Thanks!
