idle speed control??? - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 12-25-2005, 08:55 PM Thread Starter
CivicTuning2's Avatar
Date registered: Sep 2005
Vehicle: BOOsted W126
Quoted: 2 Post(s)
Send a message via AIM to CivicTuning2
does anybody know where my idle speed control is?? i asked a mechanic and told me to check it out, and no it is not the idle air control
CivicTuning2 is offline
post #2 of 7 (permalink) Old 12-26-2005, 02:05 PM
Date registered: Jan 2004
Vehicle: 88 560SEL
RE: idle speed control???
Depends on exactly what you're actually asking for - and the age of your car. If you mean the "idle control valve" you'll find it in front of the airfilter (on a V8 that is) It's cylindershaped with vacuumhoses "all over" and a contact plug on the end. If however you mean the "idle control unit" it depends on your model year. With the "KA-injection" roughly pre 1985 you'll find it between the two torpedo walls in the engine bay. On "newer" cars its placed behind the foot resting plate in the passenger footwell. In either case it's marked "idle control unit". As your car is an 300 (after 85) I'd start looking in the passenger footwell first.
Autootter is offline
post #3 of 7 (permalink) Old 12-26-2005, 02:32 PM
talbir's Avatar
Date registered: Dec 2004
Quoted: 2 Post(s)
As far as I know, the M103 engine has no idle control unit/relay.
It's all done via the CIS-KE unit and idle air valve - this valve is under the air filter on the M103, just in front of the air intake. Only two hoses on this idle air valve (M117 V8's have 3, a bypass hose as well).
However, the M103 idle air valve has a 2mm allen screw on the body which can be adjusted to correct idle speed.
talbir
Mercedes w124 500E 1993 Black 040
Mercedes w124 500E 1993 Spruce Green
Mercedes AMG 560SEC 1988
Mercedes AMG DOHC M117 w126 AMG Widebody SEC 1985
Mercedes 560SE Carat Duchatelet 1987
Mercedes w126 SEL Brabus
Mercedes w124 T Brabus
Porsche 911 Turbo SE Slantnose 1986
Mercedes 560E - w124 5.6 DOHC 360bhp by Stratton
Ferrari 328 GTS Quattrovalvole 1986 Koenig Widebody
Porsche 928 S4 by Strosek, Supercharged 550bhp
Mercedes 190E AMG Widebody
Mercedes SEC by Gemballa 6.9
talbir is offline
post #4 of 7 (permalink) Old 12-26-2005, 05:49 PM
sss11's Avatar
Date registered: Sep 2003
Vehicle: 300 SEL (1989)
Hear's a shot of the idle air control valve (see item "C") on the M103, which I've been having problems with.
Took it out the other day to cleaned it & broke one of the hoses. Managed to clean the valve & with the help of super glue, managed to put it back together. Idle lumpy at times with a minor improvement. I need to have it out again replace the hoses - so far no stock - got to look around.
I'm having difficulty removing the hoses. Any advice on how would be appreciated. What does the electrics do on the valve & what does the adjustment on the 2 mm
Allen screw do? & how to check that the valve is operating correctly?
<a href="http://english.wunderground.com/global/stations/48698.html">
<img src="http://banners.wunderground.com/banner/gizmotimetempbig_both/language/english/global/stations/48698.gif"
sss11 is offline
post #5 of 7 (permalink) Old 12-27-2005, 10:06 PM
Date registered: Apr 2004
Vehicle: W140 '93 500 SEL
The rubber hoses are in stock(ordered for me) had bought mine already.
call teng soon on 67633281.
2mm allen key screw changes idle speed. I'll leave it just buy a new unit(c).
Rough idle change a NEW(not a used one) fuel distributor ... sorry you can't avoid it.
If your idle is high could be due to you acclerator linkage. Mine was mis adjusted has readjusted them found on the fire wall near the engine bay.
W126 91 300SEL EURO, AMG 16 INCH RIMS, BURL WALNUT WOOD, ABS, NAKAMICHI RD 701,STOCK SPEAKERS. WHITE FRONT AND REAR LAMPS.(SOLD)
W140 93 500SEL COMPLETELY STOCK
PORSCHE 911SC SPORTS PACKAGE AKA REAR AND FRONT TURBO SPOILERS, RED, TARGA. COMPLETELY STOCK ONLY ADDITION IS K AND N AIR FILTER.
Peter Seow is offline
post #6 of 7 (permalink) Old 12-27-2005, 10:08 PM
Add wd 40 and slide it out. Get a new one in stock just in case you break it.
post #7 of 7 (permalink) Old 12-28-2005, 09:38 PM
wabenzi's Avatar
Date registered: Aug 2005
Send a message via AIM to wabenzi
yo what about the idle speed control unit aka "the computer"? i just had to replace one...so now the idle's back down low but the transmission's mashed up--car wont shift as rpms (and mph) increase...
wabenzi is offline
