Old 08-26-2005, 04:36 PM   #11 (permalink)
vwbuge's Avatar
Vehicle: 1985 300SD
RE: Write up on brake pad change
I have a few of my write up posted in the DIY section over at mercedesshop.com. I think I could post them here also.
vwbuge is offline   Reply With Quote
Old 08-26-2005, 05:05 PM   #12 (permalink)
sss11's Avatar
Date registered: Sep 2003
Vehicle: 300 SEL (1989)
danwatt,
An excellent presentation!
sss11
sss11 is offline   Reply With Quote
Old 08-26-2005, 05:34 PM   #13 (permalink)
dsilvar's Avatar
Date registered: Jan 2004
Vehicle: 1989 560SEL, 1998 SL 500
sss11 - 8/26/2005 8:05 PM
danwatt,
sss11
I will heartly second that and raise one..altruistic Dan..thanks
dsilvar is offline   Reply With Quote
Old 08-26-2005, 05:35 PM   #14 (permalink)
Date registered: May 2005
Vehicle: 1983 300 SD; 1989 300 SE
danwatt,
sss11
I second that, great job DanWatt.
By the way, what is proper torque for the wheels?
'83 SD burns no oil @ 216,000
Starts at zero degrees w/o a heater
Silver Blue/ Blue
andrew_falky is offline   Reply With Quote
Old 08-26-2005, 06:50 PM   #15 (permalink)
jako's Avatar
Date registered: Feb 2005
Vehicle: 86 420 sel,
jhodg5ck - 8/26/2005 8:05 AM
Out of curiosity what kind of pads are those? I see they don't come w/ any anti squeal shims attaches.
Might I also recommend that people apply anti squeal paste to the back of the pad.. I'm partial to the Mercedes paste..keeps all my cars nice and Quiet:)
Jonathan
YEAH, WE ONLY USE PAGID, TEXTAR, JURID, ATE[:D]
http://www.cardomain.com/ride/1551324
86 420 SEL, 86 560 SL, 86 560 SEC(selling), 77 300 D(selling), 87 190 D 2.5(sold), 69 280 SE(selling), 01 ML 320(sold), 02 C 230K (sold), 83 300 CD, 04 ML 350
jako is offline   Reply With Quote
Old 08-26-2005, 07:47 PM   #16 (permalink)
mramay's Avatar
Vehicle: '87 570SEC & '87 560SEL
vwbuge -
I used to use the BIG channel locks until now. This month's Star magazine brought up a really good reason to crack the bleed screw - that pushes out the brake fluid that has been exposed to the most heat, the fluid in the calipers. Makes sense to me.
Y'all take care, y'hear?
Mike R.
Blasphemous Mike
US '87 560SEC with Euro headlights, clear markers, H&Rs, 18x8.5, ATE slotted rotors with semi-metallics, BergWerks FGS, 3.07 Limited Slip.
In progress - FrankenBenz SEC: GM LS6 5.7L engine with custom 4L60E 4-spd overdrive transmission, GM rack and pinion.
There is a very fine line between "hobby" and "mental illness."
mramay is online now   Reply With Quote
Old 08-26-2005, 11:46 PM   #17 (permalink)
danwatt's Avatar
Date registered: Aug 2004
Vehicle: 1990 300SE
Send a message via AIM to danwatt
Thanks for the compliments everybody. I'm thinking about putting together a web site for just the w126. I've got a server with more than enough bandwith and space, just need to get around to doing it.
To answer some other questions:
The brand of brake pad I used was Raybestos Professional Grade. $20 at the parts store I work at. They stop great, just like the Mercedes pads I had on before, and for the price, I decided to try them out. They do make a little bit of a squeal sometimes, so I'm going to order some Textars and return the current ones under warranty.
Also, proper torque for the wheels is 80 ft lbs. All Mercedes wheels use this same torque except for wheels with 14mm studs... they use 120 ft lbs I believe (could be mistaken).
Thank you Kevin for turning it into a PDF.
danwatt is offline   Reply With Quote
Old 08-28-2005, 06:39 PM   #18 (permalink)
JR_Rider's Avatar
Date registered: Nov 2003
Vehicle: 1985 300sd
I don't know why, but I always use Textar pads. I have changed my front pads 4 times and find it very easy as well. I don't use a bleeder tool, I just pump the brakes when I get everything back together with the wheels back on of course.
JR_Rider is offline   Reply With Quote
Old 09-20-2005, 01:00 PM   #19 (permalink)
MADMAX560SEC's Avatar
Date registered: Sep 2005
Vehicle: 91 560 SEC
Nice illustration on the brake job. Just one note on pushing the brake fluid back through the system without cracking the bleeder. It may damage the ABS system. On my other cars I never worried about this, but on my 560 I cracked the bleeder when changing the pads, then evacuated the entire system and put in new. After years of driving, heat and moisture that enters the system, and hours worth of bleeding the brakes with a fresh change is well worth the time.
MADMAX560SEC is offline   Reply With Quote
Old 09-20-2005, 01:12 PM   #20 (permalink)
mark2280's Avatar
Vehicle: 1989 MB 560 SEC
Excellent point Mike. I think the next pad change I will flush the brake system. I wouldn't think that the high temps would hurt the fluid that much, but changing it ever other or every third pad set would be a good idea....By the way the Pagid pads and ATE rotors are working excellently. No squeeling, stops on a dime.
Dan, what type of bleeder is that?
mark2280 is offline   Reply With Quote
