» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W126 S,SE,SEC,SEL,SD,SDL Class
Old 08-03-2005, 02:19 PM   #1 (permalink)
mark2280's Avatar
Vehicle: 1989 MB 560 SEC
W126 High Mount Brake Light
The high mount brake light housing on my 560SEC is falling apart. I seached the archives and came up with the following website:
www.danielsternlighting.com.
He has an aftermarket model available for $37. Also, you may want to check out his other products. I have no connection to him, just passing along the info...
mark2280 is offline   Reply With Quote
Old 08-03-2005, 10:03 PM   #2 (permalink)
jdc1244's Avatar
Date registered: Jun 2003
Vehicle: 1991 300 SE
RE: W126 High Mount Brake Light
They have H4 bulbs for your Euros…
http://www.danielsternlighting.com/
This is a ‘fun fact’:
“H4 bulbs
These 2-filament bulbs with P43t base are for high/low beam headlamps and Cibié BiOscar fog/drive beam lamps. Fun facts: The H4 was the world's first 2-filament halogen automotive bulb. It was introduced in Europe in 1971, and was used in many millions of European and Japanese headlamps starting in that year, but wasn't legalized in the US (where it was designated HB2 or 9003) until over two decades later, in 1992!�
Hence the ugly DOT lamps during the entire 126 production run.
1991 300 SE (w126.024/M103.981) 140,000 miles
jdc1244 is offline   Reply With Quote
Old 02-22-2007, 11:29 PM   #3 (permalink)
Date registered: Feb 2007
Adding a High mount light on 300SD
Hi I have purchased the extra Mercedes High Mount brake light and thought the way to wire it would be easy... well it is not, as it simply does not work. Would anyone here could tell me where does it connect?
I was under the impression that the positive wire would be linked to the brake wire of existing stop lights and that the negative wire would be connected as earth. If anyone could help it would be much appreciated
silver_spirit_iv is offline   Reply With Quote
