Old 07-12-2005, 07:52 AM   #1 (permalink)
1985 300CD's Avatar
Date registered: Nov 2004
Vehicle: 300TE 4Matic
Send a message via AIM to 1985 300CD
Starting engine, engine misses and gear selector chattering. Help!
When I start the car in the morning, I need to give it gas for it to start. It stalls if you dont do it. Its either when its cold or its hot.
When I give the car some gas, it misses. I just did a full tune up. I dont know why it does that.
Also, my gear selector chatters when I give it gas and when Im crusing. My blue 300CD did that too. It gets really annyoing. Thanks for the help.
2004 Porsche Cayenne - 45,XXX
1996 Bentley Brooklands - 26,XXX
1993 300TE 4Matic - 144,XXX
1991 500SL - 90,XXX
1985 300CD is offline   Reply With Quote
Old 07-12-2005, 05:23 PM   #2 (permalink)
1985 300CD's Avatar
RE: Starting engine, engine misses and gear selector chattering. Help!
Just wanted to move it up the page a little. [:D]
Old 07-12-2005, 06:01 PM   #3 (permalink)
jdc1244a's Avatar
Date registered: Oct 2004
Send a message via Yahoo to jdc1244a
What was replaced with the tune up?
How does it run at say 40 mph? Any problems accelerating?
Does it die or stall at higher speeds?
It could be an air leak or bad OVP.
Other possibilities are the EHA, airflow sensor, or the throttle valve switch being bad.
But it sounds more fuel/air delivery than electrical.
The shakes could be due to the poor running engine in combination with worn motor mounts, tranny mounts or worn shifter bushings.
jdc1244a is offline   Reply With Quote
Old 07-13-2005, 05:24 AM   #4 (permalink)
1985 300CD's Avatar
Wires, plugs, cap, rotor. I need motor mounts for sure. At 40 the car runs great. I step on the gas, and it takes off. Doesnt stall at high speeds. Only at slow speeds when I give it gas is sputters a little. I started it up the other day, gave it gas to get it smooth, pulled a hard U-Turn and it stalled going around the turn.
Old 07-13-2005, 04:14 PM   #5 (permalink)
jdc1244a's Avatar
Sounds like an air leak – can you hear a hissing sound under the hood?
